    Kitchen Touchscreen Dashboard
    14 Posts 4 Posters 11.8k Views 5 Watching
    • NiggichN Offline
      Niggich @sdetweil
      @sdetweil Thank you. I didn’t know this. I will have a look later…
      • MZ-BERM Offline
        MZ-BER @Niggich
        @Niggich I’ve got so many questions — but first, huge kudos on this amazing work!
        Could you share which display you’re using? And are you still happy with it?
        Also, the smart home control interface (lights, heating, etc.) — is that a MagicMirror module visualizing data from Home Assistant?
        NiggichN 1 Reply Last reply Reply Quote 1
        • NiggichN Offline
          Niggich @MZ-BER
          @MZ-BER Thank you! You’re Welcome!
          I’m using the MM as a server and just open Webpage in Chromium on Ubuntu. For this I using an Intel Nuc and 23" Dell Touch Monitor. I can share some more Pictures this evening.
          The SmartHome Control is an embeded Webpage I made with iQontrol from ioBroker and the Visualization is Grafana. Also as an embeded Webpage. Grafana takes the data from ioBroker.
          Here are some Pictures of the Screen (not only Screenshots)…
          page1.jpg page2.jpg page3.jpg page4.jpg page5.jpg page6.jpg page7.jpg page8.jpg page9.jpg page10.jpg
            seabass @Niggich
            @Niggich I see you’re using the MMM-Touch and MMM-pages modules. Are you able to swipe to the next page configured with the MMM-pages module? Would you be able to share your module configuration for the MMM-Touch and MMM-pages modules as I’m unable to get the MMM-Touch module working with my setup. Thank you!
            • NiggichN Offline
              Niggich @seabass
              @seabass said in Kitchen Touchscreen Dashboard:
              			module: "MMM-Touch",
              			position: "top_center",
              			classes: "",
              			    disabled: false,
              				debug: false,
              				useDisplay: false,
              				autoMode: false,
              				defaultMode: "default",
              					gestureCommands: {
              					  "default":{
              							"TAP_1": (commander) => {commander.sendNotification("USER_PRESENCE", true);},
              							"SWIPE_RIGHT_1": (commander) => {commander.sendNotification("PAGE_DECREMENT", null);},
              							"SWIPE_LEFT_1": (commander) => {commander.sendNotification("PAGE_INCREMENT", null);},
              							"SWIPE_DOWN_1": (commander, gesture) => {commander.sendNotification("ARTICLE_PREVIOUS")},
              							"SWIPE_UP_1": (commander, gesture) => {commander.sendNotification("ARTICLE_NEXT")},
              							"SWIPE_DOWN_2": (commander, gesture) => {commander.sendNotification("BACKGROUNDSLIDESHOW_PREV")},
              							"SWIPE_UP_2": (commander, gesture) => {commander.sendNotification("BACKGROUNDSLIDESHOW_NEXT")},
              							//"DOUBLE_TAP_1": (commander) => {commander.sendNotification("LOAD_NEXT_WALLPAPER", null);},
              							"SWIPE_LEFT_2": (commander) => {commander.sendNotification('CX3_GET_CONFIG', {callback: (before) => {commander.sendNotification('CX3_SET_CONFIG', {monthIndex: before.monthIndex + 1,callback: (after) => {setTimeout(() => { commander.sendNotification('CX3_RESET') }, 60_000)}})}})},
              							"SWIPE_RIGHT_2": (commander) => {commander.sendNotification('CX3_GET_CONFIG', {callback: (before) => {commander.sendNotification('CX3_SET_CONFIG', {monthIndex: before.monthIndex - 1,callback: (after) => {setTimeout(() => { commander.sendNotification('CX3_RESET') }, 60_000)}})}})},
                seabass @Niggich
                @Niggich Thanks for the sample code. Unfortunately I still can’t get it working. I’m also using the MMM-ViewNotifications module and never see a notification sent from MMM-Touch when swiping. I used your exact code but commented out all the gestures except SWIPE_RIGHT_1 and SWIPE_RIGHT_2.
                I know the touchscreen works because I’m also using the page-indicator module which sends the notification to change pages without issue. Do you have any suggestions on what I can look at?
                Thanks!
                NiggichN 1 Reply Last reply Reply Quote 0
                • NiggichN Offline
                  Niggich @seabass
                  @seabass Ok, do you have MMM-Remote-Control installed?
                  Can you share your config by the way?
                    seabass @Niggich
                    @Niggich Hopefully the format looks okay but here you go. Thanks in advance for your help. Under the MMM-Touch section I currently added another sendnotification NEW_PAGE but it didn’t have any impact.
                    let config = {
                    	address: "localhost",
                    	port: 8080,
                    	basePath: "/",
                    	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "192.168.1.228"],
                            useHttps: false,
                    	httpsPrivateKey: "",
                    	httpsCertificate: "",
                    	language: "en",
                    	locale: "en-US",
                    	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
                    	timeFormat: 12,
                    	units: "imperial",
                    			module: "alert",
                    			module: "updatenotification",
                    			position: "top_bar"
                    			module: "clock",
                    			position: "top_left"
                    			header: "US Holidays",
                    						symbol: "calendar-check",
                    						url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics"
                    			module: "compliments",
                    			position: "lower_third"
                    			module: "weather",
                    				weatherProvider: "openmeteo",
                    				type: "current",
                    				lat: 44.953873,
                    				lon: -123.0884734
                    			module: "newsfeed",
                    			position: "bottom_bar",
                    				feeds: [
                    						title: "Fox News",
                    						url: "https://moxie.foxnews.com/google-publisher/latest.xml"
                    				showSourceTitle: true,
                    				showPublishDate: true,
                    				broadcastNewsFeeds: true,
                    				broadcastNewsUpdates: true
                    		        module: 'MMM-page-indicator',
                    		        position: 'bottom_bar',
                                		activeBright: true,
                    			module: "MMM-pages",
                    		            timings: {
                                    		default: 5000,               // rotate every 5 seconds
                    		                0: 20000                     // page 0 rotates every 20 seconds
                                    		["newsfeed"], 				 // page 0
                    		                ["calendar", "compliments"], // page 1
                    		            fixed: [                         // modules that are always shown
                    						"alert",
                                    		"clock",
                    		                "weather",
                                    		"MMM-page-indicator",
                    						"MMM-Touch",
                    						"MMM-ViewNotifications"
                    		        module: 'MMM-ViewNotifications',
                    		        header: "Notifications",
                                    		// See below for Configuration Options
                    			classes: "",
                    			disabled: false,
                    				debug: false,
                    				useDisplay: false,
                    				autoMode: false,
                    				gestureCommands: {
                    					"default": {
                    							commander.sendNotification("NEW_PAGE"),
                    • NiggichN Offline
                      Niggich @seabass
                      Hey @seabass, it look’s good. I’m not sure but I think you need to install MMM-Remote-Control for sending notifications. Maybe @sdetweil can tell us more about this? Thanks.
                        sdetweil @Niggich
                        @Niggich MMM-RemoteControl is another module that can send many notifications
                        im not sure its related to Touch
                        • NiggichN Offline
                          Niggich @sdetweil
                          @sdetweil I think @seabass have to try.
                          Regards from Denmark.
                            seabass @Niggich
                            @Niggich I think @sdetweil is correct that MMM-RemoteControl is not related to Touch. I can try it in a bit to confirm. I do have a question on the MMM-Touch module though that I’m hoping one of you or anyone for that matter can answer. When using the touch module, does it allow touch/swipe across the entire screen or just within the module that is loaded on the screen itself?
