    https://github.com/njwilliams/MMM-PlaceInfo not loading
    10 Posts 5 Posters 1.3k Views 5 Watching
      sdetweil @Zoltan
      @Zoltan the latest problems are because
      Openweather changed their business model and require user to supply credit card to use the new /onecall endpoint
      So you have to set apiversion to 3.0 and the endpoint to /onecall
      Z 1 Reply Last reply Reply Quote 0
      • Z Offline
        Zoltan @sdetweil
        Thanks very much for the heads up. I remember now when one of my displays crashed due to the 2.5 that had to be changed to 3.0. Thanks for the quick response
          sdetweil @Zoltan
          @Zoltan did that solve the problem?
          • L Offline
            lmhmm @sdetweil
            @sdetweil I use this very successfully and it works fully for weather and currency.
            The secret is to use apilayer not fixer make these alterations:
            Line57 https://api.apilayer.com/fixer/latest
            58&59, 151 GBP
            460 ?apikey=
            That’s it just change in the js file. I don’t know but I downloaded the Open Weather module and it still keeps working for this. I have AccuWeatherDeluxe installed also.
            So nothing new on weather.
            It’s a great module,
            Good Luck,
            Lorraine
            • Z Offline
              Zoltan @lmhmm
              @lmhmm
              Thanks all. I am much closer than before. I now at least have a visual of the module. I however currently see on the mirror the following just below the Flag, City, Time.
              Currency failed (401)
              Weather failed (HTTP 400)
              I think it might be that i am blocked being in South Africa but i will still try a few things
              Thanks so much for the advise and help, its much appreciated
              • Z Offline
                Zoltan @Zoltan
                @lmhmm
                I finally managed to get the module running. I used the following fork
                https://github.com/magicmirror-sdmy/MMM-PlaceInfo
                Thanks once again for the help from you both
