    MMM-FroniusSolar family modules
    31 Posts 5 Posters 13.1k Views 5 Watching
    • W
      waynerob11
      Tried to install 2 and 3 on an RPI 3B+ running 64
      bookworm - will not even load and throws a .js error - IP address configured and did copy and paste for the config.js - mm just stalls
      C 1 Reply Last reply
        chrisfr1976 @sdetweil
        I’ve updated the node _helper.js.
        //const fetch = require("node-fetch");
        If some has trouble it can be reactivated. Maybe I hab installed node_helper in the past manually. I don’t remember. Until now I had no errors from that. But yes, it woks well without this line.
        Regards, Chris.
        W 1 Reply Last reply
          chrisfr1976 @waynerob11
          @waynerob11
          Please send the error massage that you receive. I want to help you!
          Regards, Chris.
          • W
            waynerob11 @chrisfr1976
            @chrisfr1976
            Thanks for your response - I am attempting to install Fronius Solar 2 and have commented out the line in node-helper.js as advised in a previous post ( //const fetch = require(“node-fetch”);) and ran MM.
            It all loaded OK with no errors but it doesn’t show up on the dashboard, doesn’t even say loading. IP address is correct.
            Wayne
            C W 3 Replies Last reply
              @waynerob11 Hello,
              I’ve created a version with console.logs inside. Go to the MMM-FroniusSolar2 module folder and replace the files with this content:
              MMM-FroniusSolar2.js:
              Module.register("MMM-FroniusSolar2", {
                  defaults: {
                      InverterIP: "192.168.178.134",
                      updateInterval: 60000, // Update every 60 seconds
                      icons: {
                          P_Akku: "mdi:car-battery",
                          P_Grid: "mdi:transmission-tower",
                          P_Load: "mdi:home-lightbulb",
                          P_PV: "mdi:solar-panel-large",
                      Radius: 80, // Radius for the SVG gauges
                      MaxPower: 1000, // Maximum power for grid, house, and battery
                      MaxPowerPV: 10400, // Maximum power for solar PV
                      ShowText: true,
                      TextMessge: [
                          { about: "600", Text: "Leicht erhöhter Netzbezug.", color: "#999" },
                          { about: "1000", Text: "Über 1 KW Netzbezug!", color: "#ffffff" },
                          { about: "1500", Text: "Über 1,5KW Netzbezug.", color: "#eea205" },
                          { about: "2500", Text: "Über 2,5KW aus dem Netz!", color: "#ec7c25" },
                          { about: "5000", Text: "Auto lädt, richtig? Nächstes Mal auf Sonne warten.", color: "#cc0605" },
                          { less: "-500", Text: "Sonne scheint! Mehr als 500W frei.", color: "#f8f32b" },
                          { less: "-2000", Text: "Wäsche waschen! Über 2KW freie Energie!", color: "#00bb2d" },
                          { less: "-4000", Text: "Auto laden! Über 4KW freie Energie!", color: "#f80000" },
                      debug: true, // Set to true to enable debug logging
                  start: function () {
                      if (this.config.debug) {
                          console.log("[MMM-FroniusSolar2] Starting module with config:", this.config);
                      this.solarData = null;
                      this.solarSOC = null; // Added for SOC
                      console.log("[MMM-FroniusSolar2] Sending configuration to node_helper...");
                      this.sendSocketNotification("SET_CONFIG", this.config); // Send configuration to node_helper
                      this.scheduleUpdate(); // Schedule periodic updates
                  getStyles: function () {
                      return ["MMM-FroniusSolar2.css", "https://code.iconify.design/2/2.2.1/iconify.min.js"];
                  scheduleUpdate: function () {
                          console.log("[MMM-FroniusSolar2] Scheduling updates every", this.config.updateInterval, "ms");
                      const self = this;
                      setInterval(function () {
                          if (self.config.debug) {
                              console.log("[MMM-FroniusSolar2] Requesting data update from node_helper...");
                          self.sendSocketNotification("GET_FRONIUS_DATA");
                      }, this.config.updateInterval);
                  socketNotificationReceived: function (notification, payload) {
                      if (notification === "FRONIUS_DATA") {
                              console.log("[MMM-FroniusSolar2] Received FRONIUS_DATA:", payload);
                          this.solarData = {
                              P_Akku: Math.round(payload.P_Akku || 0),
                              P_Grid: Math.round(payload.P_Grid || 0),
                              P_Load: Math.round(payload.P_Load || 0),
