    i need help w pi imager and ssh, headless, oops, user error
    15 Posts 3 Posters 2.7k Views 3 Watching
      rkorell @sdetweil
      @sdetweil said
      I am not a system setup guy.
      Dear Sam,
      you may aware of this - than please ignore it…
      You’ve described that you have put a SD card in your NVME-HAT’ed Pi and your Pi has not booted from SD but from NVME…
      You can steer this with the BOOT_ORDER entry in eeprom configuration.
      This code is read right to left to determine the boot order and should (in your case) be: 0xf461:
      1 = Check SD card
      6 = Check PCIe NVME
      4 = Check USB drive
      f = Start again
      You can check this:
      sudo rpi-eeprom-config
      If boot order is not as desired you can edit this with
      sudo -E rpi-eeprom-config --edit
      enter or modify to:
      BOOT_ORDER=0xf461
      (In my configuration this opens the nano editor in which ctrl-O writes the changes to disk and ctrl-X leaves the editor.
      eeprom-config then modifies the system and a reboot is neccessary)
      With this configuration you will lose a tiny bit of time for the SD-card check but it enables you to insert a SD card and boot from there despite the NVME is connected as well.
      Regards,
      Ralf
        sdetweil @rkorell
        @rkorell thanks. i had clearly set the boot order wrong.
          rkorell @sdetweil
          @sdetweil This is a single error :-)
          try to count mine - you will win ! :-)
            sdetweil @rkorell
            @rkorell this is not a contest. if we all work together things will always improve
              rkorell @sdetweil
              @sdetweil you’re absolutely true!
              • just kidding !
              Ralf
                sdetweil @rkorell
                @rkorell i knew you were teasing me. thank you for that!
