    v2.31.0
    Scheduled Pinned Locked Moved MagicMirror
    1 Posts 1 Posters 2.1k Views 1 Watching
    • rejasR
      rejas Module Developer
      [2.31.0] - 2025-04-01
      Thanks to: @Developer-Incoming, @eltociear, @geraki, @khassel, @KristjanESPERANTO, @MagMar94, @mixasgr, @n8many, @OWL4C, @rejas, @savvadam, @sdetweil.
      ⚠️ This release needs nodejs version v22.14.0 or higher
      Added
      • Add CSS support to the digital clock hour/minute/second through the use of the classes clock-hour-digital, clock-minute-digital, and clock-second-digital.
      • Add Arabic (#3719) and Esperanto translation.
      • Mark option secondsColor as deprecated in clock module.
      • Add Greek translation to Alerts module.
      • [newsfeed] Add specific ignoreOlderThan value (override) per feed (#3360)
      • [weather] Added option Humidity to hourly View
      • [weather] Added option to hide hourly entries that are Zero, hiding the entire column if empty.
      • [updatenotification] Added option to iterate over modules directory instead using modules defined in config.js (#3739)
      Changed
      • [core] starting clientonly now checks for needed env var WAYLAND_DISPLAY or DISPLAY and starts electron with needed parameters (if both are set wayland is used) (#3677)
      • [core] Optimize systeminformation calls and output (#3689)
      • [core] Add issue templates for feature requests and bug reports (#3695)
      • [core] Adapt start:x11:dev script
      • [weather/yr] The Yr weather provider now enforces a minimum updateInterval of 600 000 ms (10 minutes) to comply with the terms of service. If a lower value is set, it will be automatically increased to this minimum.
      • [weather/weatherflow] Fixed icons and added hourly support as well as UV, precipitation, and location name support.
      • [workflow] Run sudo apt-get update before installing packages to avoid install errors
      • [workflow] Exclude issues with label ready (coming with next release) from stale job
      Removed
      Updated
      • [core] Update requirements and dependencies including electron to v35 and formatting (#3593, #3693, #3717)
      • [core] Update prettier, ESLint and simplify config
      • Update Greek translation
      Fixed
      • [calendar] Fix clipping events being broadcast (#3678)
      • [tests] Fix Electron tests by running them under new github image ubuntu-24.04, replace xserver with labwc, running under xserver and labwc depending on env variable WAYLAND_DISPLAY is set (#3676)
      • [calendar] Fix arrayed symbols, #3267, again, add testcase, add testcase for #3678
      • [weather] Fix wrong weatherCondition name in openmeteo provider which lead to n/a icon (#3691)
      • [core] Fix wrong port in log message when starting server only (#3696)
      • [calendar] Fix NewYork event processed on system in Central timezone shows wrong time #3701
      • [weather/yr] The Yr weather provider is now able to recover from bad API responses instead of freezing (#3296)
      • [compliments] Fix evening events being shown during the day (#3727)
      • [weather] Fixed minor spacing issues when using UV Index in Hourly
      • [workflow] Fix command to run spellcheck
      https://github.com/MagicMirrorOrg/MagicMirror/releases/tag/v2.31.0
      Reply Quote 3
      • rejasR rejas locked this topic on