                              P_PV: Math.round(payload.P_PV || 0),
                          this.solarSOC =
                              payload.Inverters &&
                              payload.Inverters["1"] &&
                              payload.Inverters["1"].SOC
                                  ? Math.round(payload.Inverters["1"].SOC)
                                  : 0; // Fallback to 0 if SOC is undefined
                              console.log("[MMM-FroniusSolar2] Processed solarData:", this.solarData, "SOC:", this.solarSOC);
                          this.updateDom();
                  getDom: function () {
                          console.log("[MMM-FroniusSolar2] Rendering DOM");
                      const wrapper = document.createElement("div");
                      wrapper.className = "solar2-wrapper";
                      if (!this.solarData) {
                          wrapper.innerHTML = "Loading...";
                          return wrapper;
                      const radius = this.config.Radius || 80;
                      const strokeWidth = 12;
                      const svgSize = 350; // Adjusted SVG height for labels and padding
                      // Recalculate house consumption
                      const outerPower = this.solarData.P_Grid + this.solarData.P_Akku + this.solarData.P_PV;
                      // Fixed positions for the gauges in dice layout
                      const positions = {
                          PV: { x: 75, y: 75 },
                          Grid: { x: 225, y: 75 },
                          Akku: { x: 75, y: 225 },
                          House: { x: 225, y: 225 }
                      // Define colors for gauges
                      const gridColor = this.solarData.P_Grid >= 0 ? "#808080" : "#add8e6"; // Gray for positive, light blue for negative
                      const akkuColor = "#00ff00"; // Always green
                      const pvColor = "#ffff00"; // Always yellow
                      // House Gauge: Logic for color determination
                      let houseColor;
                      if (this.solarData.P_Akku - 100 > Math.abs(this.solarData.P_Grid)) {
                          houseColor = "#a3c49f"; // Light green for high battery activity
                      } else if (this.solarData.P_Grid > 150) {
                          houseColor = "#808080"; // Gray for high grid consumption
                      } else if (outerPower > 0) {
                          houseColor = "#00ff00"; // Green for positive power flow
                      } else {
                          houseColor = "#1f84ff"; // Light blue
                          console.log("[MMM-FroniusSolar2] Gauge colors determined:",
                              { pvColor, gridColor, akkuColor, houseColor });
                      // Create unified SVG
                      const svg = document.createElementNS("http://www.w3.org/2000/svg", "svg");
                      svg.setAttribute("width", svgSize);
                      svg.setAttribute("height", svgSize);
                      svg.setAttribute("viewBox", "0 -20 300 350"); // Adjusted viewBox to fix label cutoff
                      svg.style.margin = "auto"; // Center the SVG
                      // Define glow effect
                      const defs = document.createElementNS("http://www.w3.org/2000/svg", "defs");
                      defs.innerHTML = `
                          <filter id="glow">
                              <feGaussianBlur in="SourceGraphic" stdDeviation="4" result="blurred" />
                              <feMerge>
                                  <feMergeNode in="blurred" />
                                  <feMergeNode in="SourceGraphic" />
                              </feMerge>
                          </filter>
                      svg.appendChild(defs);
                      // Function to create a line
                      const createLine = (x1, y1, x2, y2, color) => {
                              console.log("[MMM-FroniusSolar2] Creating line:", { x1, y1, x2, y2, color });
                          const line = document.createElementNS("http://www.w3.org/2000/svg", "line");
                          line.setAttribute("x1", x1);
                          line.setAttribute("y1", y1);
                          line.setAttribute("x2", x2);
                          line.setAttribute("y2", y2);
                          line.setAttribute("stroke", color);
                          line.setAttribute("stroke-width", "4");
                          line.setAttribute("class", "flow-lines");
                          return line;
                      // Add flow lines based on power conditions
                      if (this.solarData.P_Akku < -10 && this.solarData.P_PV > 0 ) {
                          svg.appendChild(createLine(positions.PV.x, positions.PV.y + radius, positions.Akku.x, positions.Akku.y - radius, "#ffff00"));
