    Mirror Freezing
    14 Posts 4 Posters 3.7k Views 4 Watching
      @also to stackoverflow
      https://stackoverflow.com/questions/72876389/how-does-chromium-implement-failifmajorperformancecaveat
      which points to a graphical module, globe, something doing heavy charts.
      • plainbrokeP Offline
        plainbroke @sdetweil
        you are correct electron is hoarding resources.
        Is there a way to kill a PID in debian to see what module may be causing this.
        1998
        1988
        and 1949 are top three cpu hogs…
          sdetweil @plainbroke
          @plainbroke you can
          sudo kill -9 pid
          but i dont know what functions are in what process, electron decides that. one is the page/tab
            Just did a kill 1998 and it is now not showing up but the mirror is still working,
            I guess I will wait until one of the modules doesn’t work anymore.
            Then i will know which one to remove, right?
            Turns out that was the wireless connection I think.
            MM stopped and I can not access it through ssh time to POPO.
            I will keep after this but I will also stop globe in the config.js. just to see if that helps.
            Thanks for your help I have learned alot tonight about the way debian and MM run.
              @plainbroke i think page switching while globe is drawing
              is probably the cause
              • F Offline
                freelancerakash @plainbroke
                @plainbroke this is the best Answer
                  Not so sure that it was globe came home today and the same screen was stopped,
                  MMM-Dogs and the time was the same 3:37 pm but the real time was 4:30 pm.
                  So re-enabled globe and disabled MMM-Dogs to see if it does it again tomorrow…
                  I am almost wondering if it isn’t something to do with MMM-birthday-paged.
                  It was the last module I remember adding since this started.
                  I will slowly figure it out by disabling one module at a time that seems to hog resources.
                  By the way what do it mean by zombie in top.?
                  top - 16:53:44 up 17 min,  3 users,  load average: 5.34, 5.15, 3.71
                  Tasks: 222 total,   3 running, 218 sleeping,   0 stopped,   1 zombie
                  %Cpu(s): 77.3 us, 12.1 sy,  0.0 ni, 10.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :   7820.9 total,   4021.5 free,   1923.3 used,   2830.4 buff/cache
                  MiB Swap:    512.0 total,    512.0 free,      0.0 used.   5897.6 avail Mem
                  karsten13K S 2 Replies Last reply Reply Quote 0
                  • karsten13K Offline
                    karsten13 @plainbroke
                    @plainbroke
                    see e.g. https://www.baeldung.com/linux/clean-zombie-process
                        @plainbroke i think most often is the parent dies but the child was still running…
                          @sdetweil @karsten13
                          Found It
                          ps ux | awk '{if($8=="Z") print}'
                          pi          1170  0.0  0.0      0     0 ?        Z    16:36   0:00 [xsettingsd] <defunct>
                          What is xsettingsd?
                          Should x11 be running with wayland ?
                          Seems like a duplicated background app running or do they not do basically the same thing.?
                          I did kill the 1166 which turned out to be the parent of the 1170 xsettingsd
                          Mirror restarted I assume due to PM2 being involved.
                          It restarted MUCH faster than normal. The MMM-Snow is running smoother.
                          I guess only time will tell.
                          • plainbrokeP plainbroke has marked this topic as solved on
