    [MMM-PIR-Sensor] Install failing
    75 Posts 19 Posters 118.6k Views 18 Watching
    • K
      kerijn
      @yawns Thank you very much for your help but infortunately this didn’t work. I now cannot start Magicmirror anymore even without the MMM-PIR-Sensor module… See error below. I also got the same warning as @fox with missing grunt@…
      pi@MyPi:~/MagicMirror $ npm start
      > magicmirror@2.1.0 start /home/pi/MagicMirror
      > electron js/electron.js
      npm ERR! Linux 4.4.43-v7+
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
      npm ERR! node v6.9.4
      npm ERR! npm  v3.10.10
      npm ERR! code ELIFECYCLE
      npm ERR! magicmirror@2.1.0 start: `electron js/electron.js`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.1.0 start script 'electron js/electron.js'.
      npm ERR! If you do, this is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR!     electron js/electron.js
      npm ERR!     npm bugs magicmirror
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls magicmirror
      npm ERR!     /home/pi/MagicMirror/npm-debug.log
      • K
        kerijn
        I now did a full new installation of MagicMirror with the defauls config.js and got the same error.
        npm ERR!
        • F
          fox
          @kerijn perhaps @paviro can help us here. It seems to be a general problem.
          Issues With MMM-WatchDog known?
          https://forum.magicmirror.builders/post/29827
          Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
            Jopyth Moderator @kerijn
            @kerijn @fox I think I fixed this issue before, it comes from the changes the Magic Mirror version 2.1.0 introduced. I am not sure, but I think the changes neccessary are almost as simple as here. Will have to test this at home though. Maybe there was something else needed.
            F K 2 Replies Last reply Reply Quote 2
            • F
              fox @Jopyth
              @Jopyth said in MMM-PIR-Sensor Install failing:
              Thank you. That fixes the problem for me ! :)
              • K
                kerijn @Jopyth
                @Jopyth This worked for me for the installation as well. Thank you! However, the sensor does not seem to do anything. How can I check whether the sensor is working properly?
                  Makradon @kerijn
                  @kerijn said in [MMM-PIR-Sensor] Install failing:
                  I have the same problem
                    Jopyth Moderator @Makradon
                    @Makradon @kerijn I found this. I think you could save this as test.py somewhere on your Pi and see if the output changes when you move and don’t move (set the pin number in the second line) after your start it with python test.py:
                    import RPi.GPIO as GPIO
                    pin = 11
                    GPIO.setwarnings(False)
                    GPIO.setmode(GPIO.BOARD)
                    GPIO.setup(pin, GPIO.IN)         #Read output from PIR motion sensor
                    while True:
                           i=GPIO.input(pin)
                           if i==0:                 #When output from motion sensor is LOW
                                 print "No intruders",i
                                 time.sleep(0.1)
                           elif i==1:               #When output from motion sensor is HIGH
                                 print "Intruder detected",i
                                 time.sleep(0.1)
                    • T
                      thoimi @Jopyth
                      @Jopyth I had the same problem.
                      Your work-around (installation) worked for me but the sensor does not seem to do anything…
                      the test.py script shows me always “1” - also when nothing is moving in the room…
                        Jopyth Moderator @thoimi
                        @thoimi Check for the correct wiring (PIN-Numbers can be confusing, there is the BCM numbering and the other one), also make sure GND and 5V are conncted correctly, adjust sensitivity to maximum and time to minimum (so it hopefully switch back and forth quickly), try covering up the sensor under a bowl or something and then put your hand in to test.
                        When I set up the sensor, I also searched for the error for hours, and at the end my problem was the sensor was plugged into pin 4 (BCM) and not 7 as I thought. Also I think you need to remove the , pull_up_down=GPIO.PUD_DOWN part (PIR example).
                        • T
                          thoimi @Jopyth
                          @Jopyth Thank you for your quick reply! :)
                          I tried for hours now… I think it’s connected correctly, because when I’m switching the pin-number in the script the script shows me always “0” - with the correct pin-number it shows me “1”…
                          I also put the sensor in a box - always shows me “1”… completely strange… :/
                            @thoimi It shows 1 because of the pull up resistor. Try removing that part, check my edited post above.
                            Edit: The 1 does not mean it is wired correctly, it just shows 1 because of the pull up resistor.
                            • T
                              thoimi @Jopyth
                              @Jopyth
                              thank you for the updated script!
                              the new script also shows me “Intruder detected” … i tried many variations of time and sensitivity adjustments…
                              I found another script on the internet:
                              from gpiozero import MotionSensor
                              pir = MotionSensor(4)
                              while True:
                                  if pir.motion_detected:
                                      print("Motion detected!")
                              This script shows me also the “Motion detected” all the time…
                              Maybe the PIR-Sensor itself is the problem… I will try with another Sensor next week :(
                                Makradon
                                Thanks for trying to help me.
