    Version 2.30.0 requires updated nodejs, warning for pi0w installations
    24 Posts 3 Posters 13.8k Views 3 Watching
      rushmuzik @sdetweil
      @sdetweil No worries. Thanks for all that you do.
        sdetweil @rushmuzik
        @rushmuzik can you try the upgrade script again
          rushmuzik @sdetweil
          @sdetweil Still the same error in update log. unfortunately
            sdetweil @rushmuzik
            @rushmuzik ok, then you have to upgrade the OS on the sd card
            see my backup/restore
            https://github.com/sdetweil/MagicMirror-backup-restore
            to save and later restore the MM config and modules after reinstalling MM
            with the installer script.
              rushmuzik @sdetweil
              @sdetweil The interesting thing is that I was able to do a fresh install using the rasberry.sh script. I renamed my original MagicMirror folder then did a fresh install using your install script. 2.30 is running. Everything works except the calendar. lol. Where can I change the fetch timeout to 60 seconds?
                sdetweil @rushmuzik
                @rushmuzik send me the upgrade.log again after the new run…
                something isn’t right…
                  sdetweil @rushmuzik
                  @rushmuzik fetchTimeout see the doc
                  have to use export
                  in front just like the external_ browser
                    rushmuzik @sdetweil
                    @sdetweil Here it is
                    Upgrade started - Fri Jan 3 20:33:33 EST 2025
                    system is Linux kiosk 6.1.21+ #1642 Mon Apr 3 17:19:14 BST 2023 armv6l GNU/Linux
                    user requested to apply changes
                    doing test run = false
                    the os is PRETTY_NAME=“Raspbian GNU/Linux 11 (bullseye)” NAME=“Raspbian GNU/Linux” VERSION_ID=“11” VERSION=“11 (bullseye)” VERSION_CODENAME=bullseye ID=raspbian ID_LIKE=debian HOME_URL=“http://www.raspbian.org/” SUPPORT_URL=“http://www.raspbian.org/RaspbianForums” BUG_REPORT_URL=“http://www.raspbian.org/RaspbianBugs”
                    the latest MagicMirror version, 2.23 (April 4 2023) or above, will not run on Raspian Bullseye, due to browser limitations
                    Upgrade ended - Fri Jan 3 20:33:33 EST 2025
                      sdetweil @rushmuzik
                      @rushmuzik yep, thanks… fixed… should have been buster…
                        rushmuzik @sdetweil
                        @sdetweil yep! that fixed it. update installed. Still have issues with the calendar though. holidays doesn’t load.
