    Version 2.30.0 requires updated nodejs, warning for pi0w installations
    24 Posts 3 Posters 13.8k Views 3 Watching
    • karsten13K Offline
      karsten13 @sdetweil
      see https://endoflife.date/nodejs
      I recommend using even node versions (at the moment v22) as the odd ones have a short lifespan…
        sdetweil @karsten13
        @karsten13 even numbered? I was just commenting for user that installed nodejs manually before today and got the bad engine error for node 23 as it is the ‘latest’
        but for armv6l, there are no more builds, I already install from the unreleased list
          rushmuzik @sdetweil
          @sdetweil Im having some issues with the Upgrade script. This is what i’m getting in the log. Does this mean I have to do a manual upgrade? I’m using surf browser. How would I manually upgrade?
            sdetweil @rushmuzik
            @rushmuzik sorry , let me look at that
              rushmuzik @sdetweil
              @sdetweil No worries. Thanks for all that you do.
                sdetweil @rushmuzik
                @rushmuzik can you try the upgrade script again
                  rushmuzik @sdetweil
                  @sdetweil Still the same error in update log. unfortunately
                    sdetweil @rushmuzik
                    @rushmuzik ok, then you have to upgrade the OS on the sd card
                    see my backup/restore
                    https://github.com/sdetweil/MagicMirror-backup-restore
                    to save and later restore the MM config and modules after reinstalling MM
                    with the installer script.
                      rushmuzik @sdetweil
                      @sdetweil The interesting thing is that I was able to do a fresh install using the rasberry.sh script. I renamed my original MagicMirror folder then did a fresh install using your install script. 2.30 is running. Everything works except the calendar. lol. Where can I change the fetch timeout to 60 seconds?
                        sdetweil @rushmuzik
                        @rushmuzik send me the upgrade.log again after the new run…
                        something isn’t right…
