    MagicMirror is Failing to start at all
    22 Posts 4 Posters 7.0k Views 4 Watching
      sdetweil @Sampleswow
      Because you did this manually the script will abort if the same version is already
      I provide another option, instead of apply use
      force
      At the end of the command
      I don’t document this because I dont want everyone using force and getting into more trouble.
        Sampleswow @sdetweil
        So i used the force protocol and it took some time and did some things. after it was done i attempted to start the MM using both the old way and they way the release notes said and i still get this,
        pi@raspberrypi:~ $ cd MagicMirror
        magicmirror@2.32.0 start
        node --run start:x11
        node: bad option: --run
        pi@raspberrypi:~/MagicMirror $ node --run
        node: --run requires an argument
          @Sampleswow can you show the output of
          node -v
            pi@raspberrypi:~ $ node -v
            v24.4.1
            pi@raspberrypi:~/MagicMirror $ node -v
            v24.4.1
              @Sampleswow thanks
              Try this
              sudo n 22.14
              hash -r
              node -v
              You should get 22.14 or 22.15
              Then try npm start in the MagicMirror folder
                pi@raspberrypi:~ $ sudo n 22.14
                copying : node/22.14.0
                installed : v22.14.0 (with npm 10.9.2)
                pi@raspberrypi:~ $ hash -r
                v22.14.0
                  @karsten13 have any debug advice here?
                  • karsten13K
                    karsten13 @sdetweil
                    can you see what I’m doing right now ;)
                    I used my containers a few minutes ago to see if I can reproduce but I can’t. So no idea.
                      @Sampleswow ok, it makes no sense
                      I would suggest starting over
                      Reflash the SD card
                      Use the script to Install
                        is that the only way? I have a lot of setup, I would hate to lose by starting over.
                        also again What script i have no idea what your referring to, or how to use it. I am a basic user of Magic Mirror
                          @Sampleswow
                          I have two sets of scripts, install/update are listed in the MagicMirror doc
                          Install/upgrade
                          Backup/restore, which can save your MagicMirror setup and place it in a GitHub repo, with versions (it does not backup folders, only info required to restore the config onto a new MagicMirror install.).
                          https://github.com/sdetweil/MagicMirror-backup-restore
                          You can backup Your config now, copy off system, upload to GitHub as part of backup
                          config.js, custom.css, all the installed modules and where they came from. And any new files they created
                          I always recommend using a new SD card anyhow, just in case there is something (which I will fix)
                          Nodejs is just a tool we use to launch Our app, and run our code.
                          I don’t see any reports of problems like this so, I don’t know
                          • KristjanESPERANTOK
                            If --run is a bad option let’s try run the long command directly and see what happens.
                            So instead of npm run, try this:
                            On Wayland:
                            WAYLAND_DISPLAY="${WAYLAND_DISPLAY:=wayland-1}" ./node_modules/.bin/electron js/electron.js --enable-features=UseOzonePlatform --ozone-platform=wayland
                            On X11:
                            DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                            This may show us the real core of the problem, or it works and starts MM properly and we could make it a little more comfortable (even if it is a bit hacky).
                              Sampleswow @KristjanESPERANTO
                              @KristjanESPERANTO said in MagicMirror is Failing to start at all:
                              This Command STARTED my Mirror!!!
                              Im super excited everything is the way I left it even no loading google images lol (I know i have to find and alternative now )
                                @Sampleswow awesome
                                edit the package.json
                                and change the “start”
                                to “startx”
                                then add this line after
                                "start":"DISPLAY=${DISPLAY:=:0} ./node_modules/.bin/electron js/electron.js",
                                then
                                npm start
                                should start your MagicMirror
                                this was the way it was before this release
                                  That worked i picked the right start because there is apparently 2 of them in the text code
                                    Update for the Jan 1 2026,
                                    This no longer fixes the issue. I used your update script and now i get this error;
                                    sh: 1: ./node_modules/.bin.electron.js: not found
                                      @Sampleswow should not say electron.js
                                      Do
                                      ls node_modules/electron
                                      If not found do
                                      npm install electron@39.2.7
                                      If successful
                                      Do
                                      npm start
                                      Please advise
                                        That fixed it for now. I guess will talk again next update lol, Thank you for your dedication to resolving my issue!
                                          @Sampleswow can you send me the ~/MagicMirror/installers/upgrade.log
                                          Via email.
                                          The same userid as here at gmail
