    Kitchen Touchscreen Dashboard
    14 Posts 4 Posters 6.8k Views 5 Watching
    • N Offline
      Niggich
      Hey Guys,
      I using and follow the MM Project since about 8 years. Finnaly I want to show you my Dasboard at the Kitchen. That are just Screenshots from the Serverpage… I also use a Mirror with a 27" Monitor.
      I used the following Modules.
      calendar_monthly
      MMM-DWD-Pollen
      MMM-MicrosoftToDo
      MMM-OnThisDayWikiApi
      MMM-RTSPtoWeb
      MMM-EasyPix
      MMM-MoonPhase
      MMM-page-indicator
      MMM-Touch
      MMM-ApothekenNotdienst
      MMM-EmbedURL
      MMM-Multimonth
      MMM-pages
      MMM-WeeklySchedule
      MMM-BackgroundSlideshow
      MMM-Fuel
      MMM-News-QR
      MMM-PDFSlideshow
      MMM-Worldclock
      MMM-Breathwork
      MMM-germanwordclock
      MMM-Nixie-Clock
      MMM-PirateSkyForecast
      MMM-Year-Progress
      MMM-CalendarExt3
      MMM-GrafanaChart
      MMM-octoprint
      MMM-RAIN-MAP
      MMM-DailyJuice
      MMM-ioBroker
      MMM-Remote-Control
      S MZ-BERM S 3 Replies Last reply Reply Quote 7
        sdetweil @Niggich
        @Niggich very cool… if you hadn’t seen it
        you can change the indicator circles to actual buttons
        https://forum.magicmirror.builders/topic/18876/mmm-carousel-pagination-icons/8?_=1735070775315
        N 1 Reply Last reply Reply Quote 2
        • N Offline
          Niggich @sdetweil
          @sdetweil Thank you. I didn’t know this. I will have a look later…
          • MZ-BERM Offline
            MZ-BER @Niggich
            @Niggich I’ve got so many questions — but first, huge kudos on this amazing work!
            Could you share which display you’re using? And are you still happy with it?
            Also, the smart home control interface (lights, heating, etc.) — is that a MagicMirror module visualizing data from Home Assistant?
            N 1 Reply Last reply Reply Quote 1
            • N Offline
              Niggich @MZ-BER
              @MZ-BER Thank you! You’re Welcome!
              I’m using the MM as a server and just open Webpage in Chromium on Ubuntu. For this I using an Intel Nuc and 23" Dell Touch Monitor. I can share some more Pictures this evening.
              The SmartHome Control is an embeded Webpage I made with iQontrol from ioBroker and the Visualization is Grafana. Also as an embeded Webpage. Grafana takes the data from ioBroker.
              Here are some Pictures of the Screen (not only Screenshots)…
              page1.jpg page2.jpg page3.jpg page4.jpg page5.jpg page6.jpg page7.jpg page8.jpg page9.jpg page10.jpg
                seabass @Niggich
                @Niggich I see you’re using the MMM-Touch and MMM-pages modules. Are you able to swipe to the next page configured with the MMM-pages module? Would you be able to share your module configuration for the MMM-Touch and MMM-pages modules as I’m unable to get the MMM-Touch module working with my setup. Thank you!
