    Problems with KristjanESPERANTO/MMM-PublicTransportHafas
    13 Posts 5 Posters 6.4k Views 5 Watching
    • K
      Klinge @sdetweil
      @sdetweil Sorry, but I don´t know what you mean. So I would say, no
        sdetweil @Klinge
        @Klinge every module that you git clone install has a repository
        github/gitlab
        anyhow, the creator of the module would look at the issues page for reported problems
        https://github.com/KristjanESPERANTO/MMM-PublicTransportHafas
        and that page shows
        K 1 Reply Last reply
        • K
          Klinge @sdetweil
          @sdetweil Ok, there is an issue regarding direction. I commented it and now I will be patient.
          Thank you for you advice
          • K Klinge has marked this topic as solved on
            sdetweil @Klinge
            @Klinge also, if you don’t know where an modules github page is (or don’t remember as we all do)
            in the module folder do
            git remote -v
            and it will give you the url where this module came from
            • V
              Volkae
              Don´t know what happend,
              everything worked fine, but since two days it does not work anymore. It only signs “Abfahrtsschnittstelle nicht erreichbar”.
              Same problem on my other MM.
              Any idea?
              Volker
              S KristjanESPERANTOK 2 Replies Last reply
                sdetweil @Volkae
                @Volkae I’m guessing something changed in the service api.
                @kristjanesperanto will be along tomorrow
                • KristjanESPERANTOK
                  KristjanESPERANTO Module Developer @Volkae
                  There have been some recent issues with certain APIs (we use different ones depending on the profile). Tell me which profile you’re using and which station and I’ll check. If you don’t want to share the station here, you can also send it to me via private message.
                  W V 2 Replies Last reply
                  • W
                    wimThoelke @KristjanESPERANTO
                    same problem here:
                    module: “MMM-PublicTransportHafas”,
                    hafasProfile: “db”,
                    stationID: “467033”,
                    KristjanESPERANTOK 1 Reply Last reply
                      KristjanESPERANTO Module Developer @wimThoelke
                      @wimthoelke
                      Please update to the new version (v4.4.3). Your stationID works for me.
                      If this doesn’t work: use the profile dbweb.
                      If this doesn’t work, checkout this module: MMM-PublicTransportHub
                      W 1 Reply Last reply
                      • W
                        @KristjanESPERANTO
                        THANX! works with 4.4.3 (same config).
                        • V
                          Volkae @KristjanESPERANTO
                          @KristjanESPERANTO
                          I used Sam´s update-script and now it works again.
                          Thanks for your help!!
                          @KristjanESPERANTO
                          @KristjanESPERANTO
