    Fresh install on bookworm only works with X11 - which disables VNC...
    11 Posts 2 Posters 2.0k Views 2 Watching
      rkorell @rkorell
      @rkorell What i figured out as well is:
      VNC viewer in this combination cannot work…
      So the right way to handle this is:
      DISable VNC service in raspi-config (this is the wayland VNC) and ENable the X11 Real VNC server manually with
      sudo systemctl enable --now vncserver-x11-serviced
      Reboot Pi and VNC works again.
      So I now stick with the dark display …
      Thanks & warm regards,
      Ralf
      R S 2 Replies Last reply Reply Quote 0
        rkorell @rkorell
        @rkorell Screen switching Off is now disappeared without any reason - did not change anything…
        Screen darkness still there but may an issue with the modules I never used and this greyish is “normal” …
        • R rkorell has marked this topic as solved on
          sdetweil @rkorell
          @rkorell i do not know how you disable screen blanking via script w labwc
            sdetweil @rkorell
            @rkorell i will fix installer now that new start commands available
              rkorell @sdetweil
              @sdetweil :-)
              For me it’s currently fine!
              All is working and wayland is not needed THAT much :-)
                sdetweil @rkorell
                @rkorell if you switched to x11 my screensaveroff script will work
                  rkorell @sdetweil
                  @sdetweil cool - but had switched to X11 after installation.
                  But screensaver IS switched off (it seems to me that screensaver is switched off per default - never seen a screenserver on my pis …
                    sdetweil @rkorell
                    @rkorell i think it is ON by default , but will retest when i can
