    Display JSON data from an api
    15 Posts 6 Posters 10.7k Views 5 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer @mortenbirkelund
      @mortenbirkelund it would be easier to just write a new module for it… hacking something will probably not give you the results you want.
      What is the address of the api?
      • L Offline
        looolz
        @cowboysdude
        Thanks, yes. Do you happen to know of a module that successfully loads data from a JSON file? Seems like such a simple thing to do.
        and @mortenbirkelund
        Thanks for the suggestion. I don’t have the skills to make this, yet.
          mortenbirkelund
          @cowboysdude said in Display JSON data from an api:
          Perhaps. I just guessed a the rest module could be a good starting point.
            cowboysdude Module Developer @looolz
            @looolz Where is the info coming from? What is the api address?
            • L Offline
              looolz @cowboysdude
              @cowboysdude There is no API. In this case it’s just shell scripts that write out JSON files. I could modify the shell script to write out the files anyhow I want.
              • yawnsY Offline
                yawns Moderator
                So this is just a JSON file which is sitting on your raspberry, right?
                The approach would be the same as with the compliments.js module loading a local file with additional statements.
                That shouldn’t be too difficult. I could try to tackle this, but I need to complete another module first which is waiting for so long already … too much to do and no time :(
                • L Offline
                  looolz @yawns
                  @yawns Thanks for the reply!
                  Well, the JSON-file would be hosted on a server, so a http-path to the file would do the job for sure. A common way to do this that I’ve seen is installing Dropbox on a server, and sharing out the JSON file via a public link.
                  ooom416354O 1 Reply Last reply Reply Quote 0
                  • ooom416354O Offline
                    ooom416354 @looolz
                    @looolz I am actually trying to do this also. I have JSON data I’m pulling from an API and am able to present it on a page when I click a button but am not entirely sure how to map this over to an actual MM2 module. I’m trying to follow the documentation and it’s overwhelming for someone with limited JS experience! Is there a generic module already created which can be used to kind of re-point the URL to use any JSON feed, change the returned field names and obviously update the results on the mirror?
                    • yawnsY Offline
                      yawns Moderator
                      :D
                      I just noticed @PeppaPigKilla was the one asking for a UbisoftStats display and @looolz was asking for some different usecase
                      @looolz: do you have an example of your JSON file?
                      • L Offline
                        looolz
                        The big elephant in the room here is that Panic’s StatusBoard did this and is now dead. They discontinued their iPad app in November, and users from all over the world are looking for something to replace it with. MagicMirror is the perfect replacement, but it lacks the most popular module: The Graph Module. When the Graph Module in Statusboard is fed just one number, it displays the number with a name, instead of the graph. I think a good solution would be to base further MMM development based on the same JSON structure that has already been established in the StatusBoard community. Examples:
                        "graph": {
                        "title" : "IKKE BEHANDLET",
                        "total" : true,
                        "datasequences" : [
                        "title" : "Datasupport",
                        "datapoints" : [
                        { "title" : "Antall", "value" : 3 }
                        This will in StatusBoard look like this:
                        If however, the same module is used, and pointed to this JSON-file:
                        "graph" : {
                        "title" : "Prod-Redigering : antall saker opprettet",
                        "total" : true,
                        "datasequences" : [
                        "title" : "Uke 29",
                        "datapoints" : [
                        {"title" : "Mandag", "value" : 0 },
                        {"title" : "Tirsdag", "value" : 4 },
                        {"title" : "Onsdag", "value" : 0 },
                        {"title" : "Torsdag" , "value" : 3 },
                        {"title" : "Fredag", "value" : 2 }
                        That will produce this nice Column Graph:
                        The whitepaper still exists here: https://library.panic.com/statusboard/graph_tutorial/
                        If someone needs motivation to look into this, please check the comments here:
                        https://panic.com/blog/the-future-of-status-board/