                      if (this.solarData.P_PV > 10) {
                          svg.appendChild(createLine(positions.PV.x + (radius * 0.7071), positions.PV.y + (radius * 0.7071), positions.House.x - (radius * 0.7071), positions.House.y - (radius * 0.7071), "#ffff00"));
                      if (this.solarData.P_Grid > 10) {
                          svg.appendChild(createLine(positions.Grid.x, positions.Grid.y + radius, positions.House.x, positions.House.y - radius, "#808080"));
                      if (this.solarData.P_Akku > 10) {
                          svg.appendChild(createLine(positions.Akku.x + radius, positions.Akku.y, positions.House.x - radius, positions.House.y, "#00ff00"));
                      if (this.solarData.P_Grid < -10 && this.solarData.P_PV > Math.abs(this.solarData.P_Grid)) {
                          svg.appendChild(createLine(positions.PV.x + radius, positions.PV.y, positions.Grid.x - radius, positions.Grid.y, "#add8e6"));
                      if (this.solarData.P_Grid < -10 && this.solarData.P_PV <= 0) {
                          svg.appendChild(createLine(positions.Akku.x + (radius * 0.7071), positions.Akku.y - (radius * 0.7071), positions.Grid.x - (radius * 0.7071), positions.Grid.y + (radius * 0.7071), "#00ff00"));
                      if (this.solarData.P_PV <= 0 && this.solarData.P_Akku < -10) {
                          svg.appendChild(createLine(positions.Grid.x - (radius * 0.7071), positions.Grid.y + (radius * 0.7071), positions.Akku.x + (radius * 0.7071), positions.Akku.y - (radius * 0.7071), "#808080"));
                      // Function to create a gauge
                      const createGauge = (x, y, mainValue, subValue, percentage, color, label, icon, labelPosition) => {
                              console.log("[MMM-FroniusSolar2] Creating gauge:", { label, mainValue, subValue, percentage, color });
                          const group = document.createElementNS("http://www.w3.org/2000/svg", "g");
                          group.setAttribute("transform", `translate(${x},${y})`);
                          // Circle Background
                          const bgCircle = document.createElementNS("http://www.w3.org/2000/svg", "circle");
                          bgCircle.setAttribute("cx", 0);
                          bgCircle.setAttribute("cy", 0);
                          bgCircle.setAttribute("r", radius);
                          bgCircle.setAttribute("stroke", "#e0e0e0");
                          bgCircle.setAttribute("opacity", "1");
                          bgCircle.setAttribute("stroke-width", strokeWidth);
                          bgCircle.setAttribute("fill", "none");
                          group.appendChild(bgCircle);
                          // Circle Progress with glow
                          const progressCircle = document.createElementNS("http://www.w3.org/2000/svg", "circle");
                          progressCircle.setAttribute("cx", 0);
                          progressCircle.setAttribute("cy", 0);
                          progressCircle.setAttribute("r", radius);
                          progressCircle.setAttribute("stroke", color);
                          progressCircle.setAttribute("stroke-width", strokeWidth);
                          progressCircle.setAttribute("fill", "none");
                          progressCircle.setAttribute("stroke-dasharray", `${percentage * 2 * Math.PI * radius} ${2 * Math.PI * radius}`);
                          progressCircle.setAttribute("transform", "rotate(-90 0 0)");
                          progressCircle.setAttribute("filter", "url(#glow)"); // Apply glow filter
                          group.appendChild(progressCircle);
                          // Main Text
                          const mainText = document.createElementNS("http://www.w3.org/2000/svg", "text");
                          mainText.setAttribute("x", 0);
                          mainText.setAttribute("y", 6); // Adjusted y position for main text
                          mainText.setAttribute("text-anchor", "middle");
                          mainText.setAttribute("font-size", "22px");
                          mainText.setAttribute("fill", "#ffffff");
                          mainText.textContent = mainValue;
                          group.appendChild(mainText);
                          // Sub Text
                          if (subValue) {
                              const subText = document.createElementNS("http://www.w3.org/2000/svg", "text");
                              subText.setAttribute("x", 0);
                              subText.setAttribute("y", 25); // Adjusted y position for sub text
                              subText.setAttribute("text-anchor", "middle");
                              subText.setAttribute("font-size", "16px");
                              subText.setAttribute("fill", "#ffffff");
                              subText.textContent = subValue;
