    MMM-Webuntis
    Scheduled Pinned Locked Moved Education
    53 Posts 9 Posters 8.9k Views 9 Watching
    • E Offline
      Eli @Eli
      @Eli said in MMM-Webuntis:
      @HeikoGr Smashing, Heiko! Works perfect now! Many thanks!
      Small update: Seems to work only when debug mode is true…
      • H Offline
        HeikoGr @Eli
        @Eli maybe your school doesn‘t show more than 2 days to the future (like our school).
        Because the only differences in the debug mode are more log output and not filtering past lessons (there is also an undocumented option „debugLastDays“ - so i was able to develop during the holidays…). How many future days do you see in the untis app or on webuntis.com?
        H E 2 Replies Last reply Reply Quote 0
        • H Offline
          HeikoGr @HeikoGr
          @HeikoGr a new commit is on github with a fix in the handling of “days” - maybe this fixes your problem.
          • O Offline
            OliWer
            Fix works for me, thanks for your work!
            • E Offline
              Eli @HeikoGr
              @HeikoGr Sorry, for the delayed reply. You are acorrect, also works without debug mode. Seems there was some other hickup with the server and just next time I enabled debug again is was working again. So all fine.
              • H Offline
                HeikoGr
                Achtung, ich habe eine neue Version veröffentlicht und dabei die Konfigurations Variablen umbenannt - es muss die config.js angepasst werden.
                Dafür habe ich jetzt aber auch eine Tabellenansicht implementiert:
                • T Offline
                  thk @HeikoGr
                  @HeikoGr
                  Hallo & Vielen Dank für dieses tolle Modul!
                  I do love the module and especially the grid-view.
                  Is there a way to limit the number of hours displayed?
                  By that the vertical height of the grid-view could be reduced, I suppose.
                  I am asking because the generated table is exceeding the needed length to display the last hours of actual school, especially when there are weekdays in the grid which span across the whole day, like “kein Unterricht”.
                  I see there is a grid-comlumn-end, but I struggle to use it properly.
                  Thanks a lot in advance for any hint :-)
                  • H Offline
                    HeikoGr @thk
                    @thk thank you for you kind word. I was able to implement a new config option “maxGridLessons” which will cut-off everything below the configured lesson. A “… more” badge is placed if an actual lesson is hidden because of this cutoff.
                    • T Offline
                      thk @HeikoGr
                      @HeikoGr
                      Perfect!
                      Thank you so much for this fast feature implementation, exactly what I was looking for.
                      • H Offline
                        HeikoGr
                        Attention / Important
                        (for our school) Untis GmbH changed url and schoolname.
                        You may need to log in your (childrens) account(s) an edit the config.js according to the new values.
                        At least they didn’t switch off te old json-rpc api MMM-Webuntis is using
                        • 3 / 6
