    Monthly Calendar View
    58 Posts 23 Posters 91.1k Views 19 Watching
    • KirAsh4K
      KirAsh4 Moderator
      Spent the day wrangling code. Apparently I have a lot of ‘sumptinks’ coming up! :)
      This is just raw data processing. Stuff comes in, gets processed, and placed in the array which I then fetch. There’s no formatting in the code yet. Just don’t ask.
      L 1 Reply Last reply
      • MitchfarinoM
        Mitchfarino Module Developer
        I really like that running week of events!!
        Much better than the current calendar list
        Great work!
        • KirAsh4K
          KirAsh4 Moderator
          Thanks. It’s still in it’s very early stages. A lot can and will change still.
          • KirAsh4K
            KirAsh4 Moderator
            And now that I’m home, on the vertical layout, I left the other calendarS turned on:
            • Wilco89W
              Wilco89
              Is this using the currrent caladers?
              is it possible to add the starting/end time and the icon selected? when I add my and my girlfriend her calender both will show the same text “work” so it’s really difficult to see who is who.
              • KirAsh4K
                KirAsh4 Moderator
                There are three different calendars on that screen, the default one which is the list of events, the monthly calendar, and the running week. Both the monthly calendar and running week are unreleased code because they’re both still being developed.
                V 1 Reply Last reply
                • KirAsh4K
                  KirAsh4 Moderator
                  Please read about the release here: https://forum.magicmirror.builders/topic/238/monthly-calendar
                  • V
                    Vauxdvihl @KirAsh4
                    • L
                      l8kerjuan @KirAsh4
                      Hello @KirAsh4 where can i get the config for this calendar… exactly what i have been looking for. the “running week of events” is what every mom/dad need for their kids!!! hope you can share this!
                      • L
                        l8kerjuan @KirAsh4
                        looking for this @shuwi
                        • pjkoelemanP
                          pjkoeleman
                          @KirAsh4
                          What I’am missing in the calendar is a colum with the weeknumbers, left of the dates.
                          The weeknumbers could or should be an option ‘showWeekNr’ is true of false.
                          This should not be too difficult to build into the calendar.
                          just my thoughts
                          • E
                            erik72
                            Is there any config.js language setting that will make it start on Monday ?
                            Tried uk that gave me russian :)
                            • F
                              FangFace
                              ‘en-GB’ worked for me
                              E J 2 Replies Last reply
                              • E
                                erik72 @FangFace
                                @FangFace Your golden, Thanks
                                • KimzerK
                                  Kimzer @KirAsh4
                                  @KirAsh4 said in Monthly Calendar View:
                                  Oh I suppose …
                                  Keep in mind that the styling can be changed by the user to whatever they want it to look like. The sky isn’t the limit … it’s their imagination. :)
                                  can u post css for this?
                                  • Y
                                    yomaldyw @KirAsh4
                                    @KirAsh4 As mentioned above, how to configure magic mirror default calendar in monthly view. I eagerly await an answer from you :slightly_smiling_face: :slightly_smiling_face: :slightly_smiling_face:
                                      sdetweil @yomaldyw
                                      @yomaldyw see https://forum.magicmirror.builders/topic/238/monthly-calendar
                                      Y 1 Reply Last reply
                                      • Y
                                        yomaldyw @sdetweil
                                        @sdetweil yes thanks. I install it. but its not displaying
                                        S K 2 Replies Last reply
                                          sdetweil @yomaldyw
                                          @yomaldyw worked for me out of the box… have to put it between date and calendar modules in the config list to get it to display there…
                                          used the default config
                                          				module: 'calendar_monthly',
                                          				position: 'top_left',
                                          						// The config property is optional
                                          						// Without a config, a default month view is shown
                                          						// Please see the 'Configuration Options' section for more information
                                          • Y
                                            yomaldyw @sdetweil
                                            @sdetweil yes yes i got it. now its work wel, thank you so much.:smiling_face: :smiling_face: :smiling_face: :folded_hands: :folded_hands: :folded_hands: :thumbs_up: :thumbs_up: :thumbs_up: :thumbs_up: :handshake: :handshake: :handshake:
                                            • 3 / 3
