    https://github.com/njwilliams/MMM-PlaceInfo not loading
    10 Posts 5 Posters 1.9k Views 5 Watching
    • G
      GoodWillGustin
      Does anyone else use this module/anyone having trouble with it?
      I got my API keys and set up the config file. When I launch MM, not only does the PlaceInfo module not load (when set to either top_center or bottom_center), but none of my modules will load besides top_left, top_center, and middle_center regions. I’m getting no errors in the terminal. Here is my config.js entry:
      module: 'MMM-PlaceInfo',
      position: 'top-center',
      weatherAPIKey: "myopenweatherAPIkey",
      currencyAPIKey: "myfixer.ioAPIkey",
      currencyPrecision: 2,
      currencyRelativeTo: 'USD',
      places: [
      title: "London",
      flag: "gb",
      currency: "GBP",
      timezone: "Europe/London",
      weatherID: "2643743",
      title: "Tokyo",
      flag: "jp",
      currency: "JPY",
      timezone: "Asia/Tokyo",
      weatherID: "1857910",
      • Z
        Zoltan @Zoltan
        @lmhmm
        I finally managed to get the module running. I used the following fork
        https://github.com/magicmirror-sdmy/MMM-PlaceInfo
        Thanks once again for the help from you both
          Dresch360 Project Sponsor
          I’m having the same issue. Any updates?
            sdetweil @Dresch360
            @dresch360 can u open the developers window. ctrl-shift-i on the mirror keyboard and select the console tab
            Z 1 Reply Last reply
            • Z
              Zoltan @sdetweil
              @Dresch360
              I suspect it is a “,” issue but I also cant seem to figure it. Did you manage?
                sdetweil @Zoltan
                @Zoltan the latest problems are because
                Openweather changed their business model and require user to supply credit card to use the new /onecall endpoint
                So you have to set apiversion to 3.0 and the endpoint to /onecall
                • Z
                  Zoltan @sdetweil
                  Thanks very much for the heads up. I remember now when one of my displays crashed due to the 2.5 that had to be changed to 3.0. Thanks for the quick response
                    sdetweil @Zoltan
                    @Zoltan did that solve the problem?
                    L 1 Reply Last reply
                    • L
                      lmhmm @sdetweil
                      @sdetweil I use this very successfully and it works fully for weather and currency.
                      The secret is to use apilayer not fixer make these alterations:
                      Line57 https://api.apilayer.com/fixer/latest
                      58&59, 151 GBP
                      460 ?apikey=
                      That’s it just change in the js file. I don’t know but I downloaded the Open Weather module and it still keeps working for this. I have AccuWeatherDeluxe installed also.
                      So nothing new on weather.
                      It’s a great module,
                      Good Luck,
                      Lorraine
                      • Z
                        Zoltan @lmhmm
                        @lmhmm
                        Thanks all. I am much closer than before. I now at least have a visual of the module. I however currently see on the mirror the following just below the Flag, City, Time.
                        Currency failed (401)
                        Weather failed (HTTP 400)
                        I think it might be that i am blocked being in South Africa but i will still try a few things
                        Thanks so much for the advise and help, its much appreciated
                        • Z
                          Zoltan @Zoltan
                          @lmhmm
