    Bugsounet and MMM-Pir
    68 Posts 10 Posters 32.3k Views 11 Watching
      myfingersarecold @sdetweil
      @sdetweil i will post my pir module on github tonight. its much more simple, but may work for some as a replacement.
        sdetweil @myfingersarecold
        @myfingersarecold add it to the 3rd party wiki
        see the link here
        you do the editing
        https://docs.magicmirror.builders/modules/introduction.html
          @sdetweil will do.
            myfingersarecold @myfingersarecold
            added to the 3rd party module wiki list under the other PIR modules. github page linked as well.
            https://github.com/ryanjblajda/MMM-SimplePIR
              sdetweil @bitass
              @bitass i didnt say disable the modules. i said disable the notifications
              from the updateNotifications module doc
              https://docs.magicmirror.builders/modules/updatenotification.html#configuration-options
                sdetweil @bitass
                @bitass and he has blocked all his modules
                  MMaik100
                  so now the EXT-YouTube wont work either?
                    sdetweil @MMaik100
                    @MMaik100 yes, sadly all his modules will fail eventually, depending on how tight he coupled them
                      coernel
                      I also just looked for the module as I wanted to contribute some troubleshooting guide and didn’t find it.
                      As I have installed the module, what do you think about re-publishing it so that it doesn’t get lost?
                      It is MIT-license so no problem about that!
                        coernel
                        I have re-published it already: https://github.com/Coernel82/MMM-Pir
                          sdetweil @coernel
                          @coernel please add it to the third party list
                          • L Offline
                            lif
                            Is this the correct place to ask questions about the module?
                            If so, is there any way to test that it is actually running?
                            I have installed the module for using a PIR module but nothing appears in the screen in the place I requested it.
                              sdetweil @lif
                              @lif have you verified that the PIR is working outside of MagicMirror??
                              • L Offline
                                lif @sdetweil
                                @sdetweil said in Bugsounet and MMM-Pir:
                                Yes,
                                  sdetweil @lif
                                  @lif and you are using the correct pin definition
                                      Pir: {
                                        mode: 0,
                                        gpio: 21
                                  L 2 Replies Last reply Reply Quote 0
                                  • L Offline
                                    lif @sdetweil
                                        Pir: {
                                          mode: 0,
                                          gpio: 21
                                    Yes, the working script is:
                                    from gpiozero import MotionSensor
                                    from datetime import datetime
                                    import os, time
                                    import RPi.GPIO as GPIO
                                    pir = MotionSensor(21)
                                    while True:
                                        pir.wait_for_motion()
                                        now = datetime.now()
                                        current_time = now.strftime("%H:%M:%S")
                                        print("Movement detected at", current_time)
                                        pir.wait_for_no_motion()
                                      sdetweil @lif
                                      @lif I meant MMM-PIR config setup
                                      there are different numbering schemes for GPIO pins and different ways to access
                                      the doc (readme) describes the different choices.
                                      • L Offline
                                        lif @sdetweil
                                            Pir: {
                                              mode: 0,
                                              gpio: 21
                                        Yes, I think so, the pir is connected to pin 40 on the Raspberry pi 3b which I’m sure is GPIO 21
                                          sdetweil @lif
                                          @lif and if you change to mode 1?? which matches your python lib test?
                                          • L Offline
                                            lif @sdetweil
                                            No difference.
                                            I have added a header: “PIR”, line before the config and that is not showing either.
                                            • 1 / 4
