    [MMM-PIR-Sensor] Install failing
    75 Posts 19 Posters 118.6k Views 18 Watching
    • K
      kerijn @Jopyth
      @Jopyth This worked for me for the installation as well. Thank you! However, the sensor does not seem to do anything. How can I check whether the sensor is working properly?
        Makradon @kerijn
        @kerijn said in [MMM-PIR-Sensor] Install failing:
        I have the same problem
          Jopyth Moderator @Makradon
          @Makradon @kerijn I found this. I think you could save this as test.py somewhere on your Pi and see if the output changes when you move and don’t move (set the pin number in the second line) after your start it with python test.py:
          import RPi.GPIO as GPIO
          pin = 11
          GPIO.setwarnings(False)
          GPIO.setmode(GPIO.BOARD)
          GPIO.setup(pin, GPIO.IN)         #Read output from PIR motion sensor
          while True:
                 i=GPIO.input(pin)
                 if i==0:                 #When output from motion sensor is LOW
                       print "No intruders",i
                       time.sleep(0.1)
                 elif i==1:               #When output from motion sensor is HIGH
                       print "Intruder detected",i
                       time.sleep(0.1)
          • T
            thoimi @Jopyth
            @Jopyth I had the same problem.
            Your work-around (installation) worked for me but the sensor does not seem to do anything…
            the test.py script shows me always “1” - also when nothing is moving in the room…
              Jopyth Moderator @thoimi
              @thoimi Check for the correct wiring (PIN-Numbers can be confusing, there is the BCM numbering and the other one), also make sure GND and 5V are conncted correctly, adjust sensitivity to maximum and time to minimum (so it hopefully switch back and forth quickly), try covering up the sensor under a bowl or something and then put your hand in to test.
              When I set up the sensor, I also searched for the error for hours, and at the end my problem was the sensor was plugged into pin 4 (BCM) and not 7 as I thought. Also I think you need to remove the , pull_up_down=GPIO.PUD_DOWN part (PIR example).
              • T
                thoimi @Jopyth
                @Jopyth Thank you for your quick reply! :)
                I tried for hours now… I think it’s connected correctly, because when I’m switching the pin-number in the script the script shows me always “0” - with the correct pin-number it shows me “1”…
                I also put the sensor in a box - always shows me “1”… completely strange… :/
                  @thoimi It shows 1 because of the pull up resistor. Try removing that part, check my edited post above.
                  Edit: The 1 does not mean it is wired correctly, it just shows 1 because of the pull up resistor.
                  • T
                    thoimi @Jopyth
                    @Jopyth
                    thank you for the updated script!
                    the new script also shows me “Intruder detected” … i tried many variations of time and sensitivity adjustments…
                    I found another script on the internet:
                    from gpiozero import MotionSensor
                    pir = MotionSensor(4)
                    while True:
                        if pir.motion_detected:
                            print("Motion detected!")
                    This script shows me also the “Motion detected” all the time…
                    Maybe the PIR-Sensor itself is the problem… I will try with another Sensor next week :(
                      Makradon
                      Thanks for trying to help me.
                      I tried what you said. It always says “motion detected”.
                      I’m sure the wiring is right… I also use the dht22 sensor and that works perfectly fine. And the way you count the pins is the same… isn’t it?
                      I bought a new PIR sensor… but the problem is still there.
                        @Makradon Nope, definitely not the same numbering.
                          Makradon @Jopyth
                          @Jopyth said in [MMM-PIR-Sensor] Install failing:
                          Now I’m confused.
                          5V is Pin 2
                          Ground is Pin 6
                          I think that is right when you count like this:
                          http://www.elektronik-kompendium.de/sites/raspberry-pi/fotos/raspberry-pi-15b.jpg
                          And when you don’t change the pin in the config file it says SensorPin 22.
                          So which is the right pin in the pic above to connect the output of the PIR sensor that it works with this module?
                            @Makradon Sensor PIN 22 for the PIR-Sensor module is this one:
                            Edit: Maybe I was confused by the diagram of the DHT22 module. It looked to me like the GPIO and WiringPi numbers are different.
                            johnnyboyJ 1 Reply Last reply Reply Quote 1
                              PindaPower
                              In other post they posted this link, maybe it will help??
                              https://diyhacking.com/raspberry-pi-gpio-control/
                              F 1 Reply Last reply Reply Quote 1
                              • F
                                fox @PindaPower
                                @PindaPower said in [MMM-PIR-Sensor] Install failing:
                                Thank you. With that i understood the delay and sensitivy knob.
                                But! When i put sensivity at most right, the monitor goes on automatically ON after a while, even when there is NO movement in the radius… How can i debug this?
                                Issues With MMM-WatchDog known?
                                https://forum.magicmirror.builders/post/29827
                                Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                                  Mar
                                  I’ve tried following the instruction above of removing and reinstalling but I keep getting the below errors. I’m not even sure what they are unfortunately, wondering if anyone is able to help.
                                  pi@raspberrypi:~/MagicMirror/modules/MMM-PIR-Sensor $ npm install
                                  npm WARN engine electron-rebuild@1.5.7: wanted: {"node":">=6.0.0"} (current: {"node":"4.2.1","npm":"2.14.7"})
                                  > epoll@0.1.20 install /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/onoff/node_modules/epoll
                                  > node-gyp rebuild
                                  make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/onoff/node_modules/epoll/build'
                                    CXX(target) Release/obj.target/epoll/src/epoll.o
                                    SOLINK_MODULE(target) Release/obj.target/epoll.node
                                    COPY Release/epoll.node
                                  make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/onoff/node_modules/epoll/build'
                                  > Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall /home/pi/MagicMirror/modules/MMM-PIR-Sensor
                                  > electron-rebuild -e ../../node_modules/electron-prebuilt
                                  /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/node_modules/spawn-rx/lib/index.js:139
                                      let cmdArgs = ['/C', exe, ...args];
                                  SyntaxError: Unexpected token ...
