    Fresh install on bookworm only works with X11 - which disables VNC...
    11 Posts 2 Posters 2.4k Views 2 Watching
      rkorell Module Developer
      Hi Team,
      may somebody has a hint for me.
      I’ve just installed with Sam’s script a complete fresh instance of MagicMirror.
      Installation went without any error.
      Starting up the mirror gave an error - the startup is called with x11! - for whatever reason.
      So I changed with raspi-config wayland to X11 (which I do not want) - mirror starts, all is OK.
      The connected HDMI TV is really dark (!) (Webrowser is correctly white on black, shiny) AND: after several minutes screen turns OFF.
      (BASE config file, only adapted whitelist and localization, standard template modules displayed)
      Second issue - with X11 Windows manager enabled I’m not able to connect to the mirror via VNC which I really like and am used to do because it is much faster that the browser and the mouse pointer doesn’t disappear.
      Any hints for me?
      Thanks a lot!
      Regards,
      Ralf
        rkorell Module Developer @rkorell
        @rkorell What i figured out as well is:
        VNC viewer in this combination cannot work…
        So the right way to handle this is:
        DISable VNC service in raspi-config (this is the wayland VNC) and ENable the X11 Real VNC server manually with
        sudo systemctl enable --now vncserver-x11-serviced
        Reboot Pi and VNC works again.
        So I now stick with the dark display …
        Thanks & warm regards,
        Ralf
        R S 2 Replies Last reply Reply Quote 0
          sdetweil @rkorell
          @rkorell use the other start commands,
          message posted and pinned in january in general section
            @sdetweil :-)
            OK good move…
            But the startup-command is generated by your install-script, so this is the result of the “auto-start”…
            In the meantime I’ve figured out that may X11 is - in priciple - may the better choice for me because I might remember that MMM-Pir ( :-) ) had issues with wayland in context of screen-off …
              Ralf
                @rkorell Screen switching Off is now disappeared without any reason - did not change anything…
                Screen darkness still there but may an issue with the modules I never used and this greyish is “normal” …
                • R rkorell has marked this topic as solved on
                  sdetweil @rkorell
                  @rkorell i do not know how you disable screen blanking via script w labwc
                    sdetweil @rkorell
                    @rkorell i will fix installer now that new start commands available
                      @sdetweil :-)
                      For me it’s currently fine!
                      All is working and wayland is not needed THAT much :-)
                        sdetweil @rkorell
                        @rkorell if you switched to x11 my screensaveroff script will work
                          @sdetweil cool - but had switched to X11 after installation.
                          But screensaver IS switched off (it seems to me that screensaver is switched off per default - never seen a screenserver on my pis …
                            sdetweil @rkorell
                            @rkorell i think it is ON by default , but will retest when i can