                              group.appendChild(subText);
                          // Label with foreignObject for icon
                          const labelY = labelPosition === "top" ? -(radius + 45) : radius + 15; // Increased offset for top labels
                          const labelContainer = document.createElementNS("http://www.w3.org/2000/svg", "foreignObject");
                          labelContainer.setAttribute("x", -radius - 20);
                          labelContainer.setAttribute("y", labelY);
                          labelContainer.setAttribute("text-anchor", "middle");
                          labelContainer.setAttribute("width", radius * 2);
                          labelContainer.setAttribute("height", labelPosition === "top" ? 60 : 40); // Adjusted label height
                          labelContainer.innerHTML = `
                              <div xmlns="http://www.w3.org/1999/xhtml" style="display: flex; align-items: center; justify-content: center; text-align: center; font-size: 20px; color: white;">
                                  <span class="iconify" data-icon="${icon}" style="margin-right: 5px;"></span>
                                  ${label}
                              </div>
                          group.appendChild(labelContainer);
                          return group;
                      // Add gauges to SVG
                      svg.appendChild(createGauge(
                          positions.PV.x,
                          positions.PV.y,
                          `${this.solarData.P_PV || 0} W`,
                          null,
                          Math.min((this.solarData.P_PV || 0) / this.config.MaxPowerPV, 1),
                          pvColor,
                          "PV",
                          this.config.icons.P_PV,
                          "top"
                          positions.Grid.x,
                          positions.Grid.y,
                          `${this.solarData.P_Grid || 0} W`,
                          null,
                          Math.min(Math.abs(this.solarData.P_Grid || 0) / this.config.MaxPower, 1),
                          gridColor,
                          "Grid",
                          this.config.icons.P_Grid,
                          "top"
                          positions.Akku.x,
                          positions.Akku.y,
                          `${this.solarSOC || 0}%`,
                          `${this.solarData.P_Akku || 0} W`,
                          Math.min(this.solarSOC / 100, 1),
                          akkuColor,
                          "Akku",
                          this.config.icons.P_Akku,
                          "bottom"
                          positions.House.x,
                          positions.House.y,
                          `${outerPower || 0} W`,
                          null,
                          Math.min(Math.abs(outerPower || 0) / this.config.MaxPower, 1),
                          houseColor,
                          "House",
                          this.config.icons.P_Load,
                          "bottom"
                      wrapper.appendChild(svg);
                      // Add dynamic text message below the gauge
                      if (this.config.ShowText) {
                          const textMessageDiv = document.createElement("div");
                          textMessageDiv.className = "text-message2";
                          const messageConfig = this.config.TextMessge || [];
                          let selectedMessage = null;
                          for (const message of messageConfig) {
                              if (
                                  (message.about && this.solarData.P_Grid > parseInt(message.about)) ||
                                  (message.less && this.solarData.P_Grid < parseInt(message.less))
                                  // If no message is selected yet, or the new match is more specific
                                  if (
                                      !selectedMessage ||
                                      (message.about && parseInt(message.about) > parseInt(selectedMessage.about || -Infinity)) ||
                                      (message.less && parseInt(message.less) < parseInt(selectedMessage.less || Infinity))
                                      selectedMessage = message;
                          if (selectedMessage) {
                                  console.log("[MMM-FroniusSolar2] Selected text message:", selectedMessage);
                              textMessageDiv.innerHTML = `
                                  <span style="color: ${selectedMessage.color}; font-size: 18px;">
                                      ${selectedMessage.Text}
                                  </span>
                          } else {
                                  <span style="color: #999; font-size: 16px;">
                                      PV Anlage läuft...
