    MMM-Webuntis
    Scheduled Pinned Locked Moved Education
    82 Posts 13 Posters 33.9k Views 13 Watching
    • H
      HeikoGr
      Note to myself: enhance error handling
      I did a clean reinstall on my machine and it worked with your config (and our qr code).
      Maybe the school doesn’t publish personal timetables?
      Can you try to set useClassTimetable: true,
      O 1 Reply Last reply
      • O
        OliWer @HeikoGr
        @HeikoGr
        added that to my config, but nothing changed.
        When I login to WebUntis via Browser, I can see a “My Timetable” (Mein Stundenplan). Not sure if there is a language difference or something.
        When I change the login information, I get error messages in the log, so the login itself seems to work and it gets data, even if it is just “all according to plan”. But not the data.
        What I also noticed is that there are two “My Timetable” in the web overview - one marked with beta.
        URL for non-beta: https://ikarus.webuntis.com/timetable-students-my/
        URL for beta: https://ikarus.webuntis.com/timetable-new/my-student
        URL for class: https://ikarus.webuntis.com/timetable-classes/
        So I think the school allowed the timetables you are asking for.
        Thanks for taking your time! Let me know if I can provide further information.
        • K
          kurkarte
          I am experiencing an issue with your MMM-WebUntis module. Despite following the setup instructions and providing the correct credentials, I am unable to log in. After testing, I believe the issue may be related to the presence of an umlaut (e.g., ö) and/or a whitespace in the school name.
          My Setup:
          MagicMirror Version: v2.29.0
          MMM-WebUntis Module Version: Latest from repository
          School Name: Contains an umlaut (ö) and a space
          Login Method: My school uses iserv (iserv.de) for authentication. I do not have direct login credentials for the WebUntis portal but instead rely on the QR code provided by the school, which works in the official WebUntis app.
          Configuration:
          Here is an example of my configuration (with pseudodata replacing sensitive values):
            module: "MMM-Webuntis",
            header: "WebUntis Schedule",
              students: [
                  title: "Student1",
                  qrcode: "untis://setschool?url=kadmos.webuntis.com&school=schulname with ö and space&user=username&key=ABC12345&schoolNumber=1234567",
              days: 10,
              mode: "verbose"
          Error Messages:
          Here are the errors I encountered:
          When using the QR code:
          [LOG]   ERROR for Student1: Error: Request failed with status code 400
          Debugging with the check.js script
          Error: getaddrinfo ENOTFOUND undefined
          When manually entering the school name, username, and password instead of using qrcode:
          Error: Failed to login. {"jsonrpc":"2.0","id":"Awesome","error":{"message":"bad credentials","code":-8504}}
          Observations:
          The QR code provided by webuntis contains the following (copied directly from the QR code content):
          You see, the miscoding of the ö.
          untis://setschool?url=example.webuntis.com&school=school name with � and space&user=username&key=ABC12345&schoolNumber=1234567
          Notably:
          The umlaut (ö) in the school name seems to cause issues.
          There is also a whitespace in the school name.
          Even when encoding the URL (e.g., using %C3%B6 for ö and %20 for the whitespace), I still encounter errors. I tried various configurations, including:
          "school%20name%20with%20%C3%B6%20and%20space"
          "schoolname with ö and space"
          "schoolname+with+oe+and+space"
          The QR code works perfectly in the WebUntis app, so I believe the credentials and format are correct. But my school uses iserv for authentication, meaning I do not have a standard WebUntis username and password.
          H 1 Reply Last reply
          • H
            HeikoGr @kurkarte
            @kurkarte you can try to search your school at https://webuntis.com/ . On the next site the school name in the URL could work if you replace empty spa es with „+“ signs.
            • H
              HeikoGr @OliWer
              @OliWer i pushed a fix to github.
              I was able to reproduce your error.
              it should work now.
              E 1 Reply Last reply
              Reply Quote 2
              • O
                OliWer
                Data is getting displayed now, will play around with it more later. Thank you very much!
                • E
                  Eli @HeikoGr
                  @HeikoGr
                  Hi, I am running on an RPI normally. The test system is running on Windows, yes. But both show the same issue.
