    Version 2.30.0 requires updated nodejs, warning for pi0w installations
    24 Posts 3 Posters 14.7k Views 3 Watching
      version 2.30.0 on Jan 1, 2025 requires an updated nodejs version, minimum 20.18.1
      we also support node 23 now
      use my upgrade script and it handles the upgrade…
      For Rasperrby pi 0W users, this looks likk the last nodejs version for the armv6l devices.
      no other build has been done for quite some time.
      I am sure we will be forced to upgrade nodejs again (soon) as node 20 is getting old… now latest is node 23
      karsten13K R 2 Replies Last reply Reply Quote 1
      • S sdetweil pinned this topic on
      • karsten13K Offline
        karsten13 @sdetweil
        see https://endoflife.date/nodejs
        I recommend using even node versions (at the moment v22) as the odd ones have a short lifespan…
          sdetweil @karsten13
          @karsten13 even numbered? I was just commenting for user that installed nodejs manually before today and got the bad engine error for node 23 as it is the ‘latest’
          but for armv6l, there are no more builds, I already install from the unreleased list
            rushmuzik @sdetweil
            @sdetweil Im having some issues with the Upgrade script. This is what i’m getting in the log. Does this mean I have to do a manual upgrade? I’m using surf browser. How would I manually upgrade?
              sdetweil @rushmuzik
              @rushmuzik sorry , let me look at that
                rushmuzik @sdetweil
                @sdetweil No worries. Thanks for all that you do.
                  sdetweil @rushmuzik
                  @rushmuzik can you try the upgrade script again
                    rushmuzik @sdetweil
                    @sdetweil Still the same error in update log. unfortunately
                      sdetweil @rushmuzik
                      @rushmuzik ok, then you have to upgrade the OS on the sd card
                      see my backup/restore
                      https://github.com/sdetweil/MagicMirror-backup-restore
                      to save and later restore the MM config and modules after reinstalling MM
                      with the installer script.
                        rushmuzik @sdetweil
                        @sdetweil The interesting thing is that I was able to do a fresh install using the rasberry.sh script. I renamed my original MagicMirror folder then did a fresh install using your install script. 2.30 is running. Everything works except the calendar. lol. Where can I change the fetch timeout to 60 seconds?
                          sdetweil @rushmuzik
                          @rushmuzik send me the upgrade.log again after the new run…
                          something isn’t right…
                            sdetweil @rushmuzik
                            @rushmuzik fetchTimeout see the doc
                            have to use export
                            in front just like the external_ browser
                              rushmuzik @sdetweil
                              @sdetweil Here it is
                              Upgrade started - Fri Jan 3 20:33:33 EST 2025
                              system is Linux kiosk 6.1.21+ #1642 Mon Apr 3 17:19:14 BST 2023 armv6l GNU/Linux
                              user requested to apply changes
                              doing test run = false
                              the os is PRETTY_NAME=“Raspbian GNU/Linux 11 (bullseye)” NAME=“Raspbian GNU/Linux” VERSION_ID=“11” VERSION=“11 (bullseye)” VERSION_CODENAME=bullseye ID=raspbian ID_LIKE=debian HOME_URL=“http://www.raspbian.org/” SUPPORT_URL=“http://www.raspbian.org/RaspbianForums” BUG_REPORT_URL=“http://www.raspbian.org/RaspbianBugs”
                              the latest MagicMirror version, 2.23 (April 4 2023) or above, will not run on Raspian Bullseye, due to browser limitations
                              Upgrade ended - Fri Jan 3 20:33:33 EST 2025
                                sdetweil @rushmuzik
                                @rushmuzik yep, thanks… fixed… should have been buster…
                                  rushmuzik @sdetweil
                                  @sdetweil yep! that fixed it. update installed. Still have issues with the calendar though. holidays doesn’t load.
                                    sdetweil @rushmuzik
                                    @rushmuzik i don’t see that on my pi0w. all works great w push browser
                                    i use holidays and my personal calendar together
                                      @rushmuzik did u put on the clipping fix? pinned at top of troubleshooting
                                      are they being broadcast?
                                        rushmuzik @sdetweil
                                        @sdetweil Yes, I ran the clipping fix. I’m using the surf browser.
                                          rushmuzik @sdetweil
                                          @sdetweil according to pm2 logs it did broadcast 12 events
                                            sdetweil @rushmuzik
                                            @rushmuzik and calendar has a position set?
