    Google Photos API changing - MMM-GooglePhotos will stop working soon.
    22 Posts 4 Posters 9.0k Views 4 Watching
      @gonzonia
      gp app is the ONLY way to pick images
      the selected pics access times out after an hour!!!
      G 1 Reply Last reply
      • G
        gonzonia @sdetweil
        @sdetweil so the user wouldn’t have to Re-select after an hour? That can’t be right.
          sdetweil @gonzonia
          @gonzonia so it seems.
          • G
            gonzonia @sdetweil
            @sdetweil The way they want it to work is that the user makes the selection, the app gets the items, the session ends. In this case, that would mean the module would have to pull the photos locally which would limit the number of photos available by the amount of space available. I might as well just use a different module and put all my photos somewhere on my network.
              sdetweil @gonzonia
              @gonzonia yes, i use local already. have a 12tb nas drive for photos
              G A 2 Replies Last reply
              • G
                gonzonia @sdetweil
                @sdetweil yeah Google was one of my backups. We are primarily an Apple family but there’s no iCloud module that I’m aware of. I’ll have to do an export or figure something else out.
                • A
                  Andresleonsalas @sdetweil
                  @sdetweil what module are you using for local photos?
                    sdetweil @Andresleonsalas
                    @Andresleonsalas I use an updated version of MMM-ImagesPhotos
                    see my fork https://github.com/sdetweil/MMM-ImagesPhotos
                    supports recursive image folder…
                    I am picky about displaying my photos…
                    I don’t want cover or contain, I want consistent aspect ratio…
                    fit vertical or horizontal and adjust the other to the physical size…
                    G S 2 Replies Last reply
                    • G
                      gonzonia @sdetweil
                      @sdetweil Thanks. I got that up and running. One thing I wish it had (and I don’t think any module does). I’d like to show some of the EXIF data.
                      At a minimum, the date the photo was taken, but ideally, also lookup the location and display that in a friendly manner (i.e. City, State, Country)
                      I thought, “that shouldn’t be too hard” but I don’t understand modules and the relationship of node helper to the main js. I’m not sure how to load the appropriate library to access the exif data.
                        sdetweil @gonzonia
                        @gonzonia modulename.js runs in a browser
                        but a browser cannot access files, except thru a web server,
                        also cant access hardware (gpio)
                        so the node_helper runs on server as task, so it can
                        there is an api to send request to helper and get response back,
                        this module uses another trick, by accessing a web link to a file
                        anyhow , here is a drawing i did years ago to explain this, its truncated on the side on purpose, as its just repetitive
                        my sample module shows all that operation
                        https://github.com/sdetweil/SampleModule
                        anyhow, one could extend the response to include the exif data
                        here is a nodejs lib that does exif
                        https://www.npmjs.com/package/exif
                        • G
                          gonzonia @sdetweil
                          @sdetweil Thanks. That’s helpful. But I think it’s still above my pay-grade. I may poke around and see if I can figure something out, but I’m not sure I can. I conceptually understand what’s happening, but don’t see it in the code in a way that is clicking for me such that I can just make a call to an Exif method where it pulls the data from the file.
                          I’ve come across a couple of other modules who are doing some of it, but again, I’m not quite sure I understand how the data is being passed around so that I can correctly apply the logic in the right place.
                          • G
                            gonzonia @gonzonia
                            @sdetweil MMM-BackgroundSlideshow seems to do exactly what I want, but I think your handling of formatting the images is better.
                              Sampleswow @sdetweil
                              @sdetweil Sorry about the late reply i am just now finding out about the google-photos issue, i like your remedy but as i was looking at your fork i couldn’t figure out how to point the check file to my NAS i can defiantly cre4ate a specific folder on my NAS but I’m not sure where i would input that information to your fork??
                                sdetweil @Sampleswow
                                @Sampleswow so you have to mount the Nas file servr share to
                                your Linux machine
                                Once you do that
                                This module uses a specific folder, uploads, to find pics
                                Then you rensmentyevexisting uploads out of the way and use the ln command to make a link uploads to the mounted Nas folder
