    Logging issues
    22 Posts 2 Posters 5.9k Views 2 Watching
      sdetweil @BKeyport
      @BKeyport module doesn’t know its position (or lack thereof)
      it signals updateDom() which calls getDom()
      oops no place to put it. oh well
      hidden pages stop rotation
      IMG_0832.png .
      i think it says that ‘not in the normal rotation’
      pause while paused restarts is a bug i think, will review
      as i just fixed that area too
        @BKeyport i looked thru the code and dont SEE a path where pause while paused restarts, but i will test later tonight
        can you show any part of what you logged?
        BKeyportB 1 Reply Last reply
        • BKeyportB
          @sdetweil While this is broken up to explain what is sent where, there’s no lines in between other than the diagnostics on the error for “already paused”
          Sent: curl -X GET http://mirrorserv:8080/api/notification/PAGE_CHANGED/0
          [MMM-pages] received a notification to change to page 0 of type string.
          module.js:189 MMM-pages is suspended.
          module.js:189 MMM-CalendarExt3Agenda is suspended.
          module.js:189 MMM-OpenWeatherForecast is suspended.
          module.js:189 MMM-CalendarExt3 is suspended.
          module.js:196 alert is resumed.
          module.js:196 calendar is resumed.
          module.js:196 MMM-Remote-Control is resumed.
          module.js:196 clock is resumed.
          module.js:196 MMM-Worldclock is resumed.
          module.js:196 MMM-Wallpaper is resumed.
          module.js:196 MMM-CalendarExt3 is resumed.
          module.js:196 MMM-CalendarExt3Agenda is resumed.
          module.js:196 MMM-Multimonth is resumed.
          Sent: curl -X GET http://mirrorserv:8080/api/notification/PAUSE_ROTATION/
          MMM-pages.js:311 [MMM-pages] pausing rotation
          Sent: curl -X GET http://mirrorserv:8080/api/notification/PAGE_CHANGED/2
          [MMM-pages] received a notification to change to page 2 of type string.
          3module.js:189 MMM-Multimonth is suspended.
          module.js:196 MMM-OpenWeatherForecast is resumed.
          MMM-pages.js:309 [MMM-pages] was asked to pause but rotation is already paused!
          MMM-pages.js:100 [MMM-pages] received a notification to increment pages!
          etc.
          The diagnostics:
          setRotation	@	MMM-pages.js:309
          notificationReceived	@	MMM-pages.js:123
          sendNotification	@	main.js:99
          sendNotification	@	main.js:649
          sendNotification	@	module.js:350
          socketNotificationReceived	@	MMM-Remote-Control.js:159
          (anonymous)	@	module.js:240
          (anonymous)	@	socketclient.js:32
          Emitter.emit	@	index.js:136
          emitEvent	@	socket.js:553
          onevent	@	socket.js:540
          MMSocket.socket.onevent	@	socketclient.js:26
          onpacket	@	socket.js:508
          (anonymous)	@	manager.js:217
          Promise.then
          (anonymous)	@	globals.js:4
          ondecoded	@	manager.js:216
          add	@	index.js:142
          ondata	@	manager.js:203
          _onPacket	@	socket.js:259
          onPacket	@	transport.js:99
          onData	@	transport.js:91
          ws.onmessage	@	websocket.js:48
            sdetweil @BKeyport
            @BKeyport sent message
            • BKeyportB
              @sdetweil Got message - nothing critical, as usual. and if you have a better way to set page & pause (stop), then later resuming (start) the rotation, I’m all ears.
              For reference, same configuration as before.
                sdetweil @BKeyport
                @BKeyport git pull for update
                I think you can set page (will resume rotation)
                then immediately (or before rotationTime) pauseRotation
                • BKeyportB
                  @sdetweil – Pausing is working perfectly, but we moved the bug elsewhere.
                  MMM-pages.js:192 [MMM-pages] cannot change to a named page 0'
                  updatePages	@	MMM-pages.js:192
                  notificationReceived	@	MMM-pages.js:102
                  Promise.then
                  add	@	index.js:142
                    sdetweil @BKeyport
                    @BKeyport can you show me the actual request for page 0
                    its a number, 0 , not a string “0” or ‘0’
                    • BKeyportB
                      @sdetweil it’s through MMM-Remote-Control - the curl statements above is what is sent to trigger.
                        sdetweil @BKeyport
                        @BKeyport ok, will look at what to do
                        • BKeyportB
                          @sdetweil FWIW, it worked before the latest changes, just didn’t pause as requested.
                            sdetweil @BKeyport
                            @BKeyport yes, i know, i sent a notification with a string and it crashed. so i added a check, its NOT supposed to be a string
                            but ive got to figure out how to deal with that
                            • BKeyportB
                              @sdetweil Yeah, I was looking into the code myself.
                              Maybe a re-write to see if it’s a string, then parseint(this.curPage) - and if it’s not NaN, run it?
                              S 2 Replies Last reply
                                sdetweil @BKeyport
                                @BKeyport yeh, but parseInt stops if it sees a non numeric, but doesn’t fail
                                so 1234test returns 1234
                                which is incomplete
                                such was my comment about what to do
                                  sdetweil @BKeyport
                                  @BKeyport git pull when you have time
                                  • BKeyportB
                                    @sdetweil OK. It’s now changing pages correctly, but it will resume rotation if pause is already set and you request it again.
                                      sdetweil @BKeyport
                                      @BKeyport did you log that?
                                      doing pause-rotation?
                                        sdetweil @BKeyport
                                        @BKeyport did you changepage? it didn’t set active ,but started, now sets active
                                        new git pull
                                        I put it in manual mode (rotationTime:0,)
                                        and it also works as expected
                                        • BKeyportB
                                          @sdetweil It now is working as expected. Thanks for the help.
                                          • BKeyportB BKeyport has marked this topic as solved on
