    Logging issues
    22 Posts 2 Posters 5.9k Views 2 Watching
    • BKeyportB
      BKeyport Module Developer
      I’m having trouble with logging issues again - and want to get some feedback on why and how it’s not working -
      Trying to get a module (MMM-pages) to work the way I want it to - and notice in the code that it’s using Log.warn to try and log errors and whatnot.
      I’m launching MM with pm2, in a server/client enviroment.
      PM2 logs show nothing from this module, either on the server or the client.
      my config.js has log level set at logLevel: ["INFO", "LOG", "WARN", "ERROR", "DEBUG"],
      where is this actually logging to?
        sdetweil @BKeyport
        @BKeyport browser side goes to the browser console , which you can see in the developers window, console tab (how i debugged your recent problem)
        pm2 only sees the stdout/stderr consoles (so only from node_helpers log. or console.)
        so to merge them together you would use
        MMM-Logging or MMM-LogExt
        then all the messages are logged in the stdout/err console
        i extended logging, MMRIZE did LogExt
        logLevel decides which messages print
        BKeyportB 1 Reply Last reply
        • BKeyportB
          Ended up loading it up on my PC to get the console.
          So, here’s what I got…
          1. Apparently, MMM-pages will resume the rotation if you tell it to pause, but it’s already paused.
          2. It should be documented that MMM-pages will pause as part of the hidden pages routine.
          While I was looking and debugging
          Out of curiosity, why would calendar try to update the DOM without being given a location to display
            sdetweil @BKeyport
            @BKeyport module doesn’t know its position (or lack thereof)
            it signals updateDom() which calls getDom()
            oops no place to put it. oh well
            hidden pages stop rotation
            IMG_0832.png .
            i think it says that ‘not in the normal rotation’
            pause while paused restarts is a bug i think, will review
            as i just fixed that area too
              @BKeyport i looked thru the code and dont SEE a path where pause while paused restarts, but i will test later tonight
              can you show any part of what you logged?
              • BKeyportB
                @sdetweil While this is broken up to explain what is sent where, there’s no lines in between other than the diagnostics on the error for “already paused”
                Sent: curl -X GET http://mirrorserv:8080/api/notification/PAGE_CHANGED/0
                [MMM-pages] received a notification to change to page 0 of type string.
                module.js:189 MMM-pages is suspended.
                module.js:189 MMM-CalendarExt3Agenda is suspended.
                module.js:189 MMM-OpenWeatherForecast is suspended.
                module.js:189 MMM-CalendarExt3 is suspended.
                module.js:196 alert is resumed.
                module.js:196 calendar is resumed.
                module.js:196 MMM-Remote-Control is resumed.
                module.js:196 clock is resumed.
                module.js:196 MMM-Worldclock is resumed.
                module.js:196 MMM-Wallpaper is resumed.
                module.js:196 MMM-CalendarExt3 is resumed.
                module.js:196 MMM-CalendarExt3Agenda is resumed.
                module.js:196 MMM-Multimonth is resumed.
                Sent: curl -X GET http://mirrorserv:8080/api/notification/PAUSE_ROTATION/
                MMM-pages.js:311 [MMM-pages] pausing rotation
                Sent: curl -X GET http://mirrorserv:8080/api/notification/PAGE_CHANGED/2
                [MMM-pages] received a notification to change to page 2 of type string.
                3module.js:189 MMM-Multimonth is suspended.
                module.js:196 MMM-OpenWeatherForecast is resumed.
                MMM-pages.js:309 [MMM-pages] was asked to pause but rotation is already paused!
                MMM-pages.js:100 [MMM-pages] received a notification to increment pages!
                etc.
                The diagnostics:
                setRotation	@	MMM-pages.js:309
                notificationReceived	@	MMM-pages.js:123
                sendNotification	@	main.js:99
                sendNotification	@	main.js:649
                sendNotification	@	module.js:350
                socketNotificationReceived	@	MMM-Remote-Control.js:159
                (anonymous)	@	module.js:240
                (anonymous)	@	socketclient.js:32
                Emitter.emit	@	index.js:136
                emitEvent	@	socket.js:553
                onevent	@	socket.js:540
                MMSocket.socket.onevent	@	socketclient.js:26
                onpacket	@	socket.js:508
                (anonymous)	@	manager.js:217
                Promise.then
                (anonymous)	@	globals.js:4
                ondecoded	@	manager.js:216
                add	@	index.js:142
                ondata	@	manager.js:203
                _onPacket	@	socket.js:259
                onPacket	@	transport.js:99
                onData	@	transport.js:91
                ws.onmessage	@	websocket.js:48
                  sdetweil @BKeyport
                  @BKeyport sent message
                  • BKeyportB
                    @sdetweil Got message - nothing critical, as usual. and if you have a better way to set page & pause (stop), then later resuming (start) the rotation, I’m all ears.
                    For reference, same configuration as before.
                      sdetweil @BKeyport
                      @BKeyport git pull for update
                      I think you can set page (will resume rotation)
                      then immediately (or before rotationTime) pauseRotation
                      • BKeyportB
                        @sdetweil – Pausing is working perfectly, but we moved the bug elsewhere.
                        MMM-pages.js:192 [MMM-pages] cannot change to a named page 0'
                        updatePages	@	MMM-pages.js:192
                        notificationReceived	@	MMM-pages.js:102
                        Promise.then
                        add	@	index.js:142
                          sdetweil @BKeyport
                          @BKeyport can you show me the actual request for page 0
                          its a number, 0 , not a string “0” or ‘0’
                          • BKeyportB
                            @sdetweil it’s through MMM-Remote-Control - the curl statements above is what is sent to trigger.
                              sdetweil @BKeyport
                              @BKeyport ok, will look at what to do
                              • BKeyportB
                                @sdetweil FWIW, it worked before the latest changes, just didn’t pause as requested.
                                  sdetweil @BKeyport
                                  @BKeyport yes, i know, i sent a notification with a string and it crashed. so i added a check, its NOT supposed to be a string
                                  but ive got to figure out how to deal with that
                                  • BKeyportB
                                    @sdetweil Yeah, I was looking into the code myself.
                                    Maybe a re-write to see if it’s a string, then parseint(this.curPage) - and if it’s not NaN, run it?
                                    S 2 Replies Last reply
                                      sdetweil @BKeyport
                                      @BKeyport yeh, but parseInt stops if it sees a non numeric, but doesn’t fail
                                      so 1234test returns 1234
                                      which is incomplete
                                      such was my comment about what to do
                                        sdetweil @BKeyport
                                        @BKeyport git pull when you have time
                                        • BKeyportB
                                          @sdetweil OK. It’s now changing pages correctly, but it will resume rotation if pause is already set and you request it again.
                                            sdetweil @BKeyport
                                            @BKeyport did you log that?
                                            doing pause-rotation?
