    PIR sensor behind glass?
    65 Posts 16 Posters 115.7k Views 19 Watching
    • N Offline
      Nususu @cowboysdude
      @cowboysdude I got it working using this code:
      https://github.com/paviro/MMM-PIR-Sensor
      With this code, I’ve got a problem where the screen only stays on for about 1 second after motion detection. Now I need to modify the code somehow to allow me to tell the mirror to stay on for a set amount of time after detecting motion, i.e. only go dark once no motion has been detected for x seconds. Problem is I don’t know where to start with that. Will let you know if I figure anything out. Any ideas?
      • cowboysdudeC Offline
        cowboysdude Module Developer @Nususu
        @Nususu try adding the powerSaving to your config…
                module: 'MMM-PIR-Sensor',
                    powerSaving: false
        See what that does :) PLUS there’s also an adjustment on your PIR sensor itself… which one and I don’t know … do a google search for adjustments :)
          Aly
          @Nususu - same here
          Perhaps, with a resistor?
          • N Offline
            Nususu @Aly
            @Aly I found documentation for the sensor that a resistor would indeed solve the issue here. I can set the delay up to 200 seconds with a 250k resistor, so I ordered one and will report back how it went.
              Aly
              @Nususu - great !!
              Can you post the doc. ?
              • N Offline
                Nususu @Aly
                @Aly I misspoke, shouldn’t have called it documentation. Rather, it was this picture:alt text
                Which appears to be a translation from the Chinese original picture.
                A 1 Reply Last reply Reply Quote 1
                  Aly @Nususu
                  @Nususu
                  so if we remove the R6 resistor the delay would be 30s ?
                  • N Offline
                    Nususu @Aly
                    @Aly yes, it would appear so. I just bought a soldering iron and resistors which arrive tomorrow so I’ll perform a couple tests: 1. Remove r6 and verify that it’s 30s. 2. Add 250k resistor and test duration.
                      Aly @Nususu
                      @Nususu
                      Ok - thanks for your help! :)
                      I can/will test it on coming monday.
                      • N Offline
                        Nususu @Aly
                        @Aly I tested this today - I put a 250k resistor on R6 and it increased the timer to approximately 25 seconds. I forgot to test without a resistor. Let me know if you end up testing that.
                          PaulB
                          @Comunnity
                          If it comes to the thickness of the mirror: Would you either recommend webcams, etc, behind the mirror or as I thought create a CAD-print plan for a 3 D-printer to hide the camera behind a… actually I have no clue how to call it … a “string” of maybe a lamp?
                          Do you guys have recommendations or Best Practices?
                          I saw some awesome bathroom project in this forum but no one 3D printed his lamp or LED. My roommate has a 3D printer so I am thinking about to integrated a camera in one part of an LED lamp which is on top of the mirror.
                          Maybe someone tried this idea before me. Hope there are some Best Practices on how to do it.
                          As always I would like to thank you for your awesome feedback guys.
                          Kind regard from Hamburg, Germany,
                          Paul
                          • Y Offline
                            yawns Moderator @PaulB
                            @paulb
                            I really like the way this guy mounted the camera on top of the mirror: https://forum.magicmirror.builders/topic/6952/my-mirror-so-great
                            • 4 / 4
