    https://github.com/njwilliams/MMM-PlaceInfo not loading
    10 Posts 5 Posters 1.3k Views 5 Watching
      Dresch360 Project Sponsor
      I’m having the same issue. Any updates?
        sdetweil @Dresch360
        @dresch360 can u open the developers window. ctrl-shift-i on the mirror keyboard and select the console tab
        Z 1 Reply Last reply Reply Quote 0
        • Z Offline
          Zoltan @sdetweil
          @Dresch360
          I suspect it is a “,” issue but I also cant seem to figure it. Did you manage?
            sdetweil @Zoltan
            @Zoltan the latest problems are because
            Openweather changed their business model and require user to supply credit card to use the new /onecall endpoint
            So you have to set apiversion to 3.0 and the endpoint to /onecall
            • Z Offline
              Zoltan @sdetweil
              Thanks very much for the heads up. I remember now when one of my displays crashed due to the 2.5 that had to be changed to 3.0. Thanks for the quick response
                sdetweil @Zoltan
                @Zoltan did that solve the problem?
                • L Offline
                  lmhmm @sdetweil
                  @sdetweil I use this very successfully and it works fully for weather and currency.
                  The secret is to use apilayer not fixer make these alterations:
                  Line57 https://api.apilayer.com/fixer/latest
                  58&59, 151 GBP
                  460 ?apikey=
                  That’s it just change in the js file. I don’t know but I downloaded the Open Weather module and it still keeps working for this. I have AccuWeatherDeluxe installed also.
                  So nothing new on weather.
                  It’s a great module,
                  Good Luck,
                  Lorraine
                  • Z Offline
                    Zoltan @lmhmm
                    @lmhmm
                    Thanks all. I am much closer than before. I now at least have a visual of the module. I however currently see on the mirror the following just below the Flag, City, Time.
                    Currency failed (401)
                    Weather failed (HTTP 400)
                    I think it might be that i am blocked being in South Africa but i will still try a few things
                    Thanks so much for the advise and help, its much appreciated
                    • Z Offline
                      Zoltan @Zoltan
                      @lmhmm
                      I finally managed to get the module running. I used the following fork
                      https://github.com/magicmirror-sdmy/MMM-PlaceInfo
                      Thanks once again for the help from you both