                                  </span>
                          wrapper.appendChild(textMessageDiv);
                      return wrapper;
              node_helper.js::
              const NodeHelper = require("node_helper");
                  config: null, // Initially, no config is set
                      console.log("[MMM-FroniusSolar2] Node helper started");
                      console.log("[MMM-FroniusSolar2] Received socket notification:", notification, payload);
                      if (notification === "SET_CONFIG") {
                          this.config = payload;
                              console.log("[MMM-FroniusSolar2] Configuration received:", this.config);
                          this.startFetchingData();
                      } else if (notification === "GET_FRONIUS_DATA") {
                          if (!this.config) return;
                              console.log("[MMM-FroniusSolar2] GET_FRONIUS_DATA triggered");
                          this.getFroniusData();
                  startFetchingData: function () {
                      if (this.config && this.config.InverterIP) {
                              console.log("[MMM-FroniusSolar2] Starting data fetch interval for IP", this.config.InverterIP);
                          this.fetchInterval = setInterval(() => {
                          }, 60000); // Fetch data every 60 seconds
                  getFroniusData: function () {
                      if (!this.config || !this.config.InverterIP) return;
                      const url = `http://${this.config.InverterIP}/solar_api/v1/GetPowerFlowRealtimeData.fcgi`;
                          console.log("[MMM-FroniusSolar2] Fetching data from URL:", url);
                      fetch(url)
                          .then(response => {
                                  console.log("[MMM-FroniusSolar2] Response received:", response);
                              if (!response.ok) {
                                  throw new Error(`HTTP error!`);
                              return response.json();
                          .then(data => {
                                  console.log("[MMM-FroniusSolar2] JSON data received:", data);
                              const siteData = data.Body.Data.Site;
                              const inverterData = data.Body.Data.Inverters ? data.Body.Data.Inverters["1"] : {};
                              const result = {
                                  P_Akku: siteData.P_Akku || 0,
                                  P_Grid: siteData.P_Grid || 0,
                                  P_Load: siteData.P_Load || 0,
                                  P_PV: siteData.P_PV || 0,
                                  Inverters: { "1": { SOC: inverterData.SOC || 0 } },
                                  console.log("[MMM-FroniusSolar2] Parsed result:", result);
                              this.sendSocketNotification("FRONIUS_DATA", result);
                          .catch(error => {
                              console.error("[MMM-FroniusSolar2] Error fetching data:", error);
              This will create a lot of log entry. So only use this temporary. If you see any errors you can’t solve, please send me the logs.
              Later use pm2 flush to clear the logs. The log-file size will increase with this version quite fast.
              Regards, Chris.
                @waynerob11
                is this issue solved now?
                Regards, Chris.
                • T
                  TomOMaley
                  Hi, does meanwhil one of your fronius modules work whithout Problems? Tried the second one but no display at all. What changes in the config etc. are still necessary?
                  Regards Walter
                    chrisfr1976 @TomOMaley
                    @TomOMaley
                    All modules work without any problems on my mirror. No errors, nothing in the logs and it gets data every 2 seconds.
                    To go to the chat and post a mimimi only is not that helpful to find the error. Use the log-version above then you‘ll find your error.
                    Read the doc, install the latest module, enter a correct ip and activate the api in your inverter. I cannot see any more I can do here. At least post an error log or somerhing helpful.
                    Regards, Chris.
                    T 1 Reply Last reply
                    • T
                      TomOMaley @chrisfr1976
                      @chrisfr1976 Dear Chris, I apologize for my unqualified question. Regards
                      • W
                        waynerob11 @waynerob11
                        Hi Chris,
                        Don’t know what I did but it’s all working now - only problem is all the circles are bunched up.
                        Also, how can I enlarge and bold the fonts
                        @waynerob11
                        C W 2 Replies Last reply
                          @waynerob11
                          please send a screenshot to understand clearly what you like to do.
                          Regards, Chris.
                          • W
                              @waynerob11 Hi,
                              please check in your config.js the radius value. It should be Radius: 50,. In the beginning when I released the module there was a copy+paste error. The radius was 80.
                              If you want to enlarge everything as I see the gauge radius on your mirror you need do go deeper into the MMM-FroniusSolar2.js file:
                              • Adjust text size in // Main Text | // Sub Text area.
                              • Modify gauge coordinates here:
                                      const positions = {
                              • If everything is bigger modify also the view box:
                              The view box part is really annoying. It does not what you expect (The gauges do not have 50px. In fact everything is scaled in the viewbox). If you have a working status which might be useful for others, please share. I cannot support here since it is really tricky.
                              Regards, Chris.
                              • W
                                @chrisfr1976 Changing it from 80 to 50 fixed the problem - thankyou
                                  Hi folks,
                                  a new family-member has joined: MMM-FroniusSolar5.
                                  This adds the functionality to monitor and visualize solar energy data from multiple Fronius inverters simultaneously.
                                  See module for more information. If you have 2 or more Fronius Inverters running, give it a try.
                                  I am not completely sure if it works 100% stable since I have only 1 inverter. If you discover any problems open an issue.
                                  Regards, Chris.
