    MM always black screen with cursor
    20 Posts 2 Posters 4.9k Views 2 Watching
    • N Offline
      nowayto @sdetweil
      This is the result inside the *.txt
      magicmirror@2.30.0 start
      npm run start:x11
      magicmirror@2.30.0 start:x11
      [2025-02-24 20:55:20.171] [LOG] Starting MagicMirror: v2.30.0
      [2025-02-24 20:55:22.568] [LOG] Loading config …
      [2025-02-24 20:55:22.695] [LOG] config template file not exists, no envsubst
      [2025-02-24 20:55:31.157] [INFO] Checking config file /home/berrymirror/MagicMirror/config/config.js …
      [2025-02-24 20:55:31.368] [INFO] Your configuration file doesn’t contain syntax errors :)
      [2025-02-24 20:55:31.371] [INFO] Checking modules structure configuration …
      [2025-02-24 20:55:33.349] [INFO] Your modules structure configuration doesn’t contain errors :)
      [2025-02-24 20:55:33.364] [LOG] Loading module helpers …
      [2025-02-24 20:55:33.371] [LOG] No helper found for module: alert.
      [2025-02-24 20:55:33.399] [LOG] Initializing new module helper …
      [2025-02-24 20:55:33.401] [LOG] Module helper loaded: updatenotification
      [2025-02-24 20:55:33.404] [LOG] No helper found for module: clock.
      [2025-02-24 20:55:34.525] [LOG] Initializing new module helper …
      [2025-02-24 20:55:34.526] [LOG] Module helper loaded: calendar
      [2025-02-24 20:55:34.532] [LOG] No helper found for module: compliments.
      [2025-02-24 20:55:34.538] [LOG] No helper found for module: weather.
      [2025-02-24 20:55:35.571] [LOG] Initializing new module helper …
      [2025-02-24 20:55:35.572] [LOG] Module helper loaded: newsfeed
      [2025-02-24 20:55:35.573] [LOG] All module helpers loaded.
      [2025-02-24 20:55:35.711] [LOG] Starting server on port 8080 …
      [2025-02-24 20:56:47.381] [LOG] Server started …
      [2025-02-24 20:56:49.306] [LOG] Connecting socket for: updatenotification
      [2025-02-24 20:56:50.754] [LOG] Starting module helper: updatenotification
      [2025-02-24 20:56:50.897] [LOG] Connecting socket for: calendar
      [2025-02-24 20:56:51.135] [LOG] Starting node helper for: calendar
      [2025-02-24 20:56:51.155] [LOG] Connecting socket for: newsfeed
      [2025-02-24 20:56:51.159] [LOG] Starting node helper for: newsfeed
      [2025-02-24 20:56:51.421] [LOG] Sockets connected & modules started …
      [2025-02-24 20:58:33.277] [LOG] Launching application.
        sdetweil @nowayto
        @nowayto i would wait a little longer, web app not open yet
        or npm start dev, in the dev window select the console tab
        see if there is an error displayed
        • N Offline
          nowayto @sdetweil
          After 1 millions of tests and trying… now it works.
          It seems it start to work using “raspbian bookworm 32bit legacy”.
          I tried with the non-legacy too and it didn’t work.
          Is that possible?
          I’m asking that because I know my 3 model A+ is 64bit capable.
          Honestly, without your advice… I’ll never though it could be the OS.
          Thank you a lot, now I’ll start a new chapter: the configuration
            sdetweil @nowayto
            @nowayto i think 64 bit is ok, IF you have the physical memory
            3A doesnt
              sdetweil @nowayto
              @nowayto configuration, try my MMM-Config module. also supports installing modules
              https://github.com/sdetweil/MMM-Config
              • N Offline
                nowayto @sdetweil
                very interesting. I’ve installed it, but I can’t access to webpanel.
