    MMM-WorldTides - show high and low water for your region
    12 Posts 5 Posters 10.6k Views 5 Watching
    • Y
      yawns Moderator
      There should be. I use the time format which is set in config.js but I did not check. I simply forgot about that. I will check tomorrow evening and let you know what to do.
      • Y
        yawns Moderator @onetwankyfive
        @onetwankyfive said in MMM-WorldTides - show high and low water for your region:
        Is there a way to make it 12 hour instead of 24 hour time?
        Hi, sorry it took a bit longer than expected to find some time. It actually used 12 hour format, I just forgot the “am/pm” extension.
        So I replaced this:
        time: ((this.config.timeFormat === 24) ? moment(t.dt, "X").format("HH:mm") : moment(t.dt, "X").format("hh:mm")),
        with this:
        time: ((this.config.timeFormat === 24) ? moment(t.dt, "X").format("HH:mm") : moment(t.dt, "X").format("hh:mm a")),
          A Former User
          Hmm… like the sound of the mod as live on the water, and would be handy, but git cloned repository and installed, added to config
          		module: 'MMM-WorldTides',
          		position: 'top_right',
          		longitude: '8.134', //longitude and latitude need to be written with . instead of ,
          		latitude: '98.299',
          		appid: 'APIKEY' //appid needs to be requested from worldtides.info
          And well getting the MM error … Any thoughts?
          B 1 Reply Last reply
            bhepler Module Developer @Guest
            @wjdw87 Just based on what you quoted, you have not properly closed your config section. You’re missing a close bracket just after the API KEY value.
            	latitude: '98.299',
            ? 1 Reply Last reply
              A Former User @bhepler
              @bhepler Oops my bad, many thanks for spotting that @bhepler
              Now to change those icons
              Y 1 Reply Last reply
              • Y
                yawns Moderator @Guest
                @wjdw87
                I moved the symbols to config section and updated the module on github
                Just do a git pull in the MMM-WorldTides directory and afterwards you can define own css symbols (existing in weathericons or fontawesome) in your magic mirror config.js file
                read.me was also updated to explain the change
                  A Former User
                  Many thanks, though i did update manually in the scripts yesterday, will look at options and update accordingly if the icons are more in line that are on offer, great mod.
                  BTW any plans to go more indepth with the feeds (tidal range, depth etc)?
                  • Y
                    @wjdw87
                    Currently not, although the API provides this information. Maybe I could add a switch to enable more information. It’s just a matter of space available on screen … and free time of course :-)
                      A Former User
                      I’d like to make more sense of my view LOL by the time i’ve got down past the garden and hit the reef below, it’s occasionally submerged on the fringe even on “low tide” :( so with the tidal ranges, i can see and make plans without having to manually search :)
                      alt text
                        mcm
