    Bugsounet and MMM-Pir
    68 Posts 10 Posters 32.3k Views 11 Watching
    • L Offline
      lif @sdetweil
      @sdetweil said in Bugsounet and MMM-Pir:
      @lif can you talk about this python after …
      MagicMirror upgrades? if so , did you use my upgrade script?
      this highlights a problem. some modules need a refresh install when nodejs and MagicMirror change
      so the upgrade script does that. but that wipes the node_modules folder for the module. and the dependencies are also not available anymore.
      so, if i DO try the npm install it breaks, if i dont try the npm install it might break. fun times.
      i will add a check for the authors url and skip the install action
      I was trying to upgrade Nodejs and if failed with lots of errors.
      my mm and the whole system had got messy, so I’m using this as an opportunity to clean things up (it didn’t help insofar as a restore from the most recent backup didn’t work.
        sdetweil @rkorell
        @rkorell said in Bugsounet and MMM-Pir:
        So I have to stay with the old mirror version to keep module running?
        i do not know…
        I do not understand these dependencies
        rather than put all the code in the module, there are libraries of things
        that can be called…
        so you make those libraries as separate packages and list them in the dependencies section of package.json and npm install goes and gets them
        he might have decided that multiple components needs the same functions and packaged as library, to be loaded by all that needed it, code once, ship multiple times…
        except that breaks now as the dependencies also are no longer available
        as I said in my initial warning post, plan for them all to fail to work
          sdetweil @lif
          @lif yeh, my upgrade script does the nodejs upgrade too…
          use the n command
          sudo npm install n -g
          sudo n xxx
          where xxx is the version you want to use
          how backup? use my backup/restore
          yes that is broken too, as the authors repos no longer exist and binary backup may not work on different OS level/nodejs level
          L 2 Replies Last reply Reply Quote 0
          • L Offline
            lif @sdetweil
            IMG file on my (new) linux desktop
            • L Offline
              lif @sdetweil
              use the n command
              sudo n xxx
              Thanks, added to my install notes
                sdetweil @lif
                @lif n is the nodejs version of nvm
                  yes - as stated -really unfortunate!
                  Thanks for your clarification!
                  Ralf
                  • L Offline
                    lif @sdetweil
                    I’ve reinstalled MagicMirror with your script, it worked wonderfully, than you very much for doing this.
                    Best regards from France.
                      rkorell Module Developer @rkorell
                      @sdetweil @lif
                      For your information:
                      I was successful with installing MMM-Pir on my brand new Pi5/bookworm:
                      pi@MagicMirrorPi5:~ $ cd MagicMirror/modules
                      pi@MagicMirrorPi5:~/MagicMirror/modules $ tar -xf MMM-Pir.tar.gz
                      pi@MagicMirrorPi5:~/MagicMirror/modules $ cd MMM-Pir/
                      pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-Pir $ npm install
                      > MMM-Pir@2.4.4 preinstall
                      > echo ⚠ npm install will be deprecated on next release!.
                      > MMM-Pir@2.4.4 install
                      > npm run setup
                      > MMM-Pir@2.4.4 presetup
                      > npm run dependencies && installer/preinstall.sh
                      > MMM-Pir@2.4.4 dependencies
                      > installer/dependencies.sh -d 'unclutter ddcutil cec-utils python3 python-is-python3 python3-gpiozero gpiod libgpiod2 libgpiod-dev'
                      Welcome to MMM-Pir v2.4.4
                      ① ➤ dependencies installer
                      Checking OS...
                      OS Detected: linux-gnu (debian 12 aarch64)
                      Checking all dependencies...
                      All Dependencies needed are installed !
                      ② ➤ Preinstall
                      No root checking...
                      Checking MMM-Pir: pi/pi
                      Checking MagicMirror: pi/pi
                      Installing @sdetweil sandbox fix...
                      fixing sandbox permissions
                      ③ ➤ Install npm dependencies
                      > MMM-Pir@2.4.4 setup
                      > npm prune
                      up to date in 990ms
                      124 packages are looking for funding
                        run `npm fund` for details
                      > MMM-Pir@2.4.4 postsetup
                      > installer/postinstall.sh -m -r
                      ④ ➤ Postinstall
                      Minify Main code...
