    MM always black screen with cursor
    20 Posts 2 Posters 3.7k Views 2 Watching
      sdetweil @nowayto
      @nowayto show
      npm start >somefile.txt
      then when screen up, ctrl-q
      and look at somefile.txt
      • N Offline
        nowayto @sdetweil
        This is the result inside the *.txt
        magicmirror@2.30.0 start
        npm run start:x11
        magicmirror@2.30.0 start:x11
        [2025-02-24 20:55:20.171] [LOG] Starting MagicMirror: v2.30.0
        [2025-02-24 20:55:22.568] [LOG] Loading config …
        [2025-02-24 20:55:22.695] [LOG] config template file not exists, no envsubst
        [2025-02-24 20:55:31.157] [INFO] Checking config file /home/berrymirror/MagicMirror/config/config.js …
        [2025-02-24 20:55:31.368] [INFO] Your configuration file doesn’t contain syntax errors :)
        [2025-02-24 20:55:31.371] [INFO] Checking modules structure configuration …
        [2025-02-24 20:55:33.349] [INFO] Your modules structure configuration doesn’t contain errors :)
        [2025-02-24 20:55:33.364] [LOG] Loading module helpers …
        [2025-02-24 20:55:33.371] [LOG] No helper found for module: alert.
        [2025-02-24 20:55:33.399] [LOG] Initializing new module helper …
        [2025-02-24 20:55:33.401] [LOG] Module helper loaded: updatenotification
        [2025-02-24 20:55:33.404] [LOG] No helper found for module: clock.
        [2025-02-24 20:55:34.525] [LOG] Initializing new module helper …
        [2025-02-24 20:55:34.526] [LOG] Module helper loaded: calendar
        [2025-02-24 20:55:34.532] [LOG] No helper found for module: compliments.
        [2025-02-24 20:55:34.538] [LOG] No helper found for module: weather.
        [2025-02-24 20:55:35.571] [LOG] Initializing new module helper …
        [2025-02-24 20:55:35.572] [LOG] Module helper loaded: newsfeed
        [2025-02-24 20:55:35.573] [LOG] All module helpers loaded.
        [2025-02-24 20:55:35.711] [LOG] Starting server on port 8080 …
        [2025-02-24 20:56:47.381] [LOG] Server started …
        [2025-02-24 20:56:49.306] [LOG] Connecting socket for: updatenotification
        [2025-02-24 20:56:50.754] [LOG] Starting module helper: updatenotification
        [2025-02-24 20:56:50.897] [LOG] Connecting socket for: calendar
        [2025-02-24 20:56:51.135] [LOG] Starting node helper for: calendar
        [2025-02-24 20:56:51.155] [LOG] Connecting socket for: newsfeed
        [2025-02-24 20:56:51.159] [LOG] Starting node helper for: newsfeed
        [2025-02-24 20:56:51.421] [LOG] Sockets connected & modules started …
        [2025-02-24 20:58:33.277] [LOG] Launching application.
          sdetweil @nowayto
          @nowayto i would wait a little longer, web app not open yet
          or npm start dev, in the dev window select the console tab
          see if there is an error displayed
          • N Offline
            nowayto @sdetweil
            After 1 millions of tests and trying… now it works.
            It seems it start to work using “raspbian bookworm 32bit legacy”.
            I tried with the non-legacy too and it didn’t work.
            Is that possible?
            I’m asking that because I know my 3 model A+ is 64bit capable.
            Honestly, without your advice… I’ll never though it could be the OS.
            Thank you a lot, now I’ll start a new chapter: the configuration
              sdetweil @nowayto
              @nowayto i think 64 bit is ok, IF you have the physical memory
              3A doesnt
                sdetweil @nowayto
                @nowayto configuration, try my MMM-Config module. also supports installing modules
                https://github.com/sdetweil/MMM-Config
                • N Offline
                  nowayto @sdetweil
                  very interesting. I’ve installed it, but I can’t access to webpanel.
                  Tried with:
                  http://IP:PORT/configure
                  http://LOCALHOST:PORT/configure
                  no access.
                  tried with standard 8080 and another port chosen by me.
                  computer IP is whitelisted, and clearly on same network.
                  config check is OK
                  ~/MagicMirror/config $ npm run config:check
                  magicmirror@2.30.0 config:check
                  node js/check_config.js
                  [2025-02-26 15:19:04.776] [INFO] Checking config file /home/PINAME/MagicM irror/config/config.js …
                  [2025-02-26 15:19:04.960] [INFO] Your configuration file doesn’t contain syntax errors :)
                  [2025-02-26 15:19:04.962] [INFO] Checking modules structure configuration …
                  [2025-02-26 15:19:05.229] [INFO] Your modules structure configuration doesn’t c ontain errors :)
                  Another little issues: sometimes I got black screen with cursor after “npm run start”
                  I have to restart it in order to making it work
                    sdetweil @nowayto
                    @nowayto did you add my module to config.js
                            module:"MMM-Config",
                            position:"....one_of the positions",
                             config:{
                    S N 2 Replies Last reply Reply Quote 0
                      @nowayto
                      on the startup, can you show the output of
                      npm run start
                      also show output of
                      free -m
                      • N Offline
                        nowayto @sdetweil
                        Yes i did and the config checker gave me the OK
                        this is the startup
                        npm run start
                        npm run start:x11
                        [2025-02-26 15:00:59.702] [LOG] Starting MagicMirror: v2.30.0
                        [2025-02-26 15:01:01.515] [LOG] Loading config …
                        [2025-02-26 15:01:01.525] [LOG] config template file not exists, no envsubst
                        [2025-02-26 15:01:10.865] [INFO] Checking config file /home/MYRASPBERRYNAME/MagicM irror/config/config.js …
                        [2025-02-26 15:01:11.018] [INFO] Your configuration file doesn’t contain syntax errors :)
                        [2025-02-26 15:01:11.020] [INFO] Checking modules structure configuration …
                        [2025-02-26 15:01:11.253] [INFO] Your modules structure configuration doesn’t c ontain errors :)
                        [2025-02-26 15:01:12.473] [LOG] Loading module helpers …
                        [2025-02-26 15:01:12.480] [LOG] No helper found for module: alert.
