    MMM-OpenWeatherForecast showing incorrect weather for my location
    12 Posts 2 Posters 2.2k Views 2 Watching
    • K Offline
      kasperb @sdetweil
      Here is the config:
          module: "MMM-OpenWeatherForecast",
          disabled: false,
          header: "",
            apikey: "_DELETED_", //SUPER SECRET
            latitude: <RM FOR PRIVACY>,
            longitude: <RM FOR PRIVACY,
            units: "imperial",
            debug: true,
            apiBaseURL: "https://api.openweathermap.org/data/3.0/onecall?",
            iconset: "3m",
            colored: false,
            concise: true,
            requestDelay: "2000",
            showFeelsLikeTemp: true,
            showCurrentConditions: true,
            showSummary: true,
            showExtraCurrentConditions: true,
            extraCurrentConditions: {
              highLowTemp: true,
              precipitation: true,
              sunrise: false,
              sunset: false,
              wind: true,
              barometricPressure: false,
              humidity: true,
              dewPoint: false,
              uvIndex: true,
              visibility: false
            forecastLayout: "table",
            forecastHeaderText: "",
            hourlyForecastTableHeaderText: "Hourly",
            showHourlyForecast: true,
            showHourlyTableHeaderRow: true,
            hourlyForecastInterval: 3,
            maxHourliesToShow: 3,
            hourlyExtras: {
              wind: true,
              humidity: false,
              dewPoint: false,
              uvIndex: false,
              visibility: false
            dailyForecastTableHeaderText: "Weekly",
            showDailyForecast: true,
            showDailyTableHeaderRow: true,
            maxDailiesToShow: 5,
            dailyExtras: {
              sunrise: false,
              sunset: false,
              wind: true,
              humidity: false,
              dewPoint: false,
              uvIndex: false
      This is the output of the command:
      origin https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast (fetch)
      origin https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast (push)
        sdetweil @kasperb
        @kasperb ok, his doc says
        At a minimum you need to supply the following required configuration parameters:
        apikey
        latitude
        longitude
        apikey needs to be specified as a String, while latitude and longitude can be specified as either a String or a Number. Both work fine.
        By default the module uses the OpenWeater One Call API in version 3.0 now cause version 2.5 has been shut down in June 2024. If you know what you are doing you can use the config option apiBaseURL to specify the URL you like.
        SO, you don’t need the apiBase property
        and you DID get a new 3.0 apikey, (which is backed by a credit card), right?
        the old (2.5) apiKey will not work with the 3.0 /onecall endpoint
        also, for future… all config and log info in a code block please here on the forum
        to do
        paste text into editor, blank line above and below
        select text just pasted
        hit </> button above editor
        the code block markers will be added… they MUST start a new line by themselves(why the blank line above/below)
        • K Offline
          kasperb @sdetweil
          @sdetweil Yes, I’m using the 3.0 apikey, backed by a CC. Can you clarify what you mean with removing the ApiBase property?
          I’m going to play around using some lat/long from neighboring towns and see if that could help.
          Also, thanks for the guidance on posting config & log info.
            sdetweil @kasperb
            @kasperb if you don’t set the apiBaseURL, then the module uses what it has defined
            this is one of the critical pieces of data to get the api to work. the less you specify the less chance of that trouble
            • K Offline
              kasperb @sdetweil
              @sdetweil Removed the URL, app is loading but the same issue:
              • 10F in the app
              • 15F on OpenWeather.org
              I even double-checked the lat/long, and aligned them (‘geo coords’) exactly with what’s listed for my location on the OpenWeather.org site.
                sdetweil @kasperb
                @kasperb and if you start w his example config and your lat/lon and apikey?
                • K Offline
                  kasperb @sdetweil
                  @sdetweil Good suggestion… that worked.
                  Next, I put back the original config and changed the lat/long from a number into a string which fixed it while using my original/customized config as well.
                  Thanks for your help troubleshooting @sdetweil ! Much appreciated
                    sdetweil @kasperb
                    @kasperb awesome!