                      Found: 10 files to install and minify
                      Process File: MMM-Pir/MMM-Pir.js
                      Process File: MMM-Pir/node_helper.js
                      Process File: MMM-Pir/components/cronJob.js
                      Process File: MMM-Pir/components/governorLib.js
                      Process File: MMM-Pir/components/motion.js
                      Process File: MMM-Pir/components/motionLib.js
                      Process File: MMM-Pir/components/pirLib.js
                      Process File: MMM-Pir/components/screenDisplayer.js
                      Process File: MMM-Pir/components/screenLib.js
                      Process File: MMM-Pir/components/screenTouch.js
                      Done
                      Try to Disable screen saver...
                      Found: screen saver in gsettings
                      disable screensaver via gsettings was true and uint32 300
                      Found: screen saver in lightdm
                      disable screensaver via lightdm.conf
                      Found: screen saver in lxsession
                      disable screensaver via lxsession
                      Found: wayfire.ini
                      [WARN] There is some change for disable screen saver
                      [WARN] Please, don't forget to reboot your OS for apply the new configuration!
                      Done
                      Rebuild MagicMirror...
                      ✔ Rebuild Complete
                      Done
                      MMM-Pir is now installed !
                      > MMM-Pir@2.4.4 postinstall
                      > echo ⚠ On next release, Please use: npm run setup
                      added 1 package in 31s
                      I will have to play with the screen options (caused for sure by bookworm) because right now I get an error notification from MMM-Pir (screen error detected: dpms command error(mode 1) ) but there are several other modes to try …
                      Regards,
                      Ralf
                        sdetweil @rkorell
                        @rkorell yeh, fun times
                          @sdetweil yes! :-)
                          • F Offline
                            FrostByte Module Developer
                            Hi everyone,
                            I didn’t quite get it right. Are there still problems with MMM-Pir?
                            I see that there are already two pull requests on https://github.com/Coernel82/MMM-Pir/pulls (one is from me). I would be willing to maintain the module, if no one else does.
                            Happy to hear from you @coernel
                              rkorell Module Developer @FrostByte
                              @FrostByte .
                              Yes there are still “problems”.
                              @coernel has prepared a re-upload of bugsounet’s MMM-Pir.
                              But for some reasons this has failed.
                              Several entities are missing in his upload (including e.g. the core MMM-Pi.js and several other linked and necessary sub-programs (Described in more detail in this post).
                              I’ve copied a tar.gz file of my own local repository-copy here.
                              This copy is installable with npm install in the respective MMM-Pir directory in mirror Version 2.30 (NOT tested in brand new 2.31!).
                              It works without problems on a Pi4 with bullseye.
                              It does NOT work on a Raspi5/bookworm “out of the box”.
                              In the meantime I’ve identified and corrected the root cause for this (wrong parameter for the xrandr-call).
                              This correction is NOT reflected in the URL above because I’ve done this correction after the upload.
                              I can share this with you if you are interested in - only a very minor adoption and only for MY use-case (working without wayland and with x11).
                              From my side it would be really highly appreciated if somebody can take the responsibility for maintenance of this pretty module because I really like it very much.
                              I definitely NOT able to do this but I’m definitely willing to give any additional support in the course of my (tiny) abilities…
                              Let me know what you’re thinking about.
                              Warm regards,
                              Ralf
                              • F Offline
                                FrostByte Module Developer @rkorell
                                Okay, let’s go into detail. @rkorell
                                As already written by @sdetweil , the node_modules directory is created when npm run setup (or npm install as it should be called).
                                In addition, the ‘missing files’ are also created dynamically when this command is called. See:
                                lukas@smartmirror:~/MagicMirror/modules$ git clone https://github.com/Coernel82/MMM-Pir.git MMM-Pir-test
                                lukas@smartmirror:~/MagicMirror/modules$ cd MMM-Pir-test
                                lukas@smartmirror:~/MagicMirror/modules/MMM-Pir-test$ npm run setup
                                lukas@smartmirror:~/MagicMirror/modules/MMM-Pir-test$ ls -al components/
                                total 68
                                drwxr-xr-x  2 lukas lukas  4096 Apr  1 19:06 .
                                drwxr-xr-x 10 lukas lukas  4096 Apr  1 19:53 ..
