    MMM-CalendarExt3Agenda - Two questions
    19 Posts 3 Posters 5.4k Views 3 Watching
    • K Offline
      Kelemvor @Kelemvor
      There’s already this in the CSS that makes the passed events Gray:
      .CX3A .event.passed {
      filter: brightness(0.6) grayscale(0.33);
      But, there must be something else that removes them completely when it updates so they don’t show at all.
      • BKeyportB Offline
        BKeyport Module Developer @Kelemvor
        As for the #1 question, look at these config items:
        startDayIndex
        endDayIndex
        That will adjust your view to specific days - startDayIndex: 0 will set it to start on the current day, and then continue for the number of days listed in endDayIndex
        • K Offline
          Kelemvor @BKeyport
          @BKeyport said in MMM-CalendarExt3Agenda - Two questions:
          startDayIndex
          endDayIndex
          Those are already set correctly. There’s something hard coded somewhere that removes events that are in the past from showing, even if they’re from Today. If those settings were wrong I wouldn’t see anything from today.
          K BKeyportB 2 Replies Last reply Reply Quote 0
          • K Offline
            Kelemvor @Kelemvor
            Maybe something in this section if I’m deciphering things correctly…
            • BKeyportB Offline
              @Kelemvor do you have broadcastPastEvents: true, set in the default calendar app?
              • BKeyportB Offline
                @Kelemvor Actually, I think you might be right - does look hardcoded.
                • K Offline
                  Kelemvor @BKeyport
                  Not if that goes in the normal Config area. Does that make ALL events from the entire calendar get passed over to Ext3? Is that going to overload anything since it’s decades of events? :)
                  • BKeyportB Offline
                    @Kelemvor It won’t overload anything. broadcastPastEvents is required to show old events.
                    • K Offline
                      Kelemvor @BKeyport
                      @BKeyport I know it says its broadcasting 400+ events so I’m assuming it’s sending old stuff.
                      BKeyportB K 2 Replies Last reply Reply Quote 0
                      • BKeyportB Offline
                        @Kelemvor I pretty much bet it’s that setting - with it I get what you want:
                        • K Offline
                          Kelemvor @Kelemvor
                          I think I fixed it and I Just found a typo in the official documentation:
                          On this page:
                          https://docs.magicmirror.builders/modules/calendar.html#configuration-options
                          The first instance of broadcastPastEvents is wrong.
                          It should say pastDaysCount, not maximumNumberofDays,
                          Anyway, I set broadcastPastEvents to True and PastDaysCount to 1. It seems to be showing now. I’ll know more tomorrow afternoon.
                          • BKeyportB Offline
                            oh, and you can specify past events per calendar:
                            • BKeyportB Offline
                              @Kelemvor I wouldn’t know the details on that part of the thing - I let my calendar spew the entire of the data download - it don’t hurt a thing.
                              • K Offline
                                Kelemvor @BKeyport
                                @BKeyport Oh sheesh. After my change it’s now showing the entire mini calendar with all the events on it. It wasn’t like that before so it’s definitely sending things it wasn’t. I have the PastDays thing set to 1, in the base calendar but EXT3 calendar is showing events for all of March so that flag doesn’t seem to work right or something.
                                  sdetweil @Kelemvor
                                  @Kelemvor pastDaysCount is an advisory to other modules. they dont have to honor it
                                  we send all the events, there was a bug in clipping, i ‘fixed’ for 2.30, but made it worse. the temp fix removes clipping on past events
                                  maximum days sets the range to view in cal, default 365 days
