    MMM-OpenWeatherForecast showing incorrect weather for my location
    12 Posts 2 Posters 2.2k Views 2 Watching
    • K Offline
      kasperb
      Hello - I’ve been using MMM-OpenWeatherForecast successfully for a while, but noticed the temperature is significantly different from the actual temp in my location. I’ve used latlong.net to get the right Latitude and Longitude, but it’s still not right. When I navigate to openweathermap.org, I see the correct temperature for my location (New Jersey, USA).
      Any idea what could cause this? I don’t think the config allows anything other than lat/long to determine the location (e.g., no zip code, or location ID).
      • K Offline
        kasperb @sdetweil
        @sdetweil Good suggestion… that worked.
        Next, I put back the original config and changed the lat/long from a number into a string which fixed it while using my original/customized config as well.
        Thanks for your help troubleshooting @sdetweil ! Much appreciated
          sdetweil @kasperb
          @kasperb did you out them in config as numbers or quoted strings? need numbers
          • K Offline
            kasperb @sdetweil
            @sdetweil Hi - just regular numbers e.g,
            40.712776,
            -74.005974,
              sdetweil @kasperb
              @kasperb can you show the module config?
              which source for the module?
              in the module folder do
              git remote -v
              • K Offline
                kasperb @sdetweil
                Here is the config:
                    module: "MMM-OpenWeatherForecast",
                    disabled: false,
                    header: "",
                      apikey: "_DELETED_", //SUPER SECRET
                      latitude: <RM FOR PRIVACY>,
                      longitude: <RM FOR PRIVACY,
                      units: "imperial",
                      debug: true,
                      apiBaseURL: "https://api.openweathermap.org/data/3.0/onecall?",
                      iconset: "3m",
                      colored: false,
                      concise: true,
                      requestDelay: "2000",
                      showFeelsLikeTemp: true,
                      showCurrentConditions: true,
                      showSummary: true,
                      showExtraCurrentConditions: true,
                      extraCurrentConditions: {
                        highLowTemp: true,
                        precipitation: true,
                        sunrise: false,
                        sunset: false,
                        wind: true,
                        barometricPressure: false,
                        humidity: true,
                        dewPoint: false,
                        uvIndex: true,
                        visibility: false
                      forecastLayout: "table",
                      forecastHeaderText: "",
                      hourlyForecastTableHeaderText: "Hourly",
                      showHourlyForecast: true,
                      showHourlyTableHeaderRow: true,
                      hourlyForecastInterval: 3,
                      maxHourliesToShow: 3,
                      hourlyExtras: {
                        wind: true,
                        humidity: false,
                        dewPoint: false,
                        uvIndex: false,
                        visibility: false
                      dailyForecastTableHeaderText: "Weekly",
                      showDailyForecast: true,
                      showDailyTableHeaderRow: true,
                      maxDailiesToShow: 5,
                      dailyExtras: {
                        sunrise: false,
                        sunset: false,
                        wind: true,
                        humidity: false,
                        dewPoint: false,
                        uvIndex: false
                This is the output of the command:
                origin https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast (fetch)
                origin https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast (push)
                  sdetweil @kasperb
                  @kasperb ok, his doc says
                  At a minimum you need to supply the following required configuration parameters:
                  apikey
                  latitude
                  longitude
                  apikey needs to be specified as a String, while latitude and longitude can be specified as either a String or a Number. Both work fine.
                  By default the module uses the OpenWeater One Call API in version 3.0 now cause version 2.5 has been shut down in June 2024. If you know what you are doing you can use the config option apiBaseURL to specify the URL you like.
                  SO, you don’t need the apiBase property
                  and you DID get a new 3.0 apikey, (which is backed by a credit card), right?
                  the old (2.5) apiKey will not work with the 3.0 /onecall endpoint
                  also, for future… all config and log info in a code block please here on the forum
                  to do
                  paste text into editor, blank line above and below
                  select text just pasted
                  hit </> button above editor
                  the code block markers will be added… they MUST start a new line by themselves(why the blank line above/below)
                  • K Offline
                    kasperb @sdetweil
                    @sdetweil Yes, I’m using the 3.0 apikey, backed by a CC. Can you clarify what you mean with removing the ApiBase property?
                    I’m going to play around using some lat/long from neighboring towns and see if that could help.
                    Also, thanks for the guidance on posting config & log info.
                      sdetweil @kasperb
                      @kasperb if you don’t set the apiBaseURL, then the module uses what it has defined
                      this is one of the critical pieces of data to get the api to work. the less you specify the less chance of that trouble
                      • K Offline
                        kasperb @sdetweil
                        @sdetweil Removed the URL, app is loading but the same issue:
                        • 10F in the app
                        • 15F on OpenWeather.org
                        I even double-checked the lat/long, and aligned them (‘geo coords’) exactly with what’s listed for my location on the OpenWeather.org site.
                          sdetweil @kasperb
                          @kasperb and if you start w his example config and your lat/lon and apikey?