                Tried with:
                http://IP:PORT/configure
                http://LOCALHOST:PORT/configure
                no access.
                tried with standard 8080 and another port chosen by me.
                computer IP is whitelisted, and clearly on same network.
                config check is OK
                ~/MagicMirror/config $ npm run config:check
                magicmirror@2.30.0 config:check
                node js/check_config.js
                [2025-02-26 15:19:04.776] [INFO] Checking config file /home/PINAME/MagicM irror/config/config.js …
                [2025-02-26 15:19:04.960] [INFO] Your configuration file doesn’t contain syntax errors :)
                [2025-02-26 15:19:04.962] [INFO] Checking modules structure configuration …
                [2025-02-26 15:19:05.229] [INFO] Your modules structure configuration doesn’t c ontain errors :)
                Another little issues: sometimes I got black screen with cursor after “npm run start”
                I have to restart it in order to making it work
                  sdetweil @nowayto
                  @nowayto did you add my module to config.js
                          module:"MMM-Config",
                          position:"....one_of the positions",
                           config:{
                  S N 2 Replies Last reply Reply Quote 0
                    @nowayto
                    on the startup, can you show the output of
                    npm run start
                    also show output of
                    free -m
                    • N Offline
                      nowayto @sdetweil
                      Yes i did and the config checker gave me the OK
                      this is the startup
                      npm run start
                      npm run start:x11
                      [2025-02-26 15:00:59.702] [LOG] Starting MagicMirror: v2.30.0
                      [2025-02-26 15:01:01.515] [LOG] Loading config …
                      [2025-02-26 15:01:01.525] [LOG] config template file not exists, no envsubst
                      [2025-02-26 15:01:10.865] [INFO] Checking config file /home/MYRASPBERRYNAME/MagicM irror/config/config.js …
                      [2025-02-26 15:01:11.018] [INFO] Your configuration file doesn’t contain syntax errors :)
                      [2025-02-26 15:01:11.020] [INFO] Checking modules structure configuration …
                      [2025-02-26 15:01:11.253] [INFO] Your modules structure configuration doesn’t c ontain errors :)
                      [2025-02-26 15:01:12.473] [LOG] Loading module helpers …
                      [2025-02-26 15:01:12.480] [LOG] No helper found for module: alert.
                      • N Offline
                        nowayto @sdetweil
                        free -m
                        total used free shared buff/cache available
                        Mem: 426 180 91 81 155 112
                        Swap: 1023 225 798
                          sdetweil @nowayto
                          @nowayto more log info, i dont see info for mmm-config
                          • N Offline
                            nowayto @sdetweil
                            npm run start
                            npm run start:x11
                            [2025-02-26 15:01:10.865] [INFO] Checking config file /home/MYRASPBNAME/MagicM irror/config/config.js …
                            [2025-02-26 15:01:12.519] [LOG] Initializing new module helper …
                            [2025-02-26 15:01:12.522] [LOG] Module helper loaded: updatenotification
                            [2025-02-26 15:01:12.525] [LOG] No helper found for module: clock.
                            [2025-02-26 15:01:13.000] [LOG] Initializing new module helper …
                            [2025-02-26 15:01:13.001] [LOG] Module helper loaded: calendar
                            [2025-02-26 15:01:13.005] [LOG] No helper found for module: compliments.
                            [2025-02-26 15:01:13.007] [LOG] No helper found for module: weather.
                            [2025-02-26 15:01:42.730] [LOG] Initializing new module helper …
                            [2025-02-26 15:01:42.732] [LOG] Module helper loaded: MMM-Wallpaper
                            [2025-02-26 15:01:43.127] [LOG] Initializing new module helper …
                            [2025-02-26 15:01:43.128] [LOG] Module helper loaded: MMM-Config
                            [2025-02-26 15:01:43.437] [LOG] Initializing new module helper …
                            [2025-02-26 15:01:43.438] [LOG] Module helper loaded: newsfeed
                            [2025-02-26 15:01:43.439] [LOG] All module helpers loaded.
