    MMM-FRITZ-Box-Callmonitor-py3 and MMM-Callmonitor-Current-Call
    69 Posts 7 Posters 25.0k Views 8 Watching
      sdetweil @xIExodusIx
      @xIExodusIx you did not need to fork now… I was just explaining , but
      you cannot have two folders with the same name,
      so you could
      rename your current folder,
      git clone the fork,
      and copy the files from your old renamed folder to the new cloned folder
      then
      git add
      git commit
      git push
      if you have trouble with english, post in your native language and I will use a translator to help…
      also the page can usually be translated for you from my english
      in chrome is under the 3 dots menu to the right of the address fields
      X 1 Reply Last reply
      • X
        xIExodusIx @sdetweil
        I’m commig up to “git push” asking for my username followed by my password, but then i got an error because of: Support for password authentication was removed on August 13, 2021.
        Why everything must be made so complicated. There’s no fun. :-( Nothing is smooth and easy anymore. :-(
        I should authenticate now with a “Personal-Access-Token”. I don’t own one.
        To create a “Personal-Access-Token” I have to go to my Organization, I have no Organization, I’m a private person that tries to have a little fun with a MagicMirror2 and some other Raspberry Pi projects.
        When I create an Organization and then following the instructions to create Personal-Access-Tokens, no Tokens were created.
        Sorry, for today I had enough problems, will try tomorrow again.
          @xIExodusIx yes, everybody is getting more serious about security in WAY too many different ways
          for github, read the doc on my backup/restore tools
          https://github.com/sdetweil/MagicMirror-backup-restore
            @xIExodusIx
            you can also save the settings for git
            see
            https://forum.magicmirror.builders/post/124488
            • X
              Sorry sdetweil, on my github account site at “Password and authentication” is no “developer settings”.
              What I can see is;
              Password and a button with Change Password
              Passkeys and somthing toadd and modify them.
              Two-factor authentication! with a bunch of settings.
              But no “developer settings”.
                @xIExodusIx its moved, select settings, then at the bottom
                • X
                  Okay I hav now a “Personal-Access-Token” but the next problem is comming up afet I make “git push”
                  Problem:
                  remote: Permission to xIExodusIx/MMM-FRITZ-Box-Callmonitor-py3.git denied to xIExodusIx.
                  It’s really complicated and frustrating :-(
                  What have I to do now? I searched for permissons on github to modify for uploading but could not find anything.
                    @xIExodusIx show output of
                    git remote -v
                    • X
                      git remote -v
                      origin https://github.com/xIExodusIx/MMM-FRITZ-Box-Callmonitor-py3.git (fetch)
                      origin https://github.com/xIExodusIx/MMM-FRITZ-Box-Callmonitor-py3.git (push)
                      That is what I get.
                        @xIExodusIx you did use the token as the password, right?
                        X 3 Replies Last reply
                        • X
                          Yes, when I type git push, I have to type in my username and next I have to type in the “userpassword” for that I take the “Personal-Access-Toke” I got from github.
                          Thats what I do:
                          git push
                          Username for ‘https://github.com’: xIExodusIx
                          Password for ‘https://xIExodusIx@github.com’:
                          Schwerwiegend: konnte nicht auf ‘https://github.com/xIExodusIx/MMM-FRITZ-Box-Callmonitor-py3.git/’ zugreifen: The requested URL returned error: 403
                          The Problem is, that the “password” aka “Personal-Access-Token” is not showed in Linux (RaspiOS). I copy the “PAT (Personal-Access.-Token)” that I stored in Keepass on my PC and insert it using a klick with the right mouse-button in RaspiOS.
                          • X
                            I got it, I made a new “Personal-Access-Token (classic)” giving it write access permissons for repositories and could now successful make “git push”.
                            • X
                              What have I to do next?
                              Can I edit my commit? I would like to give mor information and correct some typing errors.
                                @xIExodusIx no , cannot edit a “commit”
                                you can make another
                                change files
                                test
                                git status
                                git add
                                git commit
                                git push
                                same workflow each time
                                • X
                                  okay :-)
                                  Thank you very, very much for your help.
