    Problems with KristjanESPERANTO/MMM-PublicTransportHafas
    13 Posts 5 Posters 6.1k Views 5 Watching
    • K Offline
      Klinge
      I am currently having problems with the configuration of KristjanESPERANTO/MMM-PublicTransportHafas.
      My config looks like this
                                module: "MMM-PublicTransportHafas",
                                          stationID: "8005662",                   // Replace with your stationID!
                                          stationName: "XXXXX",   // Replace with your station name!
                                          direction: "",                    // Show only departures heading to this station. (A station ID.)
                                          ignoredLines: [],                 // Which lines should be ignored? (comma-separated list of line names)
                                          excludedTransportationTypes: ["bus"],  // Which transportation types should not be shown on the mirror? (comma-separated list of types) possible values: StN for tram, BuN for bus, s for suburban
                                          timeToStation: 10,
                                          timeInFuture: 120,                 // Show departures for the next *timeInFuture* minutes.
                                          showColoredLineSymbols: false,     // Want colored line symbols?
                                          useColorForRealtimeInfo: true,    // Want colored real time information (timeToStation, early)?
                                          showTableHeadersAsSymbols: true,  // Table Headers as symbols or text?
                                          maxUnreachableDepartures: 1,      // How many unreachable departures should be shown?
                                          maxReachableDepartures: 7,        // How many reachable departures should be shown?
                                          customLineStyles: "leipzig",      // Prefix for the name of the custom css file. ex: Leipzig-lines.css (case sensitive)
                                          showOnlyLineNumbers: false        // Display only the line number instead of the complete name, i. e. "11" instead of "STR 11"
      This shows me all trains departing from the starting station. S-Bahn (S) and Regional Express (RE) trains.
      However, as soon as I enter a destination station in “direction” as follows, only the S-Bahn trains are displayed. And the Regional Express is missing. Although the destination station is Hannover Hbf, where Regional Express trains also arrive.
                                          direction: "8000152",                    // Show only departures heading to this station. (A station ID.)
                                          timeToStation: 10,
      What can I do, that the Regional Express (RE) will be shown too when I enter a direction?
      Thank you in advance.
      Kind regards
      Klinge
        sdetweil @Klinge
        @Klinge did you look at the repo issues?? or create one?
        • K Offline
          Klinge @sdetweil
          @sdetweil Sorry, but I don´t know what you mean. So I would say, no
            sdetweil @Klinge
            @Klinge every module that you git clone install has a repository
            github/gitlab
            anyhow, the creator of the module would look at the issues page for reported problems
            https://github.com/KristjanESPERANTO/MMM-PublicTransportHafas
            and that page shows
            K 1 Reply Last reply Reply Quote 1
            • K Offline
              Klinge @sdetweil
              @sdetweil Ok, there is an issue regarding direction. I commented it and now I will be patient.
              Thank you for you advice
              • K Klinge has marked this topic as solved on
                sdetweil @Klinge
                @Klinge also, if you don’t know where an modules github page is (or don’t remember as we all do)
                in the module folder do
                git remote -v
                and it will give you the url where this module came from
                • V Offline
                  Volkae
                  Don´t know what happend,
                  everything worked fine, but since two days it does not work anymore. It only signs “Abfahrtsschnittstelle nicht erreichbar”.
                  Same problem on my other MM.
                  Any idea?
                  Volker
                  S KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
                    sdetweil @Volkae
                    @Volkae I’m guessing something changed in the service api.
                    @kristjanesperanto will be along tomorrow
                    • KristjanESPERANTOK Offline
                      KristjanESPERANTO Module Developer @Volkae
                      There have been some recent issues with certain APIs (we use different ones depending on the profile). Tell me which profile you’re using and which station and I’ll check. If you don’t want to share the station here, you can also send it to me via private message.
                      W V 2 Replies Last reply Reply Quote 0
                      • W Offline
                        wimThoelke @KristjanESPERANTO
                        same problem here:
                        module: “MMM-PublicTransportHafas”,
                        hafasProfile: “db”,
                        stationID: “467033”,
                          KristjanESPERANTO Module Developer @wimThoelke
                          @wimthoelke
                          Please update to the new version (v4.4.3). Your stationID works for me.
                          If this doesn’t work: use the profile dbweb.
                          If this doesn’t work, checkout this module: MMM-PublicTransportHub
                          • W Offline
                            @KristjanESPERANTO
                            THANX! works with 4.4.3 (same config).
                            • V Offline
                              Volkae @KristjanESPERANTO
                              @KristjanESPERANTO
                              I used Sam´s update-script and now it works again.
                              Thanks for your help!!
                              @KristjanESPERANTO
                              @KristjanESPERANTO