                  I install modules the standard way, fro a git console by pulling and npm install.
                  I also tried without remote control module - same issue.
                  • E
                    Eli @HeikoGr
                    @HeikoGr Smashing, Heiko! Works perfect now! Many thanks!
                    • E
                      Eli @Eli
                      @Eli said in MMM-Webuntis:
                      Small update: Seems to work only when debug mode is true…
                      • H
                        HeikoGr @Eli
                        @Eli maybe your school doesn‘t show more than 2 days to the future (like our school).
                        Because the only differences in the debug mode are more log output and not filtering past lessons (there is also an undocumented option „debugLastDays“ - so i was able to develop during the holidays…). How many future days do you see in the untis app or on webuntis.com?
                        H E 2 Replies Last reply
                        • H
                          HeikoGr @HeikoGr
                          @HeikoGr a new commit is on github with a fix in the handling of “days” - maybe this fixes your problem.
                          • O
                            OliWer
                            Fix works for me, thanks for your work!
                            • E
                              Eli @HeikoGr
                              @HeikoGr Sorry, for the delayed reply. You are acorrect, also works without debug mode. Seems there was some other hickup with the server and just next time I enabled debug again is was working again. So all fine.
                              • H
                                HeikoGr
                                Achtung, ich habe eine neue Version veröffentlicht und dabei die Konfigurations Variablen umbenannt - es muss die config.js angepasst werden.
                                Dafür habe ich jetzt aber auch eine Tabellenansicht implementiert:
                                T 1 Reply Last reply
                                • T
                                  thk @HeikoGr
                                  @HeikoGr
                                  Hallo & Vielen Dank für dieses tolle Modul!
                                  I do love the module and especially the grid-view.
                                  Is there a way to limit the number of hours displayed?
                                  By that the vertical height of the grid-view could be reduced, I suppose.
                                  I am asking because the generated table is exceeding the needed length to display the last hours of actual school, especially when there are weekdays in the grid which span across the whole day, like “kein Unterricht”.
                                  I see there is a grid-comlumn-end, but I struggle to use it properly.
                                  Thanks a lot in advance for any hint :-)
                                  • H
                                    HeikoGr @thk
                                    @thk thank you for you kind word. I was able to implement a new config option “maxGridLessons” which will cut-off everything below the configured lesson. A “… more” badge is placed if an actual lesson is hidden because of this cutoff.
                                    • T
                                      thk @HeikoGr
                                      @HeikoGr
                                      Perfect!
                                      Thank you so much for this fast feature implementation, exactly what I was looking for.
                                      • H
                                        HeikoGr
                                        Attention / Important
                                        (for our school) Untis GmbH changed url and schoolname.
                                        You may need to log in your (childrens) account(s) an edit the config.js according to the new values.
                                        At least they didn’t switch off te old json-rpc api MMM-Webuntis is using
                                        • A
                                          AlexLin @schmucke
                                          @schmucke, @HeikoGr
                                          I have the same situation and i finally managed to receive the timetable for my daughter by using parents account. She did not register herself for Webuntis so no chance. I made a research on the module and the webuntis API.
                                          By concept the function
                                          getOwnClassTimetableForRange(rangeStart, rangeEnd);
                                          must fail, because the parents account does not have an own timetable. So I used the function
                                          getTimetableForRange(rangeStart, rangeEnd, id, WebUntisElementType.STUDENT);
                                          The trick was to determine which “id” is to use. The id is meant as student’s id, in my case of my daughter. So I had to make a detour via
                                          const studentList = await untis.getStudents();
                                          I made a debug output of studentList to console and searched for the name of my daughter and found the id I needed for the function above. This list is very long because it showed all students of school (more than one thousand).
                                          Afterwards I could use the function and received her timetable successfully.
                                          It only worked by login with username & pass not by qrcode and only by hardcoded id because I did not find a filter method for the studentList, e.g. by name, etc. If available it should be possible not hardcoded but by config - Param.
                                          • H
                                            HeikoGr
                                            that’s great - i will look how i may use this in my module.
                                            Thank you
                                            • 2 / 5
