    Mirror Freezing
    14 Posts 4 Posters 3.8k Views 4 Watching
    • plainbrokeP
      plainbroke
      Oh and I can ssh in and run date and the time is correct.
      If I run MM in a separate browser on my laptop I pops up and runs fine and very clean. Time is correct. ect. which then causes the MM on the wall to start working again…
      I did run your update script with force tonight when I came home and it had been frozen for approx. 3.5 hrs.
      I am currently watching to see if it freezes again. so frustrating.
      S F 2 Replies Last reply Reply Quote 1
        sdetweil @plainbroke
        @plainbroke start in server mode and connect chrome or some other browser, sounds like an electron problem
        maybe change the pages rate a little (10%)
          @also to stackoverflow
          https://stackoverflow.com/questions/72876389/how-does-chromium-implement-failifmajorperformancecaveat
          which points to a graphical module, globe, something doing heavy charts.
          • plainbrokeP
            plainbroke @sdetweil
            you are correct electron is hoarding resources.
            Is there a way to kill a PID in debian to see what module may be causing this.
            1998
            1988
            and 1949 are top three cpu hogs…
              @plainbroke you can
              sudo kill -9 pid
              but i dont know what functions are in what process, electron decides that. one is the page/tab
              • plainbrokeP
                Just did a kill 1998 and it is now not showing up but the mirror is still working,
                I guess I will wait until one of the modules doesn’t work anymore.
                Then i will know which one to remove, right?
                Turns out that was the wireless connection I think.
                MM stopped and I can not access it through ssh time to POPO.
                I will keep after this but I will also stop globe in the config.js. just to see if that helps.
                Thanks for your help I have learned alot tonight about the way debian and MM run.
                  @plainbroke i think page switching while globe is drawing
                  is probably the cause
                  • F
                    freelancerakash @plainbroke
                    @plainbroke this is the best Answer
                    • plainbrokeP
                      Not so sure that it was globe came home today and the same screen was stopped,
                      MMM-Dogs and the time was the same 3:37 pm but the real time was 4:30 pm.
                      So re-enabled globe and disabled MMM-Dogs to see if it does it again tomorrow…
                      I am almost wondering if it isn’t something to do with MMM-birthday-paged.
                      It was the last module I remember adding since this started.
                      I will slowly figure it out by disabling one module at a time that seems to hog resources.
                      By the way what do it mean by zombie in top.?
                      top - 16:53:44 up 17 min,  3 users,  load average: 5.34, 5.15, 3.71
                      Tasks: 222 total,   3 running, 218 sleeping,   0 stopped,   1 zombie
                      %Cpu(s): 77.3 us, 12.1 sy,  0.0 ni, 10.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :   7820.9 total,   4021.5 free,   1923.3 used,   2830.4 buff/cache
                      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   5897.6 avail Mem
                      karsten13K S 2 Replies Last reply Reply Quote 0
                      • karsten13K
                        karsten13 @plainbroke
                        @plainbroke
                        see e.g. https://www.baeldung.com/linux/clean-zombie-process
                            @plainbroke i think most often is the parent dies but the child was still running…
                            • plainbrokeP
                              @sdetweil @karsten13
                              Found It
                              ps ux | awk '{if($8=="Z") print}'
                              pi          1170  0.0  0.0      0     0 ?        Z    16:36   0:00 [xsettingsd] <defunct>
                              What is xsettingsd?
                              Should x11 be running with wayland ?
                              Seems like a duplicated background app running or do they not do basically the same thing.?
                              I did kill the 1166 which turned out to be the parent of the 1170 xsettingsd
                              Mirror restarted I assume due to PM2 being involved.
                              It restarted MUCH faster than normal. The MMM-Snow is running smoother.
                              I guess only time will tell.
                              • plainbrokeP plainbroke has marked this topic as solved on
