    Logging issues
    22 Posts 2 Posters 5.9k Views 2 Watching
    • BKeyportB
      @sdetweil While this is broken up to explain what is sent where, there’s no lines in between other than the diagnostics on the error for “already paused”
      Sent: curl -X GET http://mirrorserv:8080/api/notification/PAGE_CHANGED/0
      [MMM-pages] received a notification to change to page 0 of type string.
      module.js:189 MMM-pages is suspended.
      module.js:189 MMM-CalendarExt3Agenda is suspended.
      module.js:189 MMM-OpenWeatherForecast is suspended.
      module.js:189 MMM-CalendarExt3 is suspended.
      module.js:196 alert is resumed.
      module.js:196 calendar is resumed.
      module.js:196 MMM-Remote-Control is resumed.
      module.js:196 clock is resumed.
      module.js:196 MMM-Worldclock is resumed.
      module.js:196 MMM-Wallpaper is resumed.
      module.js:196 MMM-CalendarExt3 is resumed.
      module.js:196 MMM-CalendarExt3Agenda is resumed.
      module.js:196 MMM-Multimonth is resumed.
      Sent: curl -X GET http://mirrorserv:8080/api/notification/PAUSE_ROTATION/
      MMM-pages.js:311 [MMM-pages] pausing rotation
      Sent: curl -X GET http://mirrorserv:8080/api/notification/PAGE_CHANGED/2
      [MMM-pages] received a notification to change to page 2 of type string.
      3module.js:189 MMM-Multimonth is suspended.
      module.js:196 MMM-OpenWeatherForecast is resumed.
      MMM-pages.js:309 [MMM-pages] was asked to pause but rotation is already paused!
      MMM-pages.js:100 [MMM-pages] received a notification to increment pages!
      etc.
      The diagnostics:
      setRotation	@	MMM-pages.js:309
      notificationReceived	@	MMM-pages.js:123
      sendNotification	@	main.js:99
      sendNotification	@	main.js:649
      sendNotification	@	module.js:350
      socketNotificationReceived	@	MMM-Remote-Control.js:159
      (anonymous)	@	module.js:240
      (anonymous)	@	socketclient.js:32
      Emitter.emit	@	index.js:136
      emitEvent	@	socket.js:553
      onevent	@	socket.js:540
      MMSocket.socket.onevent	@	socketclient.js:26
      onpacket	@	socket.js:508
      (anonymous)	@	manager.js:217
      Promise.then
      (anonymous)	@	globals.js:4
      ondecoded	@	manager.js:216
      add	@	index.js:142
      ondata	@	manager.js:203
      _onPacket	@	socket.js:259
      onPacket	@	transport.js:99
      onData	@	transport.js:91
      ws.onmessage	@	websocket.js:48
        sdetweil @BKeyport
        @BKeyport sent message
        BKeyportB 1 Reply Last reply
        • BKeyportB
          @sdetweil Got message - nothing critical, as usual. and if you have a better way to set page & pause (stop), then later resuming (start) the rotation, I’m all ears.
          For reference, same configuration as before.
            sdetweil @BKeyport
            @BKeyport git pull for update
            I think you can set page (will resume rotation)
            then immediately (or before rotationTime) pauseRotation
            • BKeyportB
              @sdetweil – Pausing is working perfectly, but we moved the bug elsewhere.
              MMM-pages.js:192 [MMM-pages] cannot change to a named page 0'
              updatePages	@	MMM-pages.js:192
              notificationReceived	@	MMM-pages.js:102
              Promise.then
              add	@	index.js:142
                sdetweil @BKeyport
                @BKeyport can you show me the actual request for page 0
                its a number, 0 , not a string “0” or ‘0’
                • BKeyportB
                  @sdetweil it’s through MMM-Remote-Control - the curl statements above is what is sent to trigger.
                    sdetweil @BKeyport
                    @BKeyport ok, will look at what to do
                    • BKeyportB
                      @sdetweil FWIW, it worked before the latest changes, just didn’t pause as requested.
                        sdetweil @BKeyport
                        @BKeyport yes, i know, i sent a notification with a string and it crashed. so i added a check, its NOT supposed to be a string
                        but ive got to figure out how to deal with that
                        • BKeyportB
                          @sdetweil Yeah, I was looking into the code myself.
                          Maybe a re-write to see if it’s a string, then parseint(this.curPage) - and if it’s not NaN, run it?
                          S 2 Replies Last reply
                            sdetweil @BKeyport
                            @BKeyport yeh, but parseInt stops if it sees a non numeric, but doesn’t fail
                            so 1234test returns 1234
                            which is incomplete
                            such was my comment about what to do
                              sdetweil @BKeyport
                              @BKeyport git pull when you have time
                              • BKeyportB
                                @sdetweil OK. It’s now changing pages correctly, but it will resume rotation if pause is already set and you request it again.
                                  sdetweil @BKeyport
                                  @BKeyport did you log that?
                                  doing pause-rotation?
                                    sdetweil @BKeyport
                                    @BKeyport did you changepage? it didn’t set active ,but started, now sets active
                                    new git pull
                                    I put it in manual mode (rotationTime:0,)
                                    and it also works as expected
                                    • BKeyportB
                                      @sdetweil It now is working as expected. Thanks for the help.
                                      • BKeyportB BKeyport has marked this topic as solved on
