    Version 2.30.0 Calendar fix for clipping broadcast events
    67 Posts 10 Posters 45.9k Views 10 Watching
      angeliKITTYx @angeliKITTYx
      @sdetweil I put the refresh interval back down to 100500, and the calendar refreshed. The 3rd calendar showed back up, but they’re all displaying at 5AM and going into the following day even though everything is an “all day” event in my Google calendar. It looks the same as the screenshot I shared earlier.
        sdetweil @angeliKITTYx
        @angeliKITTYx sounds like your system timezone is incorrect
        everything is based off the timezone
          angeliKITTYx @sdetweil
          @sdetweil how do I change the timezone in MM? This issue only came up once I did the fix clipping commands on this thread. And what about all the calendars that aren’t showing?
          I also just noticed my weather module stopped working too.
            @angeliKITTYx timezone, from desktop, click the calendar top right
            change timezone under calendar
            i don’t know in ext3 cals, not my module… but I use multi cals with it every day and don’t see this
            ext3 is done all in browser
            so maybe open the developer window (ctrl-shift-i) and select the console tab
            and out a unique part of the module name in the filter field, ext3 for this
              @sdetweil my raspberry pi desktop has the correct timezone, my Google calendars are all set right, and the clock module is showing the right time. Would ext3 have a different time zone set?
                @angeliKITTYx
                i do not know
                for debug purposes
                edit config.js and add
                ,"DEBUG"
                to the logLevel parms at the top
                stop (if using pm2, pm2 stop all)
                and MANUALLY start MM like this
                npm start >somefile.txt 2>&1
                wait til some time, and then ctrl-c on the command prompt where u did the manual start
                edit the config.js back to remove the debug parm
                the file will be large with all the calendars being processed
                you can’t upload that here, and I would normally ask to email it to me.
                I don’t know if email will take that large a file… you can try… my same userid as here at gmail
                because the FULL urls of the calendars are shown in the log, I don’t want that posted in clear text anywhere…
                I suggest uploading somewhere and emailing or direct message me the url
                I did extensive work on the calendar to fix these problems on this release.
                so I am very interested in the problem
                you can look thru the file, its just text and you will see the timezone reported as it processes calendar events.
                  @angeliKITTYx on weather see this
                  https://forum.magicmirror.builders/topic/19323/version-2-30-0-weather-module-stuck-loading-worked-fine-before-upgrade
                    @sdetweil so I decided to do a clean install of my MM, and the timezone thing fixed itself. However, it’s still not displaying all of my calendars. Two show up immediately, one shows up after the refreshinterval, and the rest don’t show up at all. I tried re-entering all of the private ical URLs, but those didn’t change anything. The log still shows it’s pulling x events from each URL, but they’re not displaying. Did you still want me to email you the logs?
                      @angeliKITTYx no you fixed the event date problem
                      so another test is to add a position to the default cal module and see if you see the events there
                      you did npm install in the ext3 module folder right?
                      he has a sub module that needs to be installed
                        @angeliKITTYx and another question. how did you upgrade?
                        you on pi or windows or?
                          @sdetweil It’s on pi.
                          I used these instructions, and I also did the “Not Working?” section.
                            @angeliKITTYx no, i meant upgrade MagicMirror
                            A 2 Replies Last reply Reply Quote 0
                              @sdetweil I deleted it off my Pi and then followed the Manual Install. Then I reinstalled all of my modules. It was a fresh install - I didn’t upgrade it.
                                  @angeliKITTYx i meant before, when you had the troubles
                                    @sdetweil I used the command on the MM documents page
                                    git pull && npm run install-mm
                                    But I always had to remove the package-lock.json and package.json too
                                    S A 2 Replies Last reply Reply Quote 0
                                      @angeliKITTYx ok… I wish more would use my upgrade script…
                                      it fixes problems you all report as we go along…
                                      C A 2 Replies Last reply Reply Quote 0
                                        @angeliKITTYx said in Version 2.30.0 Calendar fix for clipping broadcast events:
                                        I just tried it now and it’s not working since I’m in the fix clipping branch. It’s asking me to confirm branch.
                                          @angeliKITTYx yes,
                                          there are new steps if on a non-master branch
                                          rm package-lock.json
                                          git checkout master
                                          but you have lost the clipping fix (or develop branch)
                                          my upgrade script will put you back on master (seen as how thats where next release will land you)
                                          in the meantime, you should not need to pull again on current version, nothing changed
                                          if u want to npm install MM again (altho nothing has changed)
                                          do
                                          npm run install-mm
                                            cheminge @sdetweil
                                            @sdetweil Where is the new script? I can’t find it in your posts…
                                            • 3 / 4