                            [2025-02-26 15:01:43.455] [LOG] Starting server on port **** …
                            [2025-02-26 15:02:26.268] [LOG] Server started …
                            [2025-02-26 15:02:26.271] [LOG] Connecting socket for: updatenotification
                            [2025-02-26 15:02:26.288] [LOG] Starting module helper: updatenotification
                            [2025-02-26 15:02:26.290] [LOG] Connecting socket for: calendar
                            [2025-02-26 15:02:26.291] [LOG] Starting node helper for: calendar
                            [2025-02-26 15:02:26.293] [LOG] Connecting socket for: MMM-Wallpaper
                            [2025-02-26 15:02:26.295] [LOG] Starting node helper for: MMM-Wallpaper
                            [2025-02-26 15:02:26.306] [LOG] Connecting socket for: MMM-Config
                            [2025-02-26 15:02:27.236] [LOG] Connecting socket for: newsfeed
                            [2025-02-26 15:02:27.237] [LOG] Starting node helper for: newsfeed
                            [2025-02-26 15:02:27.258] [LOG] Sockets connected & modules started …
                            [2025-02-26 15:02:44.884] [LOG] Launching application.
                              sdetweil @nowayto
                              @nowayto then you should be able to access the mmm-config urls
                              • N Offline
                                nowayto @sdetweil
                                Exactly but I can’t access.
                                Now I’m trying give a whitelist complete access.
                                The only error I see is a GPU process error but I don’t think is connected to the web server.
                                [2025-02-26 22:43:49.784] [LOG] Launching application.
                                [7194:0226/224359.949078:ERROR:gpu_process_host.cc(1007)] GPU process exited unexpectedly: exit_code=512
                                [2025-02-26 22:44:42.117] [LOG]
                                [7194:0226/224442.468308:ERROR:gpu_process_host.cc(1007)] GPU process exited unexpectedly: exit_code=512
                                [7194:0226/224504.822973:ERROR:gpu_process_host.cc(1007)] GPU process exited unexpectedly: exit_code=512
                                [2025-02-26 22:45:56.193]
                                [INFO] System information:
                                SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model A Plus Rev 1.1; virtual: false
                                OS: platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21-v7+
                                VERSIONS: electron: 32.3.1; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2: 5.4.3
                                OTHER: timeZone: Europe/Rome; ELECTRON_ENABLE_GPU: undefined
                                [2025-02-26 22:45:56.931] [LOG] Create new calendarfetcher for url: https://ics.calendarlabs.com/76/****MYCAL***** - Interval: 604800000
                                [2025-02-26 22:45:57.049] [LOG] Create new newsfetcher for url: http://www.MYRSS**- Interval: 300000
                                [2025-02-26 22:45:57.118] [INFO] updatenotification: Updater Class Loaded!
                                [2025-02-26 22:45:57.123] [INFO] updatenotification: Checking PM2 using…
                                [2025-02-26 22:45:57.125] [INFO] updatenotification: [PM2] You are not using pm2
                                [2025-02-26 22:45:57.128] [INFO] Checking git for module: MMM-Wallpaper
                                [2025-02-26 22:45:57.591] [INFO] Checking git for module: MMM-Config
                                [2025-02-26 22:45:57.893] [INFO] Checking git for module: MagicMirror
                                [2025-02-26 22:45:58.426] [INFO] Calendar-Fetcher: Broadcasting 10 events from https://ics.calendarlabs.com*****MYCAL****.
                                [2025-02-26 22:45:58.443] [INFO] Newsfeed-Fetcher: Broadcasting 10 items.
                                • N Offline
                                  nowayto @sdetweil
                                  My fault. In config.js the adress was set in “localhost”… Sorry.
                                  Now I set the IP and I granted the access
                                    sdetweil @nowayto
                                    @nowayto yes, the doc mentions this, and if you had set
                                    showQR:true
                                    it would have displayed a message about localhost
