    Bugsounet and MMM-Pir
    68 Posts 10 Posters 33.6k Views 11 Watching
      bitass @sdetweil
      I also used several great modules from this developer.
      I followed the advice to disable the GA related updates and copy the used modules as backup.
      I disabled the GA module, YT module, detector module, browser module,…
      When I look in my LOG file I still see that the modules (from this developer) not GA related generating errors.
      Is there something we can do about the errors?
      S 2 Replies Last reply
        myfingersarecold @sdetweil
        @sdetweil i will post my pir module on github tonight. its much more simple, but may work for some as a replacement.
        S M 2 Replies Last reply
          sdetweil @myfingersarecold
          @myfingersarecold add it to the 3rd party wiki
          see the link here
          you do the editing
          https://docs.magicmirror.builders/modules/introduction.html
          M 1 Reply Last reply
            @sdetweil will do.
              myfingersarecold @myfingersarecold
              added to the 3rd party module wiki list under the other PIR modules. github page linked as well.
              https://github.com/ryanjblajda/MMM-SimplePIR
                sdetweil @bitass
                @bitass i didnt say disable the modules. i said disable the notifications
                from the updateNotifications module doc
                https://docs.magicmirror.builders/modules/updatenotification.html#configuration-options
                  sdetweil @bitass
                  @bitass and he has blocked all his modules
                    MMaik100
                    so now the EXT-YouTube wont work either?
                      sdetweil @MMaik100
                      @MMaik100 yes, sadly all his modules will fail eventually, depending on how tight he coupled them
                        coernel
                        I also just looked for the module as I wanted to contribute some troubleshooting guide and didn’t find it.
                        As I have installed the module, what do you think about re-publishing it so that it doesn’t get lost?
                        It is MIT-license so no problem about that!
                          coernel
                          I have re-published it already: https://github.com/Coernel82/MMM-Pir
                            sdetweil @coernel
                            @coernel please add it to the third party list
                            • L
                              lif
                              Is this the correct place to ask questions about the module?
                              If so, is there any way to test that it is actually running?
                              I have installed the module for using a PIR module but nothing appears in the screen in the place I requested it.
                                sdetweil @lif
                                @lif have you verified that the PIR is working outside of MagicMirror??
                                L 1 Reply Last reply
                                • L
                                  lif @sdetweil
                                  @sdetweil said in Bugsounet and MMM-Pir:
                                  Yes,
                                    sdetweil @lif
                                    @lif and you are using the correct pin definition
                                        Pir: {
                                          mode: 0,
                                          gpio: 21
                                    L 2 Replies Last reply
                                    • L
                                      lif @sdetweil
                                          Pir: {
                                            mode: 0,
                                            gpio: 21
                                      Yes, the working script is:
                                      from gpiozero import MotionSensor
                                      from datetime import datetime
                                      import os, time
                                      import RPi.GPIO as GPIO
                                      pir = MotionSensor(21)
                                      while True:
                                          pir.wait_for_motion()
                                          now = datetime.now()
                                          current_time = now.strftime("%H:%M:%S")
                                          print("Movement detected at", current_time)
                                          pir.wait_for_no_motion()
                                        sdetweil @lif
                                        @lif I meant MMM-PIR config setup
                                        there are different numbering schemes for GPIO pins and different ways to access
                                        the doc (readme) describes the different choices.
                                        • L
                                          lif @sdetweil
                                              Pir: {
                                                mode: 0,
                                                gpio: 21
                                          Yes, I think so, the pir is connected to pin 40 on the Raspberry pi 3b which I’m sure is GPIO 21
                                            sdetweil @lif
                                            @lif and if you change to mode 1?? which matches your python lib test?
                                            • 1 / 4