                • N Offline
                  Niggich @seabass
                  @seabass said in Kitchen Touchscreen Dashboard:
                  			module: "MMM-Touch",
                  			position: "top_center",
                  			classes: "",
                  			    disabled: false,
                  				debug: false,
                  				useDisplay: false,
                  				autoMode: false,
                  				defaultMode: "default",
                  					gestureCommands: {
                  					  "default":{
                  							"TAP_1": (commander) => {commander.sendNotification("USER_PRESENCE", true);},
                  							"SWIPE_RIGHT_1": (commander) => {commander.sendNotification("PAGE_DECREMENT", null);},
                  							"SWIPE_LEFT_1": (commander) => {commander.sendNotification("PAGE_INCREMENT", null);},
                  							"SWIPE_DOWN_1": (commander, gesture) => {commander.sendNotification("ARTICLE_PREVIOUS")},
                  							"SWIPE_UP_1": (commander, gesture) => {commander.sendNotification("ARTICLE_NEXT")},
                  							"SWIPE_DOWN_2": (commander, gesture) => {commander.sendNotification("BACKGROUNDSLIDESHOW_PREV")},
                  							"SWIPE_UP_2": (commander, gesture) => {commander.sendNotification("BACKGROUNDSLIDESHOW_NEXT")},
                  							//"DOUBLE_TAP_1": (commander) => {commander.sendNotification("LOAD_NEXT_WALLPAPER", null);},
                  							"SWIPE_LEFT_2": (commander) => {commander.sendNotification('CX3_GET_CONFIG', {callback: (before) => {commander.sendNotification('CX3_SET_CONFIG', {monthIndex: before.monthIndex + 1,callback: (after) => {setTimeout(() => { commander.sendNotification('CX3_RESET') }, 60_000)}})}})},
                  							"SWIPE_RIGHT_2": (commander) => {commander.sendNotification('CX3_GET_CONFIG', {callback: (before) => {commander.sendNotification('CX3_SET_CONFIG', {monthIndex: before.monthIndex - 1,callback: (after) => {setTimeout(() => { commander.sendNotification('CX3_RESET') }, 60_000)}})}})},
                    seabass @Niggich
                    @Niggich Thanks for the sample code. Unfortunately I still can’t get it working. I’m also using the MMM-ViewNotifications module and never see a notification sent from MMM-Touch when swiping. I used your exact code but commented out all the gestures except SWIPE_RIGHT_1 and SWIPE_RIGHT_2.
                    I know the touchscreen works because I’m also using the page-indicator module which sends the notification to change pages without issue. Do you have any suggestions on what I can look at?
                    Thanks!
                    • N Offline
                      Niggich @seabass
                      @seabass Ok, do you have MMM-Remote-Control installed?
                      Can you share your config by the way?
                        seabass @Niggich
                        @Niggich Hopefully the format looks okay but here you go. Thanks in advance for your help. Under the MMM-Touch section I currently added another sendnotification NEW_PAGE but it didn’t have any impact.
                        let config = {
                        	address: "localhost",
                        	port: 8080,
                        	basePath: "/",
                        	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "192.168.1.228"],
                                useHttps: false,
                        	httpsPrivateKey: "",
                        	httpsCertificate: "",
                        	language: "en",
                        	locale: "en-US",
                        	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
                        	timeFormat: 12,
                        	units: "imperial",
                        			module: "alert",
                        			module: "updatenotification",
                        			position: "top_bar"
                        			module: "clock",
                        			position: "top_left"
                        			header: "US Holidays",
                        						symbol: "calendar-check",
                        						url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics"
                        			module: "compliments",
                        			position: "lower_third"
                        			module: "weather",
                        				weatherProvider: "openmeteo",
                        				type: "current",
                        				lat: 44.953873,
                        				lon: -123.0884734
                        			module: "newsfeed",
                        			position: "bottom_bar",
                        				feeds: [
                        						title: "Fox News",
                        						url: "https://moxie.foxnews.com/google-publisher/latest.xml"
                        				showSourceTitle: true,
                        				showPublishDate: true,
                        				broadcastNewsFeeds: true,
                        				broadcastNewsUpdates: true
                        		        module: 'MMM-page-indicator',
                        		        position: 'bottom_bar',
                                    		activeBright: true,
                        			module: "MMM-pages",
                        		            timings: {
                                        		default: 5000,               // rotate every 5 seconds
                        		                0: 20000                     // page 0 rotates every 20 seconds
                                        		["newsfeed"], 				 // page 0
                        		                ["calendar", "compliments"], // page 1
                        		            fixed: [                         // modules that are always shown
                        						"alert",
                                        		"clock",
                        		                "weather",
                                        		"MMM-page-indicator",
                        						"MMM-Touch",
                        						"MMM-ViewNotifications"
                        		        module: 'MMM-ViewNotifications',
                        		        header: "Notifications",
                                        		// See below for Configuration Options
                        			classes: "",
                        			disabled: false,
                        				debug: false,
                        				useDisplay: false,
                        				autoMode: false,
                        				gestureCommands: {
                        					"default": {
                        							commander.sendNotification("NEW_PAGE"),
