    Mirror Freezing
    14 Posts 4 Posters 3.2k Views 4 Watching
    • plainbrokeP Offline
      plainbroke
      I have updated everything trying to get past this.
      I installed a real time clock.
      Fresh install of Debian 12
      Fresh install of MagicMirror and restore with Sam’s backup/restore script.
      So everything is fresh. I am running this on a NVME ssd stick.
      very fast.
      Ok since i gave you all the background.
      Here is the problem I am having.
      MM will run fine for hours, then all the sudden MM freezes, the time stops and it stays on the page that the time freezes on.
      I have about 40 different modules running and they run great until the freeze up happens.
      Below is the errors I am getting in the pm2 logs.
      0|mm       | [2048:0303/182231.302189:ERROR:gles2_cmd_decoder_passthrough.cc(928)] ContextResult::kFatalFailure: fail_if_major_perf_caveat + swiftshader
      0|mm       | [2048:0303/182231.339696:ERROR:gles2_cmd_decoder_passthrough.cc(928)] ContextResult::kFatalFailure: fail_if_major_perf_caveat + swiftshader
      0|mm       | [2025-03-03 18:22:33.874] [ERROR] We expected a redirect to guce.yahoo.com, but got https://finance.yahoo.com/quote/AAPL/
      0|mm       | [2025-03-03 18:22:33.875] [ERROR] We'll try to continue anyway - you can safely ignore this if the request succeeds
      0|mm       | /home/pi/MagicMirror/node modules/electron/dist/electron exited with signal SIGINT
      0|mm       | [3690:0304/064512.174017:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
      0|mm       | [3690:0304/064512.174366:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
      These repeat over and over for 20 or so times. I didnt count them.
        @plainbroke i think most often is the parent dies but the child was still running…
          plainbroke
          Oh and I can ssh in and run date and the time is correct.
          If I run MM in a separate browser on my laptop I pops up and runs fine and very clean. Time is correct. ect. which then causes the MM on the wall to start working again…
          I did run your update script with force tonight when I came home and it had been frozen for approx. 3.5 hrs.
          I am currently watching to see if it freezes again. so frustrating.
          S F 2 Replies Last reply Reply Quote 1
            sdetweil @plainbroke
            @plainbroke start in server mode and connect chrome or some other browser, sounds like an electron problem
            maybe change the pages rate a little (10%)
              @also to stackoverflow
              https://stackoverflow.com/questions/72876389/how-does-chromium-implement-failifmajorperformancecaveat
              which points to a graphical module, globe, something doing heavy charts.
                plainbroke @sdetweil
                you are correct electron is hoarding resources.
                Is there a way to kill a PID in debian to see what module may be causing this.
                1998
                1988
                and 1949 are top three cpu hogs…
                  @plainbroke you can
                  sudo kill -9 pid
                  but i dont know what functions are in what process, electron decides that. one is the page/tab
                    Just did a kill 1998 and it is now not showing up but the mirror is still working,
                    I guess I will wait until one of the modules doesn’t work anymore.
                    Then i will know which one to remove, right?
                    Turns out that was the wireless connection I think.
                    MM stopped and I can not access it through ssh time to POPO.
                    I will keep after this but I will also stop globe in the config.js. just to see if that helps.
                    Thanks for your help I have learned alot tonight about the way debian and MM run.
                      @plainbroke i think page switching while globe is drawing
                      is probably the cause
                      • F Offline
                        freelancerakash @plainbroke
                        @plainbroke this is the best Answer
                          Not so sure that it was globe came home today and the same screen was stopped,
                          MMM-Dogs and the time was the same 3:37 pm but the real time was 4:30 pm.
                          So re-enabled globe and disabled MMM-Dogs to see if it does it again tomorrow…
                          I am almost wondering if it isn’t something to do with MMM-birthday-paged.
                          It was the last module I remember adding since this started.
                          I will slowly figure it out by disabling one module at a time that seems to hog resources.
                          By the way what do it mean by zombie in top.?
                          top - 16:53:44 up 17 min,  3 users,  load average: 5.34, 5.15, 3.71
                          Tasks: 222 total,   3 running, 218 sleeping,   0 stopped,   1 zombie
                          %Cpu(s): 77.3 us, 12.1 sy,  0.0 ni, 10.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :   7820.9 total,   4021.5 free,   1923.3 used,   2830.4 buff/cache
                          MiB Swap:    512.0 total,    512.0 free,      0.0 used.   5897.6 avail Mem
                          karsten13K S 2 Replies Last reply Reply Quote 0
                          • karsten13K Online
                            karsten13 @plainbroke
                            @plainbroke
                            see e.g. https://www.baeldung.com/linux/clean-zombie-process
                                  @sdetweil @karsten13
                                  Found It
                                  ps ux | awk '{if($8=="Z") print}'
                                  pi          1170  0.0  0.0      0     0 ?        Z    16:36   0:00 [xsettingsd] <defunct>
                                  What is xsettingsd?
                                  Should x11 be running with wayland ?
                                  Seems like a duplicated background app running or do they not do basically the same thing.?
                                  I did kill the 1166 which turned out to be the parent of the 1170 xsettingsd
                                  Mirror restarted I assume due to PM2 being involved.
                                  It restarted MUCH faster than normal. The MMM-Snow is running smoother.
                                  I guess only time will tell.
                                  • plainbrokeP plainbroke has marked this topic as solved on
