    MagicMirror is Failing to start at all
    22 Posts 4 Posters 7.4k Views 4 Watching
      sdetweil @Sampleswow
      @karsten13 have any debug advice here?
      karsten13K 1 Reply Last reply
      • karsten13K
        karsten13 @sdetweil
        can you see what I’m doing right now ;)
        I used my containers a few minutes ago to see if I can reproduce but I can’t. So no idea.
          @Sampleswow ok, it makes no sense
          I would suggest starting over
          Reflash the SD card
          Use the script to Install
            Sampleswow @sdetweil
            is that the only way? I have a lot of setup, I would hate to lose by starting over.
            also again What script i have no idea what your referring to, or how to use it. I am a basic user of Magic Mirror
              @Sampleswow
              I have two sets of scripts, install/update are listed in the MagicMirror doc
              Install/upgrade
              Backup/restore, which can save your MagicMirror setup and place it in a GitHub repo, with versions (it does not backup folders, only info required to restore the config onto a new MagicMirror install.).
              https://github.com/sdetweil/MagicMirror-backup-restore
              You can backup Your config now, copy off system, upload to GitHub as part of backup
              config.js, custom.css, all the installed modules and where they came from. And any new files they created
              I always recommend using a new SD card anyhow, just in case there is something (which I will fix)
              Nodejs is just a tool we use to launch Our app, and run our code.
              I don’t see any reports of problems like this so, I don’t know
              KristjanESPERANTOK 1 Reply Last reply
              • KristjanESPERANTOK
                If --run is a bad option let’s try run the long command directly and see what happens.
                So instead of npm run, try this:
                On Wayland:
                WAYLAND_DISPLAY="${WAYLAND_DISPLAY:=wayland-1}" ./node_modules/.bin/electron js/electron.js --enable-features=UseOzonePlatform --ozone-platform=wayland
                On X11:
                DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                This may show us the real core of the problem, or it works and starts MM properly and we could make it a little more comfortable (even if it is a bit hacky).
                  Sampleswow @KristjanESPERANTO
                  @KristjanESPERANTO said in MagicMirror is Failing to start at all:
                  This Command STARTED my Mirror!!!
                  Im super excited everything is the way I left it even no loading google images lol (I know i have to find and alternative now )
                    @Sampleswow awesome
                    edit the package.json
                    and change the “start”
                    to “startx”
                    then add this line after
                    "start":"DISPLAY=${DISPLAY:=:0} ./node_modules/.bin/electron js/electron.js",
                    then
                    npm start
                    should start your MagicMirror
                    this was the way it was before this release
                    S 2 Replies Last reply
                      That worked i picked the right start because there is apparently 2 of them in the text code
                        Update for the Jan 1 2026,
                        This no longer fixes the issue. I used your update script and now i get this error;
                        sh: 1: ./node_modules/.bin.electron.js: not found
                          @Sampleswow should not say electron.js
                          Do
                          ls node_modules/electron
                          If not found do
                          npm install electron@39.2.7
                          If successful
                          Do
                          npm start
                          Please advise
                            That fixed it for now. I guess will talk again next update lol, Thank you for your dedication to resolving my issue!
                              @Sampleswow can you send me the ~/MagicMirror/installers/upgrade.log
                              Via email.
                              The same userid as here at gmail
