    MagicMirror is Failing to start at all
    22 Posts 4 Posters 7.0k Views 4 Watching
      Sampleswow @sdetweil
      pi@raspberrypi:~ $ node -v
      v24.4.1
      pi@raspberrypi:~ $ cd MagicMirror
      pi@raspberrypi:~/MagicMirror $ node -v
      v24.4.1
        sdetweil @Sampleswow
        @Sampleswow thanks
        Try this
        sudo n 22.14
        hash -r
        node -v
        You should get 22.14 or 22.15
        Then try npm start in the MagicMirror folder
          pi@raspberrypi:~ $ sudo n 22.14
          copying : node/22.14.0
          installed : v22.14.0 (with npm 10.9.2)
          pi@raspberrypi:~ $ hash -r
          v22.14.0
          magicmirror@2.32.0 start
          node --run start:x11
          node: bad option: --run
            @karsten13 have any debug advice here?
            • karsten13K
              karsten13 @sdetweil
              can you see what I’m doing right now ;)
              I used my containers a few minutes ago to see if I can reproduce but I can’t. So no idea.
                @Sampleswow ok, it makes no sense
                I would suggest starting over
                Reflash the SD card
                Use the script to Install
                  is that the only way? I have a lot of setup, I would hate to lose by starting over.
                  also again What script i have no idea what your referring to, or how to use it. I am a basic user of Magic Mirror
                    @Sampleswow
                    I have two sets of scripts, install/update are listed in the MagicMirror doc
                    Install/upgrade
                    Backup/restore, which can save your MagicMirror setup and place it in a GitHub repo, with versions (it does not backup folders, only info required to restore the config onto a new MagicMirror install.).
                    https://github.com/sdetweil/MagicMirror-backup-restore
                    You can backup Your config now, copy off system, upload to GitHub as part of backup
                    config.js, custom.css, all the installed modules and where they came from. And any new files they created
                    I always recommend using a new SD card anyhow, just in case there is something (which I will fix)
                    Nodejs is just a tool we use to launch Our app, and run our code.
                    I don’t see any reports of problems like this so, I don’t know
                    • KristjanESPERANTOK
                      If --run is a bad option let’s try run the long command directly and see what happens.
                      So instead of npm run, try this:
                      On Wayland:
                      WAYLAND_DISPLAY="${WAYLAND_DISPLAY:=wayland-1}" ./node_modules/.bin/electron js/electron.js --enable-features=UseOzonePlatform --ozone-platform=wayland
                      On X11:
                      DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                      This may show us the real core of the problem, or it works and starts MM properly and we could make it a little more comfortable (even if it is a bit hacky).
                        Sampleswow @KristjanESPERANTO
                        @KristjanESPERANTO said in MagicMirror is Failing to start at all:
                        This Command STARTED my Mirror!!!
                        Im super excited everything is the way I left it even no loading google images lol (I know i have to find and alternative now )
                          @Sampleswow awesome
                          edit the package.json
                          and change the “start”
                          to “startx”
                          then add this line after
                          "start":"DISPLAY=${DISPLAY:=:0} ./node_modules/.bin/electron js/electron.js",
                          then
                          npm start
                          should start your MagicMirror
                          this was the way it was before this release
                            That worked i picked the right start because there is apparently 2 of them in the text code
                              Update for the Jan 1 2026,
                              This no longer fixes the issue. I used your update script and now i get this error;
                              sh: 1: ./node_modules/.bin.electron.js: not found
                                @Sampleswow should not say electron.js
                                Do
                                ls node_modules/electron
                                If not found do
                                npm install electron@39.2.7
                                If successful
                                Do
                                npm start
                                Please advise
                                  That fixed it for now. I guess will talk again next update lol, Thank you for your dedication to resolving my issue!
                                    @Sampleswow can you send me the ~/MagicMirror/installers/upgrade.log
                                    Via email.
                                    The same userid as here at gmail
