    MMM-Webuntis
    Scheduled Pinned Locked Moved Education
    82 Posts 13 Posters 33.4k Views 13 Watching
    • E
      Eli @HeikoGr
      @HeikoGr
      Hi, I am running on an RPI normally. The test system is running on Windows, yes. But both show the same issue.
      I install modules the standard way, fro a git console by pulling and npm install.
      I also tried without remote control module - same issue.
      • E
        Eli @HeikoGr
        @HeikoGr Smashing, Heiko! Works perfect now! Many thanks!
        E 1 Reply Last reply
        • E
          Eli @Eli
          @Eli said in MMM-Webuntis:
          Small update: Seems to work only when debug mode is true…
          H 1 Reply Last reply
          • H
            HeikoGr @Eli
            @Eli maybe your school doesn‘t show more than 2 days to the future (like our school).
            Because the only differences in the debug mode are more log output and not filtering past lessons (there is also an undocumented option „debugLastDays“ - so i was able to develop during the holidays…). How many future days do you see in the untis app or on webuntis.com?
            H E 2 Replies Last reply
            • H
              HeikoGr @HeikoGr
              @HeikoGr a new commit is on github with a fix in the handling of “days” - maybe this fixes your problem.
              • O
                OliWer
                Fix works for me, thanks for your work!
                • E
                  Eli @HeikoGr
                  @HeikoGr Sorry, for the delayed reply. You are acorrect, also works without debug mode. Seems there was some other hickup with the server and just next time I enabled debug again is was working again. So all fine.
                  • H
                    HeikoGr
                    Achtung, ich habe eine neue Version veröffentlicht und dabei die Konfigurations Variablen umbenannt - es muss die config.js angepasst werden.
                    Dafür habe ich jetzt aber auch eine Tabellenansicht implementiert:
                    T 1 Reply Last reply
                    • T
                      thk @HeikoGr
                      @HeikoGr
                      Hallo & Vielen Dank für dieses tolle Modul!
                      I do love the module and especially the grid-view.
                      Is there a way to limit the number of hours displayed?
                      By that the vertical height of the grid-view could be reduced, I suppose.
                      I am asking because the generated table is exceeding the needed length to display the last hours of actual school, especially when there are weekdays in the grid which span across the whole day, like “kein Unterricht”.
                      I see there is a grid-comlumn-end, but I struggle to use it properly.
                      Thanks a lot in advance for any hint :-)
                      • H
                        HeikoGr @thk
                        @thk thank you for you kind word. I was able to implement a new config option “maxGridLessons” which will cut-off everything below the configured lesson. A “… more” badge is placed if an actual lesson is hidden because of this cutoff.
                        • T
                          thk @HeikoGr
                          @HeikoGr
                          Perfect!
                          Thank you so much for this fast feature implementation, exactly what I was looking for.
                          • H
                            HeikoGr
                            Attention / Important
                            (for our school) Untis GmbH changed url and schoolname.
                            You may need to log in your (childrens) account(s) an edit the config.js according to the new values.
                            At least they didn’t switch off te old json-rpc api MMM-Webuntis is using
                            • A
                              AlexLin @schmucke
                              @schmucke, @HeikoGr
                              I have the same situation and i finally managed to receive the timetable for my daughter by using parents account. She did not register herself for Webuntis so no chance. I made a research on the module and the webuntis API.
                              By concept the function
                              getOwnClassTimetableForRange(rangeStart, rangeEnd);
                              must fail, because the parents account does not have an own timetable. So I used the function
                              getTimetableForRange(rangeStart, rangeEnd, id, WebUntisElementType.STUDENT);
                              The trick was to determine which “id” is to use. The id is meant as student’s id, in my case of my daughter. So I had to make a detour via
                              const studentList = await untis.getStudents();
                              I made a debug output of studentList to console and searched for the name of my daughter and found the id I needed for the function above. This list is very long because it showed all students of school (more than one thousand).
                              Afterwards I could use the function and received her timetable successfully.
                              It only worked by login with username & pass not by qrcode and only by hardcoded id because I did not find a filter method for the studentList, e.g. by name, etc. If available it should be possible not hardcoded but by config - Param.
                              • H
                                HeikoGr
                                that’s great - i will look how i may use this in my module.
                                Thank you
                                  Rondejavu
                                  Ein guten Morgen,
                                  ich benutze Ihr WebUntis nun schon seid geraumer Zeit.
                                  Leider musste ich feststellen das seid ca. 2Wochen keine Verbindung mehr zu WebUntis stattfindet.
                                  mir wird jedes mal Error code 404 angezeigt.
                                  Was ich mir leider nicht vorstellen kann, da ich es auch über Handy nutze und dort alle Termine sowie den Stundenplan einsehen kann.
                                  Es wäre nett wenn ich dafür etwas Hilfe bekommen könnte damit dies wieder angezeigt wird.
                                  MfG
                                  Krause
                                  • H
                                    HeikoGr @Rondejavu
                                    @Rondejavu gerne:
                                    Ich vermute, dass die Antwort schon hier im Forum ca. 3 Beiträge obendrüber steht. Untis hat an den Servern gearbeitet - evtl. müssen hier die Verbindungsparamter neu eingestellt werden.
                                    R 1 Reply Last reply
                                      Rondejavu @HeikoGr
                                      @HeikoGr Moin,
                                      ja das ist mir klar … aber welche … da ich nur Zugang mit Benutzer und Passwort habe und keinen QR code … und auf der Website gibt es auch keinen link mehr um es iwie extern zu teilen bzw. der link funktioniert nicht in dem Modul … daher meine frage was ich jetzt machen soll …
                                      ich danke dir schon mal im voraus
                                      • H
                                        HeikoGr @Rondejavu
                                        @Rondejavu
                                        • Bei webuntis mit dem Schüleraccount anmelden.
                                        • Links unten auf den Account Namen klicken
                                        • Im rechten Panel auf “Freigaben” gehen
                                        • Dort gibt es den Link zum QR Code mit allen Paramtern für MMM-Webuntis.
                                        eine andere Anmeldemethode (über die Elternaccounts) habe ich leider noch nicht erfolgreich implementieren können.
                                          Rondejavu @HeikoGr
                                          @HeikoGr
                                          Nabend …
                                          wir haben nur einen Zugang, dann denke ich das wir nur den Elternzugang habe. Denn ich habe unten links leider keine möglichkeit irgendeinen QR-Code erstellen zu lassen.
                                          Anbei mal ein Bild was ich zu sehen bekomme …
                                          Danke im Voraus und falls man sich nicht liest … schöne Feiertage …
                                          • H
                                            HeikoGr @Rondejavu
                                            @Rondejavu Danke, dir auch schöne Feiertage.
                                            Ich arbeite bereits an einer massiven Überarbeitung.
                                            Dann sollte auch ein direkter Login funktionieren.
                                            Wenn ihr aber einen Zugang für die ganze Klasse habt (keine eigenen Benutzernamen) kann es sein, dass du mir helfen musst das lauffähig zu bekommen, da ich keine Testmöglichkeit habe Klassenaccounts zu testen.
                                            • 2 / 5
