    Display JSON data from an api
    15 Posts 6 Posters 11.9k Views 5 Watching
      PeppaPigKilla
      Hi
      I want to be able to display some data that is delivered in JSON format
      I ideally would like to be able to create a category with several titles in each and eah of the titles will get dynamic data produced by the API I will be using. Has anyone made anything like this or know how to make this ?
      Thank you
        PeppaPigKilla
        To add more to this.
        This is the output of the API
        {"player":{"username":"peppapigkilla","platform":"uplay","ubisoft_id":"bb2c294b-d691-4708-863f-a55242d3270e","indexed_at":"2016-05-29T16:03:49.884Z","updated_at":"2017-01-29T11:38:10.755Z","stats":{"ranked":{"has_played":true,"wins":21,"losses":9,"wlr":2.333,"kills":153,"deaths":127,"kd":1.205,"playtime":42600},"casual":{"has_played":true,"wins":468,"losses":383,"wlr":1.222,"kills":3019,"deaths":2212,"kd":1.365,"playtime":729250.0},"overall":{"revives":92,"suicides":21,"reinforcements_deployed":1765,"barricades_built":985,"steps_moved":4027174420,"bullets_fired":94519,"bullets_hit":27318,"headshots":1193,"melee_kills":23,"penetration_kills":329,"assists":927},"progression":{"level":109,"xp":9128}}}}
        I want to create a block that displasy this information.
        Not all of it, just some.
        This is a bot i use on my discord
        alt text
        Essentially just the information on this.
        • L
          looolz
          Did you get any traction with this? I’m looking for similar solutions; Display fields from JSON formatted file.
          • cowboysdudeC
            You would need to create a module to do this…
              mortenbirkelund
              You could take a look at the MMM-Rest… It doesnt have the ability to read json but could be modified. If you do modify it to accept json, please let me know as I am also looking for a way to do this.
              https://forum.magicmirror.builders/topic/1851/mmm-rest-reading-json
              • cowboysdudeC
                cowboysdude Module Developer @mortenbirkelund
                @mortenbirkelund it would be easier to just write a new module for it… hacking something will probably not give you the results you want.
                What is the address of the api?
                • L
                  looolz
                  @cowboysdude
                  Thanks, yes. Do you happen to know of a module that successfully loads data from a JSON file? Seems like such a simple thing to do.
                  and @mortenbirkelund
                  Thanks for the suggestion. I don’t have the skills to make this, yet.
                    mortenbirkelund
                    @cowboysdude said in Display JSON data from an api:
                    Perhaps. I just guessed a the rest module could be a good starting point.
                    • cowboysdudeC
                      cowboysdude Module Developer @looolz
                      @looolz Where is the info coming from? What is the api address?
                      L 1 Reply Last reply
                      • L
                        looolz @cowboysdude
                        @cowboysdude There is no API. In this case it’s just shell scripts that write out JSON files. I could modify the shell script to write out the files anyhow I want.
                        • yawnsY
                          yawns Moderator
                          So this is just a JSON file which is sitting on your raspberry, right?
                          The approach would be the same as with the compliments.js module loading a local file with additional statements.
                          That shouldn’t be too difficult. I could try to tackle this, but I need to complete another module first which is waiting for so long already … too much to do and no time :(
                          • L
                            looolz @yawns
                            @yawns Thanks for the reply!
                            Well, the JSON-file would be hosted on a server, so a http-path to the file would do the job for sure. A common way to do this that I’ve seen is installing Dropbox on a server, and sharing out the JSON file via a public link.
                            ooom416354O 1 Reply Last reply
                            • ooom416354O
                              ooom416354 @looolz
                              @looolz I am actually trying to do this also. I have JSON data I’m pulling from an API and am able to present it on a page when I click a button but am not entirely sure how to map this over to an actual MM2 module. I’m trying to follow the documentation and it’s overwhelming for someone with limited JS experience! Is there a generic module already created which can be used to kind of re-point the URL to use any JSON feed, change the returned field names and obviously update the results on the mirror?
                              • yawnsY
                                yawns Moderator
                                :D
                                I just noticed @PeppaPigKilla was the one asking for a UbisoftStats display and @looolz was asking for some different usecase
                                @looolz: do you have an example of your JSON file?
                                • L
                                  looolz
                                  The big elephant in the room here is that Panic’s StatusBoard did this and is now dead. They discontinued their iPad app in November, and users from all over the world are looking for something to replace it with. MagicMirror is the perfect replacement, but it lacks the most popular module: The Graph Module. When the Graph Module in Statusboard is fed just one number, it displays the number with a name, instead of the graph. I think a good solution would be to base further MMM development based on the same JSON structure that has already been established in the StatusBoard community. Examples:
                                  "graph": {
                                  "title" : "IKKE BEHANDLET",
                                  "total" : true,
                                  "datasequences" : [
                                  "title" : "Datasupport",
                                  "datapoints" : [
                                  { "title" : "Antall", "value" : 3 }
                                  This will in StatusBoard look like this:
                                  If however, the same module is used, and pointed to this JSON-file:
                                  "graph" : {
                                  "title" : "Prod-Redigering : antall saker opprettet",
                                  "total" : true,
                                  "datasequences" : [
                                  "title" : "Uke 29",
                                  "datapoints" : [
                                  {"title" : "Mandag", "value" : 0 },
                                  {"title" : "Tirsdag", "value" : 4 },
                                  {"title" : "Onsdag", "value" : 0 },
                                  {"title" : "Torsdag" , "value" : 3 },
                                  {"title" : "Fredag", "value" : 2 }
                                  That will produce this nice Column Graph:
                                  The whitepaper still exists here: https://library.panic.com/statusboard/graph_tutorial/
                                  If someone needs motivation to look into this, please check the comments here:
                                  https://panic.com/blog/the-future-of-status-board/
