    Default calendar customEvents not working
    22 Posts 2 Posters 5.0k Views 2 Watching
      pauabaer
      Hi guys,
      I installed the newest mm version via GitHub.
      I have tested a lot within the calendar module. My iCal-calendar is shown, but the default calendar module does not work with any customEvents entries.
                              header: "Familienkalender",
                                              url: "my-url“,
                                              symbolClass: "fas fa-fw fa-",
                                              customEvents: [
                                                              keyword: "Geburtstag",
                                                              symbol: "fire"
      Can you help me to fix it? I want change the symbols first and afterwards adding some regex-entries.
      Did I miss something?
      Thanks for your help.
      Best regards
      Pauabaer
        sdetweil @pauabaer
        @pauabaer customEvents do not go IN the calendar definition
        rather like this
                                                customEvents: [
        symbol: "fire"
                                                             url: "my-url“,
        the calendar module documentation is organized into sections
        1. applies to all calendar definitions (refresh rate, maximumDays…etc)
        2. applies to A calendar definition (color, symbol, url)
          pauabaer
          Thank you a lot @sdetweil
          Now the right symbol is shown on my screen.
          Next I tried to use the transform option:
                                          config:{
                                                  customEvents: [
                                                          symbol: "birthday-cake",
                                                          transform: {
        search: "^(.+) (\\d{4}) Geburtstag$",
        replace: "$1 ($2)",
        yearmatchgroup: 2
                                                          url: "my-url“,
          But when I refresh the browser whithin the Kalender „Familienkalender“ is no entry anymore but the word „loading…“ but nothing new is shown after a while.
          What could this circumstance cause?
            sdetweil @pauabaer
            @pauabaer that means there was an error
            open the developers window
            ctrl-shift-i
            select the console tab
            put cal in the filter field
            and you may see the error , I changed to match one of my cal event titles
            but the regex doesn’t work…
              pauabaer @sdetweil
              Thanks for helping.
              I tried to figure out. Went to the console tab and put the filter on cal.
              I get an error your yearmatch is that right? But I don’t know how to deal with it. Can you give me a hint?
                sdetweil @pauabaer
                @pauabaer its a regular expression to extract the parts of the date,
                i would use the developers window sources tab to locate that code in the calendar module and examine the data it is working with
                i might get a chance later today
                  sdetweil @pauabaer
                  @pauabaer could you add
                  ,"DEBUG"
                  to the config.js logLevel property
                  as well as your transform
                  and run MM with (stop pm2 version , with pm2 stop MagicMirror)
                  npm start >somefile.txt 2>&1
                  so we can see the actual text of the event
                  (watch out, the log output contains the COMPLETE text of the calendar url)
                  I only need the text of the event… (it supposedly has the date in it)
                    pauabaer @sdetweil
                    Finally I got some time to test. See the pic below:
                    I got the message that there is one entry but no title is shown. Did I do something wrong?
                      sdetweil @pauabaer
                      @pauabaer you didn’t add the debug setting to config.js
                      the transform happens in the front end, the backend (node_helper) gets the events from source and formats them for frontend.tye log you showed is from the backend
                        pauabaer @sdetweil
                        I did add the debug setting but presumably at the wrong position.
                        Thought I should add it here:
                                           config:{
                                                  loglevel: ["DEBUG"],
        customEvents: [
        transform: {
        search: "^([^\']*) \'(\\d{4})$",
        replace: "$1 ($2)",
        yearmatchgroup: 2
                          sdetweil @pauabaer
                          @pauabaer logevel is above the modules list
                          its not a module setting
                            pauabaer @sdetweil
                            Meanwhile I found the right place. Sorry for this.
                            In the pic below you can see the entry.
                            Does help you?
                              your search regex is wrong,
                              its captures EVERYTHING from the start… and there is nothing left for the remainder of the expression
                              you need to capture any character UP to the 1st space,
                              ^([^\s]+) (\d{4}) Gerburstag$
                              I use https://regex101.com/ to test (see below)
                              escape the backslash as required
                                pauabaer @sdetweil
                                Ok. Within the regex101 there is no mistake. But when I change within the config nothing happens again.
                                  sdetweil @pauabaer
                                  @pauabaer you needed to escape the \ with another backslash
                                  in the string… its a javascript thing
                                  as I noted in my prior post
                                  also remove the leading /
                                    pauabaer @sdetweil
                                    I did. But…
                                    I got the feeling i am not far away from the solution. Have still patient to bring me to that point? :)
                                    S P 2 Replies Last reply Reply Quote 0
                                      sdetweil @pauabaer
                                      @pauabaer do you still see the same error in the dev console?
                                        pauabaer @pauabaer
                                          pauabaer @pauabaer
                                          It’s not the error I saw before.
                                            sdetweil @pauabaer
                                            @pauabaer ok, i am at grandson baseball for a while
