    Version 2.30.0 requires updated nodejs, warning for pi0w installations
    24 Posts 3 Posters 13.7k Views 3 Watching
      sdetweil @karsten13
      @karsten13 even numbered? I was just commenting for user that installed nodejs manually before today and got the bad engine error for node 23 as it is the ‘latest’
      but for armv6l, there are no more builds, I already install from the unreleased list
        rushmuzik @sdetweil
        @sdetweil Im having some issues with the Upgrade script. This is what i’m getting in the log. Does this mean I have to do a manual upgrade? I’m using surf browser. How would I manually upgrade?
          sdetweil @rushmuzik
          @rushmuzik sorry , let me look at that
            rushmuzik @sdetweil
            @sdetweil No worries. Thanks for all that you do.
              sdetweil @rushmuzik
              @rushmuzik can you try the upgrade script again
                rushmuzik @sdetweil
                @sdetweil Still the same error in update log. unfortunately
                  sdetweil @rushmuzik
                  @rushmuzik ok, then you have to upgrade the OS on the sd card
                  see my backup/restore
                  https://github.com/sdetweil/MagicMirror-backup-restore
                  to save and later restore the MM config and modules after reinstalling MM
                  with the installer script.
                    rushmuzik @sdetweil
                    @sdetweil The interesting thing is that I was able to do a fresh install using the rasberry.sh script. I renamed my original MagicMirror folder then did a fresh install using your install script. 2.30 is running. Everything works except the calendar. lol. Where can I change the fetch timeout to 60 seconds?
                      sdetweil @rushmuzik
                      @rushmuzik send me the upgrade.log again after the new run…
                      something isn’t right…
                        sdetweil @rushmuzik
                        @rushmuzik fetchTimeout see the doc
                        have to use export
                        in front just like the external_ browser