                                I tried what you said. It always says “motion detected”.
                                I’m sure the wiring is right… I also use the dht22 sensor and that works perfectly fine. And the way you count the pins is the same… isn’t it?
                                I bought a new PIR sensor… but the problem is still there.
                                  @Makradon Nope, definitely not the same numbering.
                                    Makradon @Jopyth
                                    @Jopyth said in [MMM-PIR-Sensor] Install failing:
                                    Now I’m confused.
                                    5V is Pin 2
                                    Ground is Pin 6
                                    I think that is right when you count like this:
                                    http://www.elektronik-kompendium.de/sites/raspberry-pi/fotos/raspberry-pi-15b.jpg
                                    And when you don’t change the pin in the config file it says SensorPin 22.
                                    So which is the right pin in the pic above to connect the output of the PIR sensor that it works with this module?
                                      @Makradon Sensor PIN 22 for the PIR-Sensor module is this one:
                                      Edit: Maybe I was confused by the diagram of the DHT22 module. It looked to me like the GPIO and WiringPi numbers are different.
                                      johnnyboyJ 1 Reply Last reply Reply Quote 1
                                        PindaPower
                                        In other post they posted this link, maybe it will help??
                                        https://diyhacking.com/raspberry-pi-gpio-control/
                                        F 1 Reply Last reply Reply Quote 1
                                        • F
                                          fox @PindaPower
                                          @PindaPower said in [MMM-PIR-Sensor] Install failing:
                                          Thank you. With that i understood the delay and sensitivy knob.
                                          But! When i put sensivity at most right, the monitor goes on automatically ON after a while, even when there is NO movement in the radius… How can i debug this?
                                            Mar
                                            I’ve tried following the instruction above of removing and reinstalling but I keep getting the below errors. I’m not even sure what they are unfortunately, wondering if anyone is able to help.
                                            pi@raspberrypi:~/MagicMirror/modules/MMM-PIR-Sensor $ npm install
                                            npm WARN engine electron-rebuild@1.5.7: wanted: {"node":">=6.0.0"} (current: {"node":"4.2.1","npm":"2.14.7"})
                                            > epoll@0.1.20 install /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/onoff/node_modules/epoll
                                            > node-gyp rebuild
                                            make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/onoff/node_modules/epoll/build'
                                              CXX(target) Release/obj.target/epoll/src/epoll.o
                                              SOLINK_MODULE(target) Release/obj.target/epoll.node
                                              COPY Release/epoll.node
                                            make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/onoff/node_modules/epoll/build'
                                            > Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall /home/pi/MagicMirror/modules/MMM-PIR-Sensor
                                            > electron-rebuild -e ../../node_modules/electron-prebuilt
                                            /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/node_modules/spawn-rx/lib/index.js:139
                                                let cmdArgs = ['/C', exe, ...args];
                                            SyntaxError: Unexpected token ...
                                                at exports.runInThisContext (vm.js:53:16)
                                                at Module._compile (module.js:414:25)
                                                at Object.Module._extensions..js (module.js:442:10)
                                                at Module.load (module.js:356:32)
                                                at Function.Module._load (module.js:311:12)
                                                at Module.require (module.js:366:17)
                                                at require (module.js:385:17)
                                                at Object. (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/rebuild.js:38:16)
                                                at Module._compile (module.js:435:26)
                                                at Object. (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:24:16)
                                            npm ERR! Linux 4.4.38+
                                            npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install"
                                            npm ERR! node v4.2.1
                                            npm ERR! npm  v2.14.7
                                            npm ERR! Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall: `electron-rebuild -e ../../node_modules/electron-prebuilt`
                                            npm ERR!
                                            npm ERR! Failed at the Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall script 'electron-rebuild -e ../../node_modules/electron-prebuilt'.
                                            npm ERR! This is most likely a problem with the Magic-Mirror-Module-PIR-Sensor package,
                                            npm ERR!     electron-rebuild -e ../../node_modules/electron-prebuilt
                                            npm ERR! You can get their info via:
                                            npm ERR!     npm owner ls Magic-Mirror-Module-PIR-Sensor
                                            npm ERR!     /home/pi/MagicMirror/modules/MMM-PIR-Sensor/npm-debug.log
                                            edit: I have tried modifying the package.json file in the FAQ but the install exits within a minute, vs a really long time leaving the original. Seems like it gets farther through the install the first time. Though I’ve noticed i do have the electron folder and not an electron-prebuilt. The following is the error I get when i remove the -prebuilt.
                                                at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/rebuild.js:38:16)
                                                at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:24:16)
                                            npm ERR! Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall: `electron-rebuild -e ../../node_modules/electron`
                                            npm ERR!
                                            npm ERR! Failed at the Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall script 'electron-rebuild -e ../../node_modules/electron'.
                                            After doing the npm rebuild suggested above I get this error (with original/modified package.json)
                                            npm ERR!
                                            • 2 / 4
