    MMM-OpenWeatherForecast showing incorrect weather for my location
    12 Posts 2 Posters 2.3k Views 2 Watching
    • K Offline
      kasperb @sdetweil
      @sdetweil Hi - just regular numbers e.g,
      40.712776,
      -74.005974,
        sdetweil @kasperb
        @kasperb can you show the module config?
        which source for the module?
        in the module folder do
        git remote -v
        • K Offline
          kasperb @sdetweil
          Here is the config:
              module: "MMM-OpenWeatherForecast",
              disabled: false,
              header: "",
                apikey: "_DELETED_", //SUPER SECRET
                latitude: <RM FOR PRIVACY>,
                longitude: <RM FOR PRIVACY,
                units: "imperial",
                debug: true,
                apiBaseURL: "https://api.openweathermap.org/data/3.0/onecall?",
                iconset: "3m",
                colored: false,
                concise: true,
                requestDelay: "2000",
                showFeelsLikeTemp: true,
                showCurrentConditions: true,
                showSummary: true,
                showExtraCurrentConditions: true,
                extraCurrentConditions: {
                  highLowTemp: true,
                  precipitation: true,
                  sunrise: false,
                  sunset: false,
                  wind: true,
                  barometricPressure: false,
                  humidity: true,
                  dewPoint: false,
                  uvIndex: true,
                  visibility: false
                forecastLayout: "table",
                forecastHeaderText: "",
                hourlyForecastTableHeaderText: "Hourly",
                showHourlyForecast: true,
                showHourlyTableHeaderRow: true,
                hourlyForecastInterval: 3,
                maxHourliesToShow: 3,
                hourlyExtras: {
                  wind: true,
                  humidity: false,
                  dewPoint: false,
                  uvIndex: false,
                  visibility: false
                dailyForecastTableHeaderText: "Weekly",
                showDailyForecast: true,
                showDailyTableHeaderRow: true,
                maxDailiesToShow: 5,
                dailyExtras: {
                  sunrise: false,
                  sunset: false,
                  wind: true,
                  humidity: false,
                  dewPoint: false,
                  uvIndex: false
          This is the output of the command:
          origin https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast (fetch)
          origin https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast (push)
            sdetweil @kasperb
            @kasperb ok, his doc says
            At a minimum you need to supply the following required configuration parameters:
            apikey
            latitude
            longitude
            apikey needs to be specified as a String, while latitude and longitude can be specified as either a String or a Number. Both work fine.
            By default the module uses the OpenWeater One Call API in version 3.0 now cause version 2.5 has been shut down in June 2024. If you know what you are doing you can use the config option apiBaseURL to specify the URL you like.
            SO, you don’t need the apiBase property
            and you DID get a new 3.0 apikey, (which is backed by a credit card), right?
            the old (2.5) apiKey will not work with the 3.0 /onecall endpoint
            also, for future… all config and log info in a code block please here on the forum
            to do
            paste text into editor, blank line above and below
            select text just pasted
            hit </> button above editor
            the code block markers will be added… they MUST start a new line by themselves(why the blank line above/below)
            • K Offline
              kasperb @sdetweil
              @sdetweil Yes, I’m using the 3.0 apikey, backed by a CC. Can you clarify what you mean with removing the ApiBase property?
              I’m going to play around using some lat/long from neighboring towns and see if that could help.
              Also, thanks for the guidance on posting config & log info.
                sdetweil @kasperb
                @kasperb if you don’t set the apiBaseURL, then the module uses what it has defined
                this is one of the critical pieces of data to get the api to work. the less you specify the less chance of that trouble
                • K Offline
                  kasperb @sdetweil
                  @sdetweil Removed the URL, app is loading but the same issue:
                  • 10F in the app
                  • 15F on OpenWeather.org
                  I even double-checked the lat/long, and aligned them (‘geo coords’) exactly with what’s listed for my location on the OpenWeather.org site.
                    sdetweil @kasperb
                    @kasperb and if you start w his example config and your lat/lon and apikey?
                    • K Offline
                      kasperb @sdetweil
                      @sdetweil Good suggestion… that worked.
                      Next, I put back the original config and changed the lat/long from a number into a string which fixed it while using my original/customized config as well.
                      Thanks for your help troubleshooting @sdetweil ! Much appreciated
                        sdetweil @kasperb
                        @kasperb awesome!
