    My Mirror ! So great !
    23 Posts 12 Posters 19.3k Views 13 Watching
      belgium80
      After several weeks to read this forum, I decided to make MY own Magic Mirror. It was not easy, because I am a noob with raspberry but I am glad to have done it !
      Here is some pics.
      FYI, my modules are :
      • MMM-Remote-Control
      • compliments
      • newsfeed
      • MMM-Globe
      • MMM-NOAA
      • MMM-soccer
      • calendar
      • mm-pir-hide-all
      • MMM-PIR-Sensor
      • calendar_monthly
      • MMM-FreeBox-Monitor
      info : The spy-mirror’s thickness is 6 mm. (Size : 900mm x 600mm ; Cost =150€)
      B Mykle1M 2 Replies Last reply Reply Quote 9
        belgium80 @belgium80
        This post is deleted!
        • C Offline
          cyberphox
          that’s a great looking mirror and case!
            belgium80 @cyberphox
            @cyberphox
            Thks !
              Mykle1 Project Sponsor Module Developer @belgium80
              @belgium80
              Excellent work!
              • yawnsY Offline
                yawns Moderator
                Very nice work, looks very professional.
                What is mounted on top of the mirror? Camera, microphone, pir sensor?
                  alvesge
                  Amazing !
                  Comment as-tu fixé le mirroir au cadre sans faire de trous ?
                  Bravo encore !
                    belgium80
                    @yawns
                    It’s a camera. I wanted to use the MMM-Facial-recognition but my raspberry warms a lot. I am waiting for the cooling system what I ordered.
                    The PIR sensor is at the bottom
                    0_1523336950951_2018-04-10_07h05_49.png 0_1523336956585_2018-04-10_07h06_58.png 0_1523336967132_Sans titre.png
                    slametpsS 1 Reply Last reply Reply Quote 4
                      belgium80 @alvesge
                      @alvesge
                      I used a special glu what I bought in the special market (Mr Bricolage)
                      It’s like a silicon glu but it’s special for mirror and bathroom.
                      I didn’t want to have any borders. I prefer the frame like that (more contemporary I think !)
                        alvesge @belgium80
                        @belgium80
                        You’re the first one I see doing this like that ! Good job ;)
                        What is the model of the mirror ? Pilkington MirroView ? The mirror effect is great !
                          belgium80 @alvesge
                          @alvesge
                          I don’t know. No information in the invoice except the sizes. Sorry !
                            alvesge @belgium80
                            @belgium80
                            No problem ;) Thanks anyway
                            • bheplerB Offline
                              bhepler Module Developer
                              Looks great! Well done.
                              • slametpsS Offline
                                slametps @belgium80
                                @belgium80 said in My Mirror ! So great !:
                                @yawns
                                Mine is with a picam also for Face-Reco without any fan. The temperature is about 70C with CPU load around 15-20%. I think , the high temperature is causing by heat emitted by the display panel. But so far, so good. Mine is more than 14 months run smoothly. The monitor is also always ON.
                                regards,
                                Slamet PS
                                  belgium80 @slametps
                                  @slametps
                                  Yes you are right. The temperature increasing comes from the screen. I put a small switch to switch off/on the screen. In the future I will put a relay to switch on / off it automatically , with a timer to detect the activity of the PIR sensor and stop it during the night. (Hours range). That will be my next update.
                                    dmd
                                    Looks great! And the screen seems really bright. Is that monitor or tv? Do you know the brand/model? I’m interested what’s the brightness of the screen in cd/m².
                                      belgium80 @dmd
                                      @dmd
                                      It’s an old TV Sony Bravia LCD 94 cm if I remember well. The tuner was broken.
                                      • I Offline
                                        iorifly
                                        Man, for goods !!!
                                        I’m trying to build mine, but I’m finding it very difficult to find the mirror in my country (Brazil). Do you believe it?
                                           Congratulations on the project. His tv was 32 "??
                                        • kruemelK Offline
                                          kruemel
                                          Looks nice, i like the camera idea :-)
                                          What type of “cooling system” do you plan? Active with fan or what?
                                          Iam intrested in the end result of your project with the face recog.
                                            muffinimal
                                            Looks awesome, great work!