                                -rw-r--r--  1 lukas lukas  4101 Apr  2 11:23 cronJob.js
                                -rw-r--r--  1 lukas lukas  2241 Apr  2 11:23 governorLib.js
                                -rw-r--r--  1 lukas lukas  3894 Apr  2 11:23 motion.js
                                -rw-r--r--  1 lukas lukas  1563 Apr  2 11:23 motionLib.js
                                -rw-r--r--  1 lukas lukas   757 Mar  3 19:09 MotionSensor.py
                                -rw-r--r--  1 lukas lukas  3755 Apr  2 11:23 pirLib.js
                                -rw-r--r--  1 lukas lukas  6068 Apr  2 11:23 screenDisplayer.js
                                -rw-r--r--  1 lukas lukas 19159 Apr  2 11:23 screenLib.js
                                -rw-r--r--  1 lukas lukas  1763 Apr  2 11:23 screenTouch.js
                                I use Wayland/labwc (Debian GNU/Linux 12 bookworm) on aarch64 Raspberry Pi 3B and everything is working for my Pir configuration. I did not use your copy.
                                So i am asking again, are there some runtime errrors? So please send me errrors logs.
                                The ‘build’ step in package.json is really very confusing. That’s why I’ve started to organise it: https://github.com/Coernel82/MMM-Pir/compare/main...LukasWestholt:MMM-Pir:main#diff-7ae45ad102eab3b6d7e7896acd08c427a9b25b346470d7bc6507b6481575d519
                                Best regards,
                                Lukas
                                • F Offline
                                  FrostByte Module Developer @lif
                                  @lif So in my experience, your error just means that you didn’t run ‘npm run setup’!
                                    @FrostByte said in Bugsounet and MMM-Pir:
                                    This one I’ve missed or was to blonde, to see …
                                    If the install is creating necessary files all “should” be fine.
                                    Despite the fact that in the original screenLib.js is an error (for x11 - regarding handling because the calls are slightly different as coded).
                                    Wayland does not work properly with MagicMirror on my Pi5 - so I’ve switched back to x11, found the above error and corrected this.
                                    Not sure how to handle this in “release” and your maintenance of module.
                                    What have I done?
                                    See here:
                                    This is line 311 (of screenLib.js ):
                                           exec("DISPLAY=:0 xrandr | grep 'connected primary'", //--rkorell
                                            // original : exec("xrandr | grep 'connected primary'",
                                    this is line 489 (of screenLib.js ):
                                            // original exec(`xrandr --output ${this.screen.hdmiPort} --auto --rotate ${this.screen.xrandrRotation}`, (err) => {
                                              exec(`xrandr --output ${this.screen.hdmiPort} --primary --mode 2560x1440 --rate 59.951 --pos 0x0  --rotate ${this.screen.xrandrRotation}`, (err) => {
                                    especially the second one was disturbing because the statement simply doesn’t work - this option “auto” is something one can find everywhere referenced but it never worked as far as I have tried to research. from own experience (see above) it don’t work. I guess “–auto” should recover the current settings -but it doesn’t (on bookworm!) . Hard coded screen resolution is definitely no candidate for broader distribution …
                                    (First one “only” produces an error message)
                                    These are my findings.
                                    I’ve mistakenly (not aware of the “dynamically created” libraries/dependant modules) linked the problems of the thread owner with the missing libraries in HIS installation to the likewise missing modules in git clone…
                                    Sorry for confusion!
                                    Ralf
                                    • F Offline
                                      @rkorell Thanks for your answer! That makes total sense. Thanks for reporting your experience. I’ll keep that in mind.
                                      With Wayland it took me tens of hours to rotate the display by 90 degrees via autostart and I often thought about migrating to X11 back. But in the end it worked.
                                      • L Offline
                                        lif @FrostByte
                                        @FrostByte
                                        I don’t know if it helps but the only way I could get my old DVI input monitor to turn on & off was with Wayland enabled and the commands
                                        DISPLAY=:0.0 xrandr --output HDMI-1 --auto --rotate left
                                        and
                                        DISPLAY=:0.0 xrandr --output HDMI-1 --off
                                        Nick
                                          sdetweil @lif
                                          @lif with wayland enable it should be wl_randr
                                          xrandr is for x11
                                          • G Offline
                                            gullymat
                                            hi, i just want to drop this here.
                                            my magic mirror is running on a zero2 but very laggy, needs like 10 sec to activate the screen form the pir, often startup failures and so on.
                                            i was about to move to a bigger raspi and tried to migrate my installation from the zero2 to a pi3.
                                            unfortunatelly did not got MMM-Pir running.
                                            so i switched over to MMM-Universal-Pir and everything is running so much smoother.
                                            no need to replace the zero2 anymore :)
                                            R F 2 Replies Last reply Reply Quote 2
                                            • 3 / 4