                                      at exports.runInThisContext (vm.js:53:16)
                                      at Module._compile (module.js:414:25)
                                      at Object.Module._extensions..js (module.js:442:10)
                                      at Module.load (module.js:356:32)
                                      at Function.Module._load (module.js:311:12)
                                      at Module.require (module.js:366:17)
                                      at require (module.js:385:17)
                                      at Object. (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/rebuild.js:38:16)
                                      at Module._compile (module.js:435:26)
                                      at Object. (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:24:16)
                                  npm ERR! Linux 4.4.38+
                                  npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install"
                                  npm ERR! node v4.2.1
                                  npm ERR! npm  v2.14.7
                                  npm ERR! code ELIFECYCLE
                                  npm ERR! Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall: `electron-rebuild -e ../../node_modules/electron-prebuilt`
                                  npm ERR! Exit status 1
                                  npm ERR!
                                  npm ERR! Failed at the Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall script 'electron-rebuild -e ../../node_modules/electron-prebuilt'.
                                  npm ERR! This is most likely a problem with the Magic-Mirror-Module-PIR-Sensor package,
                                  npm ERR! not with npm itself.
                                  npm ERR!     electron-rebuild -e ../../node_modules/electron-prebuilt
                                  npm ERR! You can get their info via:
                                  npm ERR!     npm owner ls Magic-Mirror-Module-PIR-Sensor
                                  npm ERR!     /home/pi/MagicMirror/modules/MMM-PIR-Sensor/npm-debug.log
                                  edit: I have tried modifying the package.json file in the FAQ but the install exits within a minute, vs a really long time leaving the original. Seems like it gets farther through the install the first time. Though I’ve noticed i do have the electron folder and not an electron-prebuilt. The following is the error I get when i remove the -prebuilt.
                                      at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/rebuild.js:38:16)
                                      at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:24:16)
                                  npm ERR! Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall: `electron-rebuild -e ../../node_modules/electron`
                                  npm ERR!
                                  npm ERR! Failed at the Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall script 'electron-rebuild -e ../../node_modules/electron'.
                                  After doing the npm rebuild suggested above I get this error (with original/modified package.json)
                                  npm ERR!
                                    Jopyth Moderator @Mar
                                    @Mar said in [MMM-PIR-Sensor] Install failing:
                                    This is an old node version. Please update your node and npm. (If you need help check the answers to this SO question.)
                                    M 1 Reply Last reply Reply Quote 2
                                    • F
                                      fox
                                      @Jopyth thank you very much for all your efforts for this community.
                                      Even its in your spare time it should be honored !
                                        Mar @Jopyth
                                        @Jopyth Hi, thanks for taking the time to respond to this. Sorry I was away for work and didnt have too much time to test this out.
                                        So i managed to, using your link, to update node. But there was issues even getting there, I had to use an older version of node to update npm…but anyways here is the output showing I’ve updated to the latest version.
                                        pi@raspberrypi:~/MagicMirror/modules/MMM-PIR-Sensor $ npm -v
                                        4.0.5
                                        pi@raspberrypi:~/MagicMirror/modules/MMM-PIR-Sensor $ node -v
                                        v7.4.0
                                        But now I’m getting this issue. Again thanks @Jopyth for responding so quickly last time.
                                        npm WARN prefer global node-gyp@3.5.0 should be installed with -g
                                        > epoll@0.1.20 install /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll
                                        > node-gyp rebuild
                                        make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build'
                                        make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build'
                                        An unhandled error occurred inside electron-rebuild
                                        Unable to find electron-prebuilt's version number, either install it or specify an explicit version
                                        Error: Unable to find electron-prebuilt's version number, either install it or specify an explicit version
                                            at _callee$ (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:74:17)
                                            at tryCatch (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:63:40)
                                            at Generator.invoke [as _invoke] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:337:22)
                                            at Generator.prototype.(anonymous function) [as next] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:96:21)
                                            at Generator.tryCatcher (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bluebird/js/release/util.js:16:23)
                                            at PromiseSpawn._promiseFulfilled (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bluebird/js/release/generators.js:97:49)
                                            at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bluebird/js/release/generators.js:201:15
                                            at Object. (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:197:4)
                                            at Module._compile (module.js:571:32)
                                            at Object.Module._extensions..js (module.js:580:10)
                                            at Module.load (module.js:488:32)
                                            at tryModuleLoad (module.js:447:12)
                                            at Function.Module._load (module.js:439:3)
                                            at Module.runMain (module.js:605:10)
                                            at run (bootstrap_node.js:420:7)
                                            at startup (bootstrap_node.js:139:9)
                                        npm ERR! node v7.4.0
                                        npm ERR! npm  v4.0.5
                                        npm ERR! Exit status 255
                                        npm ERR!
                                        npm ERR! If you do, this is most likely a problem with the Magic-Mirror-Module-PIR-Sensor package,
                                        npm ERR!     npm bugs Magic-Mirror-Module-PIR-Sensor
                                        npm ERR! Or if that isn't available, you can get their info via:
                                          @Mar Please change your package.json file as displayed here and execute npm install again. @paviro has not yet responded to my PR, but hopefully this will get merged in sooner or later.
                                          M 3 Replies Last reply Reply Quote 1
                                            Mar @Jopyth
                                            @Jopyth It finally worked!!! :lifter_tone2: thanks so much. Ive spent days on this :(
                                            Tried this last link you provided previously before posting but nothing was working, your support around getting node updated (and npm) was all that needed to happen first.
                                            Thanks again!
                                            • 2 / 4
