    Dakboard layout for family dashboard
    9 Posts 5 Posters 6.5k Views 7 Watching
    • Q Offline
      QuackingPlums
      Sorry for yet another boring family dashboard, but I thought I’d share the progress I’ve made so far with making MMM-CalendarExt3 look like the calendar module in Dakboard.
      I haven’t decided which modules I’ll keep for sure (I was having some compatibility issues between certain combinations) but the other ones you can see here are:
      • Clock (standard)
      • Calendar (standard by invisible)
      • Weather (standard)
      • MMM-AnyList (because we use AnyList for everything)
      • MMM-WiFiPassword (for guests to access the wifi without bothering me)
      • MMM-Remote-Control (for me to issue shutdown request via my phone)
      I’m looking into building the mirror/frame next, as well as the necessary modules to give me a physical safe-shutdown button and any other physical controls that might be needed, depending on how much bloat I build into this device.
      I’d really like to have an alternative to the standard weather module — perhaps to look more like the Dark Skies app or even the old yellow-and-blue Meteo weather app with the graphs, but sadly I’d have to develop my non-existent node.js skills before I could even consider building my own modules.
      S C 2 Replies Last reply Reply Quote 1
        sdetweil @QuackingPlums
        @QuackingPlums see the piratesky provider also a standalone module
        see https://github.com/dankerthrone/MMM-PirateSkyForecast
        • plainbrokeP Offline
          plainbroke @sdetweil
          Does this still function?
          If so is it better than open weather forcast.?
          I should say is it, more accurate. Open weather said we where supposed to get 15 inches of snow last night, maybe got 1.
          I am kind of disappointed in it lately…
          Looking for something better I guess.
            sdetweil @plainbroke
            @plainbroke i dont use weather much, so no idea
              Gotcha. Thanks.
              It actually does still work and it is more accurate than Open Weather is.
                com1cedric @QuackingPlums
                @QuackingPlums hello, nice work ! how did you manage to make your calendar DAK like? Kind regards.
                Q 1 Reply Last reply Reply Quote 0
                • Q Offline
                  QuackingPlums @com1cedric
                  @com1cedric Hi, and thanks!
                  It took me a fair bit of trial and error since I’m not really an FE dev! This is the part of my custom.css that deals with MMM-CalendarExt3:
                  https://codeishot.com/3ukwf76l
                  I’ve only tested it with my specific screen and with the MMM-CalendarExt3 module in the two-week mode that is shown above. Other configs may break it — I notice that if I open the URL in a browser tab on my laptop then the red circle gets squashed, so it’s probably very much dependent on the screen size and possibly even the pixel dimensions.
                  I should come back and take another look at that at some point.
                  I also had to make a tiny tweak in the MMM-CalendarExt3.js file to allow single-character day-of-week initials, because I couldn’t work out how to change that in the config:
                  headerWeekDayOptions: {
                      weekday: "narrow" // ##### EDITED FROM "long" #####
                    @QuackingPlums impressive, thank you! I am currently using calendarExt2 with satisfaction, but I will try calendarExt3 during the spring and test it. Take car and one more time, congrats for your work.
                    • T Offline
                      Tammieda @com1cedric
                      @com1cedric Looks great so far. For the weather module, maybe check out MMM-WeatherChart or MMM-OpenWeatherForecast — they offer more visual options without needing heavy node.js work. Also, adding a physical shutdown button is a smart move for reliability. Keep us posted on the frame build!