                                  R 1 Reply Last reply
                                    rkorell Module Developer @xIExodusIx
                                    Dear @xIExodusIx ,
                                    do you think it’s possible to get your re-compiled code?
                                    I’m really curious - because the current call monitor is “nice” but the improvements you had described seemed to be really promising…
                                    Thanks a lot.
                                    Warmest regards,
                                    Ralf
                                    • X
                                      xIExodusIx @rkorell
                                      @rkorell
                                      Hi Ralf,
                                      if you search within the MM2 modules for “armybean” and find the module “MMM-Callmonitor-Current-Call” click on the right side in the description on “MMM-FRITZ-Box-Callmonitor”.
                                      On the next screen click on the right side on “25 Forks” there you will find my Fork “xIExodusIx / MMM-FRITZ-Box-Callmonitor-py3”.
                                      You can “git clone it” using “git clone https://github.com/xIExodusIx/MMM-FRITZ-Box-Callmonitor-py3.git” in the /MagicMirror/modules folder. That should do all for you. After that follow th instrucktions given by “Paviro or Dr.Torchwood” they are almost the same.
                                      I havs only merged the Versions from Paviro and armybeen and drtorchwood together, I did not compile the module new. Paviro did the aase Module, armybean added the (colored) direction arrows and drtorchwood made the module work with python3.
                                      If you wnt to have the colored direction arrows you have to add “showOutgoing: true, and colorEnabled: true,” at the modulesection “MMM-FRITZ-Box-Callmonitor.py” in the /MagicMirror/config/config.js. Same if you use armybeans “MMM-Callmonitor-Current-Call”.
                                      I hope this is understanding for you.
                                      Have fun with it.
                                      Carsten
                                      R 2 Replies Last reply
                                        @xIExodusIx said
                                        Have fun with it.
                                        Dear Carsten, indeed - I DO have fun!
                                        It’s really, really nice and works like a charm!
                                        Thanks a LOT for your great work.
                                        For future releases (if I interpret the above thread and Sam’s (@sdetweil 's) hints and advices correctly) you can edit the “README.md” file locally in your directory.
                                        There you can include your own input/changes and own hints for installing (e.g. correct the git clone-link) - and AFTER these changes in documentation do the git push-thing …
                                        Thank you very much for your effort!
                                        Warmest regards,
                                        Ralf
                                          @xIExodusIx
                                          Short additional information (may useful for others who would like to use Carsten’s modification):
                                          If one already have “MMM-FRITZ-Box-Callmonitor-py3” installed and up-and-running:
                                          In this special case a git pull “git clone https://github.com/xIExodusIx/MMM-FRITZ-Box-Callmonitor-py3.git” will not work - because the target directory $HOME/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor-py3 already exists!
                                          So it is neccessary to put the existing direcotry away.
                                          You can do this simply with “rm -rf MMM-FRITZ-Box-Callmonitor-py3”.
                                          Because I’m a friend of “security” I had decided to simply rename the old directory to keep it for recovering purposes if something bad happens…
                                          “mv MMM-FRITZ-Box-Callmonitor-py3 MMM-FRITZ-Box-Callmonitor-py3.old” will do the trick.
                                          (both commands are valid if you are in the $HOME/MagicMirror/modules directory …)
                                          Regards,
                                          Ralf
                                          X M 2 Replies Last reply
                                          • X
                                            xIExodusIx @rkorell
                                            @rkorell
                                            Hi Ralf,
                                            I’m glad to read this, I thoght it could only work for me.
                                            I will try to do what you said and edit the READ.ME file to put my changes in to it. I’m sadly could not code, what I did was only compare the different versions and merge the differences in a, for me, logical way together, and surprisingly, it worked.
                                            I personally own a FritzBox 7590AX that distinguishes between 4 types of calls, “incomming, outgoing, missed and blocked”. I would like to have the “blocked” calls also been handled and showed up in the module “MMM-FRITZ-Box-Callmonitor-py3” but I don’t know how to do this. I want these blocked calls handled by the module, because I have a large blocklist of callers that I don’t want to get in touch with. They try to cheat me for mony or peronal data. I got up to 15 calls a day of these unwanted calls.
                                            Do you have any Ideas?
                                            Regards
                                            Carsten
                                            • 1 / 4
